Minimum.exe Text Size Outliers
Joel Sherrill
joel at rtems.org
Tue May 25 17:10:30 UTC 2021
Thanks for the feedback. I did save all of the minimum.exe files as @CPU@
- at BSP@-minimum.exe so they could be analysed. For exe, I did a size, the
tail -5, and also looked for some symbols that are hints of dependency
chains to things not needed. close(), atexit(), and
rtems_libio_post_driver() being the ones I know of now. I also did a
similar check for the bsp_fdt_blob since that does indicate a large area is
being reserved.
I agree that bsp_fdt_blob() is in "r" memory and being included in the text
report. Not sure if that's right since you are implying it is copied into
so I would have expected BSS.
I thought Sebastian added a "malloc" for the BSP to use before the heap was
initialized. But I don't remember the name. Am I remembering correctly?
It is promising that 24 of the BSPs do have the FDT blob. Getting that out
of the .text section report would possibly drop about half of the BSPs'
minimum below 64k. Plus I expect some like pc386 and motorola_powerpc are >
64k for good reasons not worth investigating.
--joel
On Tue, May 25, 2021 at 10:13 AM Christian MAUDERER <
christian.mauderer at embedded-brains.de> wrote:
> Hello Joel,
> I think we currently have very few BSPs with a linked in device tree
> blob. I know only of the new imxrt (which isn't in your list) and I
> think one Xilinx something BSP.
> For imx: I only have a build for some minimum based on 5 at hand right
> now. I have to re-build an up to date version to double check that. For
> this BSP there is 0x000069bc text size and 0x00040ebc rodata. So the
> rodata is the odd part.
> nm -S --size-sort
> ./build/b-imx7/arm-rtems5/c/imx7/testsuites/samples/minimum.exe | tail -5
> gives a
> 80205e40 000004e0 T memcpy
> 80203a00 0000078c T _IO_Vprintf
> 80300c2c 00000a00 B bsp_interrupt_handler_table
> 80301ac0 00001000 B _ISR_Stack_area_begin
> 80207080 00040000 r bsp_fdt_blob
> So yes: For some reason there is a big bsp_fdt_blob there even if none
> should be linked in. I had a look at that variable:
> https://git.rtems.org/rtems/tree/bsps/shared/start/bsp-fdt.c
> U-Boot passes a FDT blob and the BSP copies it into that area that is
> reserved with a fixed size. Seems reasonable because we can't easily
> allocate memory when we copy the FDT. It's done during initialization
> and therefore there is no heap yet.
> If you still have the binaries: Maybe you can call the nm command like
> above for the other BSPs too so we can see what the biggest objects are?
> Best regards
> Christian
> Am 24.05.21 um 15:00 schrieb Joel Sherrill:
> > Hi
> > I built all 187 BSPs overnight and saved minimum.exe. Although I think
> > 64K is still too much code, I am using that as an initial cutoff when
> > asking for some help in identifying why minimum.exe is surprisingly
> > large for some BSPs. 146 stayed under 64k which leaves 41 needing some
> > investigation or explanation. I suspect some might have a device tree
> > blob linked in. The surprising ones are the riscv, stmh7, beagle, and
> qoriq.
> > Here is the list:
> > 73680 504 34135552 34209736 209ffc8
> > minimum-exes/arm-nucleo-h743zi-minimum.exe
> > minimum-exes/arm-stm32h7-minimum.exe
> > 88509 452 268346424 268435385 fffffb9
> > minimum-exes/riscv-frdme310arty-minimum.exe
> > 88647 760 67019328 67108735 3ffff7f
> > minimum-exes/riscv-rv64imac_medany-minimum.exe
> > 88697 760 67019328 67108785 3ffffb1
> > minimum-exes/riscv-rv64imac-minimum.exe
> > 88947 760 67019072 67108779 3ffffab
> > minimum-exes/riscv-rv64imafdc-minimum.exe
> > 88955 760 67019072 67108787 3ffffb3
> > minimum-exes/riscv-rv64imafdc_medany-minimum.exe
> > 89279 452 67019064 67108795 3ffffbb
> > minimum-exes/riscv-rv32imac-minimum.exe
> > 89561 452 67018808 67108821 3ffffd5
> > minimum-exes/riscv-rv32imafc-minimum.exe
> > 89577 452 67018744 67108773 3ffffa5
> > minimum-exes/riscv-rv32imafdc-minimum.exe
> > 90267 452 67018040 67108759 3ffff97
> > minimum-exes/riscv-rv32iac-minimum.exe
> > 96523 760 67011520 67108803 3ffffc3
> > minimum-exes/riscv-rv64imafd_medany-minimum.exe
> > 96547 760 67011456 67108763 3ffff9b
> > minimum-exes/riscv-rv64imafd-minimum.exe
> > 97787 452 67010536 67108775 3ffffa7
> > minimum-exes/riscv-rv32im-minimum.exe
> > 98071 452 67010296 67108819 3ffffd3
> > minimum-exes/riscv-rv32imafd-minimum.exe
> > 99587 452 67008744 67108783 3ffffaf
> > minimum-exes/riscv-rv32i-minimum.exe
> > 100328 9148 24320 133796 20aa4
> minimum-exes/i386-pc386-minimum.exe
> > 103344 9436 24256 137036 2174c
> minimum-exes/i386-pcp4-minimum.exe
> > 108836 9148 24320 142304 22be0
> minimum-exes/i386-pc486-minimum.exe
> > 111956 9148 24320 145424 23810
> minimum-exes/i386-pc586-minimum.exe
> > 112148 9372 24256 145776 23970
> > minimum-exes/i386-pc586-sse-minimum.exe
> > 114612 9148 24320 148080 24270
> minimum-exes/i386-pc686-minimum.exe
> > 121013 19128 93696 233837 3916d
> > minimum-exes/powerpc-mvme5500-minimum.exe
> > 123765 22980 379760 526505 808a9
> > minimum-exes/powerpc-qemuprep-minimum.exe
> > 124253 22916 380484 527653 80d25
> > minimum-exes/powerpc-mvme2100-minimum.exe
> > 126669 23060 379760 529489 81451
> > minimum-exes/powerpc-qemuprep-altivec-minimum.exe
> > 129820 1024 11872 142716 22d7c
> minimum-exes/mips-malta-minimum.exe
> > 130673 24324 380496 535493 82bc5
> > minimum-exes/powerpc-mtx603e-minimum.exe
> > 130977 24380 380496 535853 82d2d
> > minimum-exes/powerpc-mcp750-minimum.exe
> > 131029 24240 380496 535765 82cd5
> > minimum-exes/powerpc-mvme2307-minimum.exe
> > 154493 23912 92876 271281 423b1
> > minimum-exes/powerpc-beatnik-minimum.exe
> > 168173 27216 25081 220470 35d36
> > minimum-exes/powerpc-mvme3100-minimum.exe
> > 289136 424 535532700 535822260 1fefffb4
> > minimum-exes/arm-imx7-minimum.exe
> > 312308 7964 66788536 67108808 3ffffc8
> > minimum-exes/powerpc-qoriq_core_1-minimum.exe
> > 312340 8036 33277808 33598184 200aae8
> > minimum-exes/powerpc-qoriq_core_0-minimum.exe
> > 312340 8036 519817056 520137432 1f00aad8
> > minimum-exes/powerpc-qoriq_e500-minimum.exe
> > 316944 8060 519816888 520141892 1f00bc44
> > minimum-exes/powerpc-qoriq_e6500_32-minimum.exe
> > 331076 1304 519814736 520147116 1f00d0ac
> > minimum-exes/powerpc-qoriq_e6500_64-minimum.exe
> > Help in reducing and/or explaining is appreciated.
