Minimum.exe Text Size Outliers
Mon May 24 13:00:56 UTC 2021
Hi
I built all 187 BSPs overnight and saved minimum.exe. Although I think 64K
is still too much code, I am using that as an initial cutoff when asking
for some help in identifying why minimum.exe is surprisingly large for some
BSPs. 146 stayed under 64k which leaves 41 needing some investigation or
explanation.  I suspect some might have a device tree blob linked in. The
surprising ones are the riscv, stmh7, beagle, and qoriq.
Here is the list:
 73680     504 34135552        34209736        209ffc8
minimum-exes/arm-nucleo-h743zi-minimum.exe
minimum-exes/arm-stm32h7-minimum.exe
  88509     452 268346424       268435385       fffffb9
minimum-exes/riscv-frdme310arty-minimum.exe
  88647     760 67019328        67108735        3ffff7f
minimum-exes/riscv-rv64imac_medany-minimum.exe
  88697     760 67019328        67108785        3ffffb1
minimum-exes/riscv-rv64imac-minimum.exe
  88947     760 67019072        67108779        3ffffab
minimum-exes/riscv-rv64imafdc-minimum.exe
  88955     760 67019072        67108787        3ffffb3
minimum-exes/riscv-rv64imafdc_medany-minimum.exe
  89279     452 67019064        67108795        3ffffbb
minimum-exes/riscv-rv32imac-minimum.exe
  89561     452 67018808        67108821        3ffffd5
minimum-exes/riscv-rv32imafc-minimum.exe
  89577     452 67018744        67108773        3ffffa5
minimum-exes/riscv-rv32imafdc-minimum.exe
  90267     452 67018040        67108759        3ffff97
minimum-exes/riscv-rv32iac-minimum.exe
  96523     760 67011520        67108803        3ffffc3
minimum-exes/riscv-rv64imafd_medany-minimum.exe
  96547     760 67011456        67108763        3ffff9b
minimum-exes/riscv-rv64imafd-minimum.exe
  97787     452 67010536        67108775        3ffffa7
minimum-exes/riscv-rv32im-minimum.exe
  98071     452 67010296        67108819        3ffffd3
minimum-exes/riscv-rv32imafd-minimum.exe
  99587     452 67008744        67108783        3ffffaf
minimum-exes/riscv-rv32i-minimum.exe
 100328    9148   24320  133796   20aa4 minimum-exes/i386-pc386-minimum.exe
 103344    9436   24256  137036   2174c minimum-exes/i386-pcp4-minimum.exe
 108836    9148   24320  142304   22be0 minimum-exes/i386-pc486-minimum.exe
 111956    9148   24320  145424   23810 minimum-exes/i386-pc586-minimum.exe
 112148    9372   24256  145776   23970
minimum-exes/i386-pc586-sse-minimum.exe
 114612    9148   24320  148080   24270 minimum-exes/i386-pc686-minimum.exe
 121013   19128   93696  233837   3916d
minimum-exes/powerpc-mvme5500-minimum.exe
 123765   22980  379760  526505   808a9
minimum-exes/powerpc-qemuprep-minimum.exe
 124253   22916  380484  527653   80d25
minimum-exes/powerpc-mvme2100-minimum.exe
 126669   23060  379760  529489   81451
minimum-exes/powerpc-qemuprep-altivec-minimum.exe
 129820    1024   11872  142716   22d7c minimum-exes/mips-malta-minimum.exe
 130673   24324  380496  535493   82bc5
minimum-exes/powerpc-mtx603e-minimum.exe
 130977   24380  380496  535853   82d2d
minimum-exes/powerpc-mcp750-minimum.exe
 131029   24240  380496  535765   82cd5
minimum-exes/powerpc-mvme2307-minimum.exe
 154493   23912   92876  271281   423b1
minimum-exes/powerpc-beatnik-minimum.exe
 168173   27216   25081  220470   35d36
minimum-exes/powerpc-mvme3100-minimum.exe
 289136     424 535532700       535822260       1fefffb4
 minimum-exes/arm-imx7-minimum.exe
 312308    7964 66788536        67108808        3ffffc8
minimum-exes/powerpc-qoriq_core_1-minimum.exe
 312340    8036 33277808        33598184        200aae8
minimum-exes/powerpc-qoriq_core_0-minimum.exe
 312340    8036 519817056       520137432       1f00aad8
 minimum-exes/powerpc-qoriq_e500-minimum.exe
 316944    8060 519816888       520141892       1f00bc44
 minimum-exes/powerpc-qoriq_e6500_32-minimum.exe
 331076    1304 519814736       520147116       1f00d0ac
 minimum-exes/powerpc-qoriq_e6500_64-minimum.exe
Help in reducing and/or explaining is appreciated.
--joel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210524/d4103229/attachment.html>
