[PATCH 2/3] powerpc/.../sbrk.c: Do not reference errno.
Joel Sherrill
joel at rtems.org
Fri May 21 21:35:44 UTC 2021
Closes #4r37.
bsps/powerpc/shared/start/sbrk.c | 14 ++++++++++++--
1 file changed, 12 insertions(+), 2 deletions(-)
diff --git a/bsps/powerpc/shared/start/sbrk.c b/bsps/powerpc/shared/start/sbrk.c
index 95104ba9c8..d7507b3997 100644
--- a/bsps/powerpc/shared/start/sbrk.c
+++ b/bsps/powerpc/shared/start/sbrk.c
@@ -150,9 +150,19 @@ void *sbrk(ptrdiff_t incr)
remaining_size-=incr;
rval = (void *) remaining_start;
remaining_start += incr;
- } else {
- errno = ENOMEM;
+ * sbrk() is a Legacy POSIX method which means it is no longer part of the
+ * POSIX standard. Historically, it was required to set errno to ENOMEM if
+ * the extension failed. This implementation does not do that for two
+ * reasons. First, this method is only called from the RTEMS malloc()
+ * implementation and does not expect errno to be set when -1 is returned.
+ * Second, setting errno implicitly pulls in some of the newlib reentrancy
+ * support. Not setting errno avoids this method forcing that support
+ * into every application for every BSP that uses this method.
#ifdef DEBUG
printk("************* SBRK 0x%08x (ret 0x%08x) **********\n", incr, rval);
#endif
2.24.4