> > --joel
> > devel mailing list
> > devel at rtems.org
> embedded brains GmbH
> Herr Christian MAUDERER
> Dornierstr. 4
> 82178 Puchheim
> Germany
> email: christian.mauderer at embedded-brains.de
> phone: +49-89-18 94 741 - 18
> fax: +49-89-18 94 741 - 08
> Registergericht: Amtsgericht München
> Registernummer: HRB 157899
> Vertretungsberechtigte Geschäftsführer: Peter Rasmussen, Thomas Dörfler
> Unsere Datenschutzerklärung finden Sie hier:
> https://embedded-brains.de/datenschutzerklaerung/
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210525/cdd068f4/attachment-0001.html>
======= aarch64-a53_ilp32_qemu-minimum.exe =====
text data bss dec hex filename
35780 492 8317928 8354200 7f7998 aarch64-a53_ilp32_qemu-minimum.exe
40009a00 0000035c T _Heap_Extend
40009fb0 000003b0 T _RBTree_Extract
4000ae00 00000f44 T _IO_Vprintf
40104ac0 00002800 B _ISR_Stack_area_begin
40100750 00004000 B bsp_interrupt_handler_table
======= aarch64-a53_lp64_qemu-minimum.exe =====
36016 776 8317360 8354152 7f7968 aarch64-a53_lp64_qemu-minimum.exe
0000000040009ea0 00000000000003b8 T _RBTree_Extract
0000000040100558 0000000000000408 b _Thread_Objects
000000004000acc0 0000000000000e98 T _IO_Vprintf
0000000040108ec0 0000000000002800 B _ISR_Stack_area_begin
0000000040100ac0 0000000000008000 B bsp_interrupt_handler_table
======= aarch64-xilinx_zynqmp_ilp32_qemu-minimum.exe =====
36252 532 268364240 268401024 fff7980 aarch64-xilinx_zynqmp_ilp32_qemu-minimum.exe
40021a00 0000035c T _Heap_Extend
40021fb0 000003b0 T _RBTree_Extract
40022db0 00000f44 T _IO_Vprintf
40104b00 00002800 B _ISR_Stack_area_begin
40100790 00004000 B bsp_interrupt_handler_table
======= aarch64-xilinx_zynqmp_lp64_qemu-minimum.exe =====
36504 840 268363656 268401000 fff7968 aarch64-xilinx_zynqmp_lp64_qemu-minimum.exe
0000000040021ea0 00000000000003b8 T _RBTree_Extract
0000000040100598 0000000000000408 b _Thread_Objects
0000000040022c70 0000000000000e98 T _IO_Vprintf
0000000040108f00 0000000000002800 B _ISR_Stack_area_begin
0000000040100b00 0000000000008000 B bsp_interrupt_handler_table
======= arm-atsamv-minimum.exe =====
22937 328 392860 416125 6597d arm-atsamv-minimum.exe
204003f0 000002a0 b _Thread_Objects
00402445 000002f6 T __udivmoddi4
20400778 00000410 B bsp_interrupt_handler_table
0040290d 000007b8 T _IO_Vprintf
20400e60 00001000 B _ISR_Stack_area_begin
======= arm-beagleboardorig-minimum.exe =====
354960 1368 263884740 264241068 fbfffac arm-beagleboardorig-minimum.exe
801016c0 00001000 B _ISR_Stack_area_begin
800543a8 0000157c r ti_padconf_devmap
8000e688 0000170c T _dtoa_r
8000bdbc 0000270c T _svfprintf_r
80011d40 00040000 r bsp_fdt_blob
FOUND: bsp_fdt_blob
======= arm-beagleboardxm-minimum.exe =====
354960 1368 263884740 264241068 fbfffac arm-beagleboardxm-minimum.exe
FOUND: bsp_fdt_blob
======= arm-beagleboneblack-minimum.exe =====
354960 1368 263884740 264241068 fbfffac arm-beagleboneblack-minimum.exe
FOUND: bsp_fdt_blob
======= arm-beaglebonewhite-minimum.exe =====
354960 1368 263884740 264241068 fbfffac arm-beaglebonewhite-minimum.exe
FOUND: bsp_fdt_blob
======= arm-csb336-minimum.exe =====
19500 616 31404360 31424476 1df7fdc arm-csb336-minimum.exe
0820b20c 0000025c T _Thread_Initialize
082091b0 00000370 T _Heap_Extend
0820d36c 00000400 B bsp_interrupt_handler_table
0820a1f4 00000d9c T _IO_Vprintf
0820da20 00001000 B _ISR_Stack_area_begin
======= arm-csb337-minimum.exe =====
19780 584 15691928 15712292 efc024 arm-csb337-minimum.exe
201050f0 00000258 b _Thread_Objects
201032e4 0000025c T _Thread_Initialize
201011b0 00000370 T _Heap_Extend
201022cc 00000d9c T _IO_Vprintf
201058a0 00001000 B _ISR_Stack_area_begin
======= arm-csb637-minimum.exe =====
19780 584 66023576 66043940 3efc024 arm-csb637-minimum.exe
======= arm-edb7312-minimum.exe =====
19720 392 16757072 16777184 ffffe0 arm-edb7312-minimum.exe
00003320 00000254 T _Thread_Initialize
00004ff0 00000258 b _Thread_Objects
00001184 00000370 T _Heap_Extend
00002308 00000d9c T _IO_Vprintf
00005700 00001000 B _ISR_Stack_area_begin
======= arm-fvp_cortex_r52-minimum.exe =====
16096 272 33536924 33553292 1fffb8c arm-fvp_cortex_r52-minimum.exe
00004650 000002a0 b _Thread_Objects
00001cd1 00000388 T __udivmoddi4
000049cc 00000610 B bsp_interrupt_handler_table
00002141 000007dc T _IO_Vprintf
00005280 00001000 B _ISR_Stack_area_begin
======= arm-gumstix-minimum.exe =====
19380 456 67072632 67092468 3ffbff4 arm-gumstix-minimum.exe
a0007080 0000023c T _Thread_Initialize
a0008f10 00000258 b _Thread_Objects
a0005158 00000370 T _Heap_Extend
a00060e4 00000d48 T _IO_Vprintf
a00096c0 00001000 B _ISR_Stack_area_begin
======= arm-imx7-minimum.exe =====
289136 424 535532700 535822260 1fefffb4 arm-imx7-minimum.exe
80204c00 000004e0 T memcpy
80202971 000007ee T _IO_Vprintf
80300698 00000a00 B bsp_interrupt_handler_table
803014c0 00001000 B _ISR_Stack_area_begin
80205c40 00040000 r bsp_fdt_blob
FOUND: bsp_fdt_blob
======= arm-imxrt1052-minimum.exe =====
55632 1024 33553392 33610048 200d940 arm-imxrt1052-minimum.exe
60004419 00000518 T BOARD_BootClockRUN
60007c69 000007b8 T _IO_Vprintf
800008fc 00000a00 B bsp_interrupt_handler_table
80001860 00001000 B _ISR_Stack_area_begin
6000b7d0 00002b36 R imxrt_dtb
======= arm-kit637_v6-minimum.exe =====
19780 584 66023576 66043940 3efc024 arm-kit637_v6-minimum.exe
======= arm-lm3s3749-minimum.exe =====
24925 528 64976 90429 1613d arm-lm3s3749-minimum.exe
000049c9 000002d0 T rtems_termios_enqueue_raw_characters
000021cd 000002da T __udivmoddi4
200007b8 00000300 B bsp_interrupt_handler_table
00002715 000007b8 T _IO_Vprintf
20000e40 00001000 B _ISR_Stack_area_begin
======= arm-lm3s6965-minimum.exe =====
24929 528 64976 90433 16141 arm-lm3s6965-minimum.exe
000049cd 000002d0 T rtems_termios_enqueue_raw_characters
000021d1 000002da T __udivmoddi4
00002719 000007b8 T _IO_Vprintf
======= arm-lm3s6965_qemu-minimum.exe =====
24929 528 16776656 16802113 1006141 arm-lm3s6965_qemu-minimum.exe
======= arm-lm4f120-minimum.exe =====
24921 528 32208 57657 e139 arm-lm4f120-minimum.exe
000049c5 000002d0 T rtems_termios_enqueue_raw_characters
000021c9 000002da T __udivmoddi4
00002711 000007b8 T _IO_Vprintf
======= arm-lpc1768_mbed_ahb_ram_eth-minimum.exe =====
17124 300 48836 66260 102d4 arm-lpc1768_mbed_ahb_ram_eth-minimum.exe
10000370 00000258 b _Thread_Objects
100006b8 00000290 B bsp_interrupt_handler_table
00001dc1 000002da T __udivmoddi4
000021c1 000007b8 T _IO_Vprintf
2007c200 00001000 B _ISR_Stack_area_begin
======= arm-lpc1768_mbed_ahb_ram-minimum.exe =====
17124 300 65220 82644 142d4 arm-lpc1768_mbed_ahb_ram-minimum.exe
======= arm-lpc1768_mbed-minimum.exe =====
17124 300 32436 49860 c2c4 arm-lpc1768_mbed-minimum.exe
10000bc0 00001000 B _ISR_Stack_area_begin
======= arm-lpc17xx_ea_ram-minimum.exe =====
16795 288 33602824 33619907 200ffc3 arm-lpc17xx_ea_ram-minimum.exe
a0004430 00000258 b _Thread_Objects
a0004778 00000290 B bsp_interrupt_handler_table
a0001f25 000002da T __udivmoddi4
a00022cd 000007b8 T _IO_Vprintf
a0004c80 00001000 B _ISR_Stack_area_begin
======= arm-lpc17xx_ea_rom_int-minimum.exe =====
16963 288 33554348 33571599 200430f arm-lpc17xx_ea_rom_int-minimum.exe
a0000270 00000258 b _Thread_Objects
a00005b8 00000290 B bsp_interrupt_handler_table
00001fcd 000002da T __udivmoddi4
00002375 000007b8 T _IO_Vprintf
a0000ac0 00001000 B _ISR_Stack_area_begin
======= arm-lpc17xx_plx800_ram-minimum.exe =====
16791 288 33602856 33619935 200ffdf arm-lpc17xx_plx800_ram-minimum.exe
a0004410 00000258 b _Thread_Objects
a0004758 00000290 B bsp_interrupt_handler_table
a0001f21 000002da T __udivmoddi4
a00022c9 000007b8 T _IO_Vprintf
a0004c60 00001000 B _ISR_Stack_area_begin
======= arm-lpc17xx_plx800_rom_int-minimum.exe =====
16999 288 33619656 33636943 201424f arm-lpc17xx_plx800_rom_int-minimum.exe
00001ff1 000002da T __udivmoddi4
00002399 000007b8 T _IO_Vprintf
======= arm-lpc2362-minimum.exe =====
17351 272 32460 50083 c3a3 arm-lpc2362-minimum.exe
40000860 00000200 B _Thread_Idle_stacks
400002b0 00000258 b _Thread_Objects
0000141d 0000027a T _Heap_Extend
00002351 000007ec T _IO_Vprintf
40000a60 00001000 B _ISR_Stack_area_begin
======= arm-lpc23xx_tli800-minimum.exe =====
17351 272 32460 50083 c3a3 arm-lpc23xx_tli800-minimum.exe
00002d8d 0000027a T _Heap_Extend
00003cc1 000007ec T _IO_Vprintf
======= arm-lpc24xx_ea-minimum.exe =====
17375 272 33602284 33619931 200ffdb arm-lpc24xx_ea-minimum.exe
a000025d 0000022c T bsp_start_hook_1
a0004650 00000258 b _Thread_Objects
a0001465 0000027a T _Heap_Extend
a0002369 000007ec T _IO_Vprintf
a0004e00 00001000 B _ISR_Stack_area_begin
======= arm-lpc24xx_ncs_ram-minimum.exe =====
17375 272 8436460 8454107 80ffdb arm-lpc24xx_ncs_ram-minimum.exe
======= arm-lpc24xx_ncs_rom_ext-minimum.exe =====
17563 272 4243884 4261719 410757 arm-lpc24xx_ncs_rom_ext-minimum.exe
8100025d 0000022c T bsp_start_hook_1
a0403f90 00000258 b _Thread_Objects
a0400d8d 0000027a T _Heap_Extend
a0401c91 000007ec T _IO_Vprintf
a0404740 00001000 B _ISR_Stack_area_begin
======= arm-lpc24xx_ncs_rom_int-minimum.exe =====
17515 272 4226828 4244615 40c487 arm-lpc24xx_ncs_rom_int-minimum.exe
0000025d 0000022c T bsp_start_hook_1
a0400270 00000258 b _Thread_Objects
000014ed 0000027a T _Heap_Extend
000023f1 000007ec T _IO_Vprintf
a0400a20 00001000 B _ISR_Stack_area_begin
======= arm-lpc24xx_plx800_ram-minimum.exe =====
17383 272 33602284 33619939 200ffe3 arm-lpc24xx_plx800_ram-minimum.exe
a0000265 0000022c T bsp_start_hook_1
a000146d 0000027a T _Heap_Extend
a0002371 000007ec T _IO_Vprintf
======= arm-lpc24xx_plx800_rom_int-minimum.exe =====
17527 272 33619660 33637459 2014453 arm-lpc24xx_plx800_rom_int-minimum.exe
00000265 0000022c T bsp_start_hook_1
000014fd 0000027a T _Heap_Extend
00002401 000007ec T _IO_Vprintf
a0000a20 00001000 B _ISR_Stack_area_begin
======= arm-lpc32xx_mzx-minimum.exe =====
16621 272 33779172 33796065 203afe1 arm-lpc32xx_mzx-minimum.exe
800062cd 00000276 T _Heap_Extend
80005199 00000300 T bsp_start_hook_1
801006d8 00000600 B bsp_interrupt_handler_table
80007165 000007bc T _IO_Vprintf
80100f40 00001000 B _ISR_Stack_area_begin
======= arm-lpc32xx_mzx_stage_1-minimum.exe =====
16621 272 220640 237533 39fdd arm-lpc32xx_mzx_stage_1-minimum.exe
080012cd 00000276 T _Heap_Extend
08000199 00000300 T bsp_start_hook_1
080047d8 00000600 B bsp_interrupt_handler_table
08002165 000007bc T _IO_Vprintf
08005040 00001000 B _ISR_Stack_area_begin
======= arm-lpc32xx_mzx_stage_2-minimum.exe =====
16621 272 4423136 4440029 43bfdd arm-lpc32xx_mzx_stage_2-minimum.exe
81c012cd 00000276 T _Heap_Extend
81c00199 00000300 T bsp_start_hook_1
81c047d8 00000600 B bsp_interrupt_handler_table
81c02165 000007bc T _IO_Vprintf
81c05040 00001000 B _ISR_Stack_area_begin
======= arm-lpc32xx_phycore-minimum.exe =====
16621 272 67333604 67350497 403afe1 arm-lpc32xx_phycore-minimum.exe
800052cd 00000276 T _Heap_Extend
80004199 00000300 T bsp_start_hook_1
80006165 000007bc T _IO_Vprintf
======= arm-lpc40xx_ea_ram-minimum.exe =====
16991 288 33602600 33619879 200ffa7 arm-lpc40xx_ea_ram-minimum.exe
a0004898 00000290 B bsp_interrupt_handler_table
a0004510 000002a0 b _Thread_Objects
a0001f65 000002d8 T __udivmoddi4
a0002309 000007b2 T _IO_Vprintf
a0004da0 00001000 B _ISR_Stack_area_begin
======= arm-lpc40xx_ea_rom_int-minimum.exe =====
17159 288 33554348 33571795 20043d3 arm-lpc40xx_ea_rom_int-minimum.exe
a00005f8 00000290 B bsp_interrupt_handler_table
a0000270 000002a0 b _Thread_Objects
00002025 000002d8 T __udivmoddi4
000023c9 000007b2 T _IO_Vprintf
a0000b00 00001000 B _ISR_Stack_area_begin
======= arm-nucleo-h743zi-minimum.exe =====
73680 504 34135552 34209736 209ffc8 arm-nucleo-h743zi-minimum.exe
70004499 000007b8 T _IO_Vprintf
70003095 00000a6c T HAL_RCCEx_PeriphCLKConfig
700126d8 00000f00 B bsp_interrupt_handler_table
700138c0 00001000 B _ISR_Stack_area_begin
700065e1 00001528 T UART_SetConfig
======= arm-raspberrypi2-minimum.exe =====
28032 5976 266304188 266338196 fdfff94 arm-raspberrypi2-minimum.exe
00301c58 00000480 B bsp_interrupt_handler_table
00204200 000004e0 T memcpy
00202eed 000007ee T _IO_Vprintf
00302980 00001000 B _ISR_Stack_area_begin
003000f8 00001000 d rpi_font
======= arm-raspberrypi-minimum.exe =====
34444 5976 266297864 266338284 fdfffec arm-raspberrypi-minimum.exe
00205db4 00000420 t two_way_long_needle
00301bf8 00000480 B bsp_interrupt_handler_table
00203b58 00000d30 T _IO_Vprintf
00302920 00001000 B _ISR_Stack_area_begin
======= arm-realview_pbx_a9_qemu-minimum.exe =====
35329 312 263140472 263176113 fafbfb1 arm-realview_pbx_a9_qemu-minimum.exe
00107400 000004e0 T memcpy
0020060c 000005a0 B bsp_interrupt_handler_table
001053b9 00000a98 T _IO_Vprintf
00200e40 00001000 B _ISR_Stack_area_begin
00201e40 00001000 B _ISR_Stack_area_end
======= arm-rtl22xx-minimum.exe =====
19033 272 505000 524305 80011 arm-rtl22xx-minimum.exe
810031d4 00000254 T _Thread_Initialize
81004cd0 00000258 b _Thread_Objects
810011a4 00000370 T _Heap_Extend
810021e4 00000d9c T _IO_Vprintf
81005440 00001000 B _ISR_Stack_area_begin
======= arm-rtl22xx_t-minimum.exe =====
15489 272 508552 524313 80019 arm-rtl22xx_t-minimum.exe
81004460 00000200 B _Thread_Idle_stacks
81003ef0 00000258 b _Thread_Objects
81000e81 0000027a T _Heap_Extend
81001c55 000007ec T _IO_Vprintf
81004660 00001000 B _ISR_Stack_area_begin
======= arm-smdk2410-minimum.exe =====
21877 368 67070188 67092433 3ffbfd1 arm-smdk2410-minimum.exe
300060b0 00000314 T __aeabi_dsub
300060b0 00000314 T __subdf3
3000523c 00000370 T _Heap_Extend
30006cc0 00000d9c T _IO_Vprintf
3000a040 00001000 B _ISR_Stack_area_begin
======= arm-stm32f105rc-minimum.exe =====
17910 476 65048 83434 145ea arm-stm32f105rc-minimum.exe
200004b0 00000258 b _Thread_Objects
00001c45 000002da T __udivmoddi4
200007f8 00000520 B bsp_interrupt_handler_table
00001fed 000007b8 T _IO_Vprintf
20000fa0 00001000 B _ISR_Stack_area_begin
======= arm-stm32f4-minimum.exe =====
17942 476 130584 149002 2460a arm-stm32f4-minimum.exe
00000a01 00000238 t _Timecounter_Windup
00001f41 000007b0 T _IO_Vprintf
======= arm-stm32h7-minimum.exe =====
73680 504 34135552 34209736 209ffc8 arm-stm32h7-minimum.exe
======= arm-tms570ls3137_hdk_intram-minimum.exe =====
18012 484 243304 261800 3fea8 arm-tms570ls3137_hdk_intram-minimum.exe
08003529 000002bc T strcmp
08001905 0000037e T __udivmoddi4
08004e8c 000005f0 B bsp_interrupt_handler_table
08001d6d 000007d2 T _IO_Vprintf
08005700 00001000 B _ISR_Stack_area_begin
======= arm-tms570ls3137_hdk-minimum.exe =====
18012 484 261384 279880 44548 arm-tms570ls3137_hdk-minimum.exe
00003429 000002bc T strcmp
00001805 0000037e T __udivmoddi4
080007ec 000005f0 B bsp_interrupt_handler_table
00001c6d 000007d2 T _IO_Vprintf
08001060 00001000 B _ISR_Stack_area_begin
======= arm-tms570ls3137_hdk_sdram-minimum.exe =====
18012 484 8370024 8388520 7fffa8 arm-tms570ls3137_hdk_sdram-minimum.exe
80003429 000002bc T strcmp
80001805 0000037e T __udivmoddi4
80004d8c 000005f0 B bsp_interrupt_handler_table
80001c6d 000007d2 T _IO_Vprintf
80005600 00001000 B _ISR_Stack_area_begin
======= arm-tms570ls3137_hdk_with_loader-minimum.exe =====
18012 484 261384 279880 44548 arm-tms570ls3137_hdk_with_loader-minimum.exe
00043429 000002bc T strcmp
00041805 0000037e T __udivmoddi4
00041c6d 000007d2 T _IO_Vprintf
======= arm-xen_virtual-minimum.exe =====
21792 472 8333448 8355712 7f7f80 arm-xen_virtual-minimum.exe
40100350 000002a0 b _Thread_Objects
4000bf80 000004e0 T memcpy
4000a165 000007c8 T _IO_Vprintf
40104a40 00001000 B _ISR_Stack_area_begin
401006cc 00004000 B bsp_interrupt_handler_table
======= arm-xilinx_zynq_a9_qemu-minimum.exe =====
21840 392 267348192 267370424 fefbfb8 arm-xilinx_zynq_a9_qemu-minimum.exe
002002d0 000002a0 b _Thread_Objects
00108080 000004e0 T memcpy
0020064c 000005d0 B bsp_interrupt_handler_table
00106299 000007d4 T _IO_Vprintf
00200f00 00001000 B _ISR_Stack_area_begin
======= arm-xilinx_zynqmp_ultra96-minimum.exe =====
22044 512 2146396056 2146418612 7fefbfb4 arm-xilinx_zynqmp_ultra96-minimum.exe
00200350 000002a0 b _Thread_Objects
00108180 000004e0 T memcpy
00106285 000007c8 T _IO_Vprintf
002006cc 00000bc0 B bsp_interrupt_handler_table
00201580 00001000 B _ISR_Stack_area_begin
======= arm-xilinx_zynq_zc702-minimum.exe =====
24188 392 1072652216 1072676796 3fefbfbc arm-xilinx_zynq_zc702-minimum.exe
00105bd5 0000038a t l2c_310_check_errata
00108580 000004e0 T memcpy
00106795 000007d4 T _IO_Vprintf
======= arm-xilinx_zynq_zc706-minimum.exe =====
24188 392 1069506488 1069531068 3fbfbfbc arm-xilinx_zynq_zc706-minimum.exe
00405bd5 0000038a t l2c_310_check_errata
00408580 000004e0 T memcpy
0050064c 000005d0 B bsp_interrupt_handler_table
00406795 000007d4 T _IO_Vprintf
00500f00 00001000 B _ISR_Stack_area_begin
======= arm-xilinx_zynq_zedboard-minimum.exe =====
24188 392 535781304 535805884 1fefbfbc arm-xilinx_zynq_zedboard-minimum.exe
======= bfin-bf537Stamp-minimum.exe =====
23788 1016 10484 35288 89d8 bfin-bf537Stamp-minimum.exe
00003c3c 000002be T __RBTree_Extract
00001910 00000428 T ___umoddi3
000014d0 00000440 T ___udivdi3
0000466c 0000087e T __IO_Vprintf
000079e0 00002000 B __ISR_Stack_area_begin
======= bfin-eZKit533-minimum.exe =====
23296 760 10464 34520 86d8 bfin-eZKit533-minimum.exe
00003b7c 000002be T __RBTree_Extract
00001850 00000428 T ___umoddi3
00001410 00000440 T ___udivdi3
00004480 0000087e T __IO_Vprintf
000076e0 00002000 B __ISR_Stack_area_begin
======= bfin-TLL6527M-minimum.exe =====
23536 760 11372 35668 8b54 bfin-TLL6527M-minimum.exe
00006498 00000380 b _ivt
000009d0 00000428 T ___umoddi3
00000590 00000440 T ___udivdi3
00003698 0000087c T __IO_Vprintf
00006c60 00002000 B __ISR_Stack_area_begin
======= i386-pc386-minimum.exe =====
100328 9148 24320 133796 20aa4 i386-pc386-minimum.exe
00120b00 00001000 B _ISR_Stack_area_begin
001128dc 000011dd T _dtoa_r
0011c520 00001400 b idtHdl
0011de20 00002710 B i386_gdb_remcomStack
0010fd50 000029e3 T _svfprintf_r
======= i386-pc486-minimum.exe =====
108836 9148 24320 142304 22be0 i386-pc486-minimum.exe
00122c40 00001000 B _ISR_Stack_area_begin
00114a0c 000011dd T _dtoa_r
0011e660 00001400 b idtHdl
0011ff60 00002710 B i386_gdb_remcomStack
00111e80 000029e3 T _svfprintf_r
======= i386-pc586-minimum.exe =====
111956 9148 24320 145424 23810 i386-pc586-minimum.exe
00123880 00001000 B _ISR_Stack_area_begin
00115290 0000138f T _dtoa_r
0011f280 00001400 b idtHdl
00120b80 00002710 B i386_gdb_remcomStack
00112490 00002be8 T _svfprintf_r
======= i386-pc586-sse-minimum.exe =====
112148 9372 24256 145776 23970 i386-pc586-sse-minimum.exe
001239c0 00001000 B _ISR_Stack_area_begin
00115310 0000138f T _dtoa_r
0011f3a0 00001400 b idtHdl
00120ca0 00002710 B i386_gdb_remcomStack
00112510 00002be8 T _svfprintf_r
======= i386-pc686-minimum.exe =====
114612 9148 24320 148080 24270 i386-pc686-minimum.exe
00123300 00001000 B _ISR_Stack_area_begin
00115ca0 0000138f T _dtoa_r
0011ed00 00001400 b idtHdl
00120600 00002710 B i386_gdb_remcomStack
00112ea0 00002be8 T _svfprintf_r
======= i386-pcp4-minimum.exe =====
103344 9436 24256 137036 2174c i386-pcp4-minimum.exe
001217c0 00001000 B _ISR_Stack_area_begin
001134ec 000011dd T _dtoa_r
0011d180 00001400 b idtHdl
0011ea80 00002710 B i386_gdb_remcomStack
00110960 000029e3 T _svfprintf_r
======= lm32-lm32_evr_gdbsim-minimum.exe =====
27052 280 6089 33421 828d lm32-lm32_evr_gdbsim-minimum.exe
08001808 00000378 T _Heap_Extend
08004cb8 00000890 T __umoddi3
080026e4 000008c4 T __udivdi3
080034b4 00000b8c T _IO_Vprintf
080078e0 00001000 B _ISR_Stack_area_begin
======= lm32-lm32_evr-minimum.exe =====
27052 280 6089 33421 828d lm32-lm32_evr-minimum.exe
08004cb0 00000890 T __umoddi3
080026dc 000008c4 T __udivdi3
080034ac 00000b8c T _IO_Vprintf
======= lm32-milkymist-minimum.exe =====
12708 272 6081 19061 4a75 lm32-milkymist-minimum.exe
40000738 00000228 T _Scheduler_priority_Update_priority
400027ac 00000280 T _Thread_Initialize
40004188 00000280 b _Thread_Objects
400017a0 00000338 T _Heap_Extend
400048e0 00001000 B _ISR_Stack_area_begin
======= m68k-av5282-minimum.exe =====
18560 400 6800 25760 64a0 m68k-av5282-minimum.exe
00043824 0000032c T __umoddi3
00041dc4 000003d6 T __udivdi3
00044e34 00000400 B _ISR_Vector_table
0004225c 00000c52 T _IO_Vprintf
000454a0 00001000 B _ISR_Stack_area_begin
======= m68k-COBRA5475-minimum.exe =====
21060 384 134196264 134217708 7ffffec m68k-COBRA5475-minimum.exe
f0003a74 00000416 T __umoddi3
f0005c70 00000480 B IntUartInfo
f0001f6c 0000048c T __udivdi3
f00024b6 00000c96 T _IO_Vprintf
f0006300 00001000 B _ISR_Stack_area_begin
======= m68k-csb360-minimum.exe =====
17152 288 6800 24240 5eb0 m68k-csb360-minimum.exe
0010445c 0000022c b _Thread_Objects
00101458 000002f0 T _Heap_Extend
0010477a 00000400 B _ISR_Vector_table
00101f7a 00000c2c T _IO_Vprintf
00104eb0 00001000 B _ISR_Stack_area_begin
======= m68k-gen68340-minimum.exe =====
19712 3568 16096 39376 99d0 m68k-gen68340-minimum.exe
10001640 000002ec T _Heap_Extend
10001da4 0000039a T _dbug_dumpanic
1000624a 00000400 B _ISR_Vector_table
10002468 00000bd6 T _IO_Vprintf
100069d0 00001000 B _ISR_Stack_area_begin
======= m68k-gen68360_040-minimum.exe =====
18112 256 16000 34368 8640 m68k-gen68360_040-minimum.exe
00004fe4 00000400 B _ISR_Vector_table
00001b60 00000462 T __udivdi3
00002080 00000bd6 T _IO_Vprintf
00005640 00001000 B _ISR_Stack_area_begin
0e000000 00001800 B m360
======= m68k-gen68360-minimum.exe =====
17248 288 16000 33536 8300 m68k-gen68360-minimum.exe
00001328 000002ec T _Heap_Extend
00004bda 00000400 B _ISR_Vector_table
00001f7c 00000bd6 T _IO_Vprintf
00005300 00001000 B _ISR_Stack_area_begin
======= m68k-m5484FireEngine-minimum.exe =====
21664 384 67086808 67108856 3fffff8 m68k-m5484FireEngine-minimum.exe
00003cd4 00000416 T __umoddi3
00005ec0 00000480 B IntUartInfo
000021cc 0000048c T __udivdi3
00002716 00000c96 T _IO_Vprintf
00006550 00001000 B _ISR_Stack_area_begin
======= m68k-mcf5206elite-minimum.exe =====
20080 272 7808 28160 6e00 m68k-mcf5206elite-minimum.exe
300056da 00000400 B _ISR_Vector_table
30003f94 000004ea T __umoddi3
300023d0 00000560 T __udivdi3
30002a22 00000c2c T _IO_Vprintf
30005e00 00001000 B _ISR_Stack_area_begin
======= m68k-mcf52235-minimum.exe =====
19264 288 3712 23264 5ae0 m68k-mcf52235-minimum.exe
000021d8 000003d6 T __udivdi3
20000fa0 00000400 B _ISR_Stack_area_begin
20000944 00000400 B _ISR_Vector_table
00001cfe 0000046e T init_main
00002670 00000c52 T _IO_Vprintf
======= m68k-mcf5225x-minimum.exe =====
18112 288 3712 22112 5660 m68k-mcf5225x-minimum.exe
00003784 0000032c T __umoddi3
00001d54 000003d6 T __udivdi3
000021ec 00000c52 T _IO_Vprintf
======= m68k-mcf5235-minimum.exe =====
18496 400 6800 25696 6460 m68k-mcf5235-minimum.exe
000437d8 0000032c T __umoddi3
00041d78 000003d6 T __udivdi3
00044df4 00000400 B _ISR_Vector_table
00042210 00000c52 T _IO_Vprintf
00045460 00001000 B _ISR_Stack_area_begin
======= m68k-mcf5329-minimum.exe =====
21216 416 6800 28432 6f10 m68k-mcf5329-minimum.exe
400042e8 0000045e T __umoddi3
40002274 0000049c T init_main
400027a0 000004bc T __udivdi3
40002d1e 00000c52 T _IO_Vprintf
80000360 00001000 B _ISR_Stack_area_begin
======= m68k-mrm332-minimum.exe =====
15472 400 7824 23696 5c90 m68k-mrm332-minimum.exe
00090e0a 00000208 T _Heap_Extend
000035cc 0000022c b _Thread_Objects
000038ea 00000400 B _ISR_Vector_table
000918a6 000006dc T _IO_Vprintf
00004020 00001000 B _ISR_Stack_area_begin
======= m68k-mvme147-minimum.exe =====
17460 256 4156096 4173812 3faff4 m68k-mvme147-minimum.exe
00009df0 00000200 B _Thread_Idle_stacks
000095aa 0000022c b _Thread_Objects
00008210 000002f8 T _Heap_Extend
00009994 00000400 B _ISR_Vector_table
00009ff0 00001000 B _ISR_Stack_area_begin
======= m68k-mvme147s-minimum.exe =====
24364 260 4141008 4165632 3f9000 m68k-mvme147s-minimum.exe
0000d09a 0000022c b _Thread_Objects
0000a210 000002f8 T _Heap_Extend
0000d484 00000400 B _ISR_Vector_table
0000ac4a 00000bd0 T _IO_Vprintf
0000dae0 00001000 B _ISR_Stack_area_begin
======= m68k-mvme162lx-minimum.exe =====
17564 284 4294818355 4294836203 fffdffeb m68k-mvme162lx-minimum.exe
00024e80 00000200 B _Thread_Idle_stacks
0002462a 0000022c b _Thread_Objects
00023340 000002f0 T _Heap_Extend
00024a14 00000400 B _ISR_Vector_table
00025080 00001000 B _ISR_Stack_area_begin
======= m68k-mvme162-minimum.exe =====
17564 284 4294818355 4294836203 fffdffeb m68k-mvme162-minimum.exe
======= m68k-mvme167-minimum.exe =====
56960 256 4294910071 4294967287 fffffff7 m68k-mvme167-minimum.exe
0000e860 00000200 B _Thread_Idle_stacks
0000dfea 0000022c b _Thread_Objects
00003218 000002fc T _Heap_Extend
0000e3d4 00000400 B _ISR_Vector_table
0000ea60 00001000 B _ISR_Stack_area_begin
======= m68k-pgh360-minimum.exe =====
17072 288 16000 33360 8250 m68k-pgh360-minimum.exe
00004b2a 00000400 B _ISR_Vector_table
00001ec4 00000bd6 T _IO_Vprintf
00005250 00001000 B _ISR_Stack_area_begin
======= m68k-uC5282-minimum.exe =====
17872 752 7200 25824 64e0 m68k-uC5282-minimum.exe
000421a4 000003d6 T __udivdi3
00041ba8 000003f4 T bsp_start
00044ce4 00000400 B _ISR_Vector_table
00042690 00000c52 T _IO_Vprintf
000454e0 00001000 B _ISR_Stack_area_begin
======= mips-csb350-minimum.exe =====
24428 284 11700 36412 8e3c mips-csb350-minimum.exe
80404810 0000041c T __umoddi3
80402be0 0000045c T __udivdi3
80406530 00000690 B bsp_interrupt_handler_table
804031b0 00000be8 T _IO_Vprintf
80406e40 00002000 B _ISR_Stack_area_begin
======= mips-hurricane-minimum.exe =====
30176 312 11028 41516 a22c mips-hurricane-minimum.exe
80030678 00000420 T _ISR_Handler
80032020 00000534 T __umoddi3
80031930 000005a8 T __udivdi3
80034cac 00000b9c T _IO_Vprintf
80038240 00002000 B _ISR_Stack_area_begin
======= mips-jmr3904-minimum.exe =====
26064 280 10960 37304 91b8 mips-jmr3904-minimum.exe
88001a94 0000041c T _Heap_Extend
88004c00 00000580 T __umoddi3
88002da0 000005c4 T __udivdi3
880034e0 00000c18 T _IO_Vprintf
880071c0 00002000 B _ISR_Stack_area_begin
======= mips-malta-minimum.exe =====
129820 1024 11872 142716 22d7c mips-malta-minimum.exe
8002bc14 000005d4 T rtems_termios_enqueue_raw_characters
80018938 00000788 t RBTree_Control_RB_REMOVE_COLOR
8001ed08 00000e88 T _IO_Vprintf
80030d80 00002000 B _ISR_Stack_area_begin
80032d80 00002000 B _ISR_Stack_area_end
======= mips-rbtx4925-minimum.exe =====
30240 312 11444 41996 a40c mips-rbtx4925-minimum.exe
80037d90 00000430 B bsp_interrupt_handler_table
80032140 00000534 T __umoddi3
80031a50 000005a8 T __udivdi3
80034cf4 00000b9c T _IO_Vprintf
80038420 00002000 B _ISR_Stack_area_begin
======= mips-rbtx4938-minimum.exe =====
29952 312 11412 41676 a2cc mips-rbtx4938-minimum.exe
80137c50 00000430 B bsp_interrupt_handler_table
80132020 00000534 T __umoddi3
80131930 000005a8 T __udivdi3
80134bd4 00000b9c T _IO_Vprintf
801382e0 00002000 B _ISR_Stack_area_begin
======= moxie-moxiesim-minimum.exe =====
16754 444 3228 20426 4fca moxie-moxiesim-minimum.exe
000028de 00000254 T _Heap_Extend
00001774 0000046a T __umoddi3
000012e6 0000048e T __udivdi3
00005ae0 00000600 B _ISR_Stack_area_begin
00002fea 000009a2 T _IO_Vprintf
======= nios2-nios2_iss-minimum.exe =====
54732 380 5848 60960 ee20 nios2-nios2_iss-minimum.exe
0000d14c 00000540 T __umoddi3
000089dc 00000588 T __udivdi3
00009568 00000df0 T _IO_Vprintf
0000ee40 00001000 B _ISR_Stack_area_begin
0000fe40 00001000 B _ISR_Stack_area_end
======= or1k-generic_or1k-minimum.exe =====
25106 504 33520536 33546146 1ffdfa2 or1k-generic_or1k-minimum.exe
000039f4 000003f0 T _Heap_Extend
00006844 000005d4 T __umoddi3
000043e8 000005f4 T __udivdi3
00004b10 00000ebc T _IO_Vprintf
00008b80 00001000 B _ISR_Stack_area_begin
======= powerpc-beatnik-minimum.exe =====
154493 23912 92876 271281 423b1 powerpc-beatnik-minimum.exe
00009954 00000bfc t setbat
000193dc 0000106c T _IO_Vprintf
0001f5fc 00001398 T _dtoa_r
0001c66c 000029c8 T _vfprintf_r
000412a0 00004000 B _ISR_Stack_area_begin
FOUND: close()
======= powerpc-br_uid-minimum.exe =====
61605 9724 268298560 268369889 ffeffe1 powerpc-br_uid-minimum.exe
00017770 000004f4 T rtems_termios_enqueue_raw_characters
00013e34 0000059c T _CPU_Exception_frame_print
00021bf8 00000810 B bsp_interrupt_handler_table
00018198 00001064 T _IO_Vprintf
00022780 00002000 B _ISR_Stack_area_begin
======= powerpc-gwlcfm-minimum.exe =====
56117 8572 605592 670281 a3a49 powerpc-gwlcfm-minimum.exe
00002b78 0000045c T _RBTree_Extract
00005118 000004c4 T _CPU_Exception_frame_print
0000b558 000004f4 T rtems_termios_enqueue_raw_characters
00006864 0000108c T _IO_Vprintf
20000d60 00002000 B _ISR_Stack_area_begin
======= powerpc-haleakala-minimum.exe =====
36420 468 78468 115356 1c29c powerpc-haleakala-minimum.exe
00008998 0000048c T C_dispatch_irq_handler
0000624c 00000498 T _CPU_Exception_frame_print
0001d54c 00000ab8 b rtemsIrq
00009518 00000f64 T _IO_Vprintf
0001e2c0 00002000 B _ISR_Stack_area_begin
======= powerpc-hsc_cm01-minimum.exe =====
62101 9844 268297920 268369865 ffeffc9 powerpc-hsc_cm01-minimum.exe
00013f34 0000059c T _CPU_Exception_frame_print
0002269c 000005c0 b mpc83xx_ipic_prio2mask
00021e78 00000810 B bsp_interrupt_handler_table
00018388 00001064 T _IO_Vprintf
00022fc0 00002000 B _ISR_Stack_area_begin
======= powerpc-icecube-minimum.exe =====
37920 25120 10976 74016 12120 powerpc-icecube-minimum.exe
00012668 000003d8 T get_ppc_cpu_type
000117ec 00000408 T _Heap_Extend
000134c8 0000059c T _CPU_Exception_frame_print
0001578c 00001064 T _IO_Vprintf
00020120 00002000 B _ISR_Stack_area_begin
======= powerpc-mcp750-minimum.exe =====
130977 24380 380496 535853 82d2d powerpc-mcp750-minimum.exe
0008aee0 00002000 B _ISR_Stack_area_begin
00016dc8 000029bc T _vfprintf_r
00086de0 00003000 b log_page_pool
00080050 00006a0c B residualCopy
00060000 00020000 b cc_memory
FOUND: close()
======= powerpc-mpc5566evb-minimum.exe =====
56121 8584 654776 719481 afa79 powerpc-mpc5566evb-minimum.exe
000141b8 000004c4 T _CPU_Exception_frame_print
0001a624 000004f4 T rtems_termios_enqueue_raw_characters
20000664 000007f0 B bsp_interrupt_handler_table
00015930 0000108c T _IO_Vprintf
200011c0 00002000 B _ISR_Stack_area_begin
======= powerpc-mpc5643l_evb-minimum.exe =====
56465 8820 130416 195701 2fc75 powerpc-mpc5643l_evb-minimum.exe
000140b8 000004c4 T _CPU_Exception_frame_print
0001a7d0 000004f4 T rtems_termios_enqueue_raw_characters
400008d8 000007f0 B bsp_interrupt_handler_table
00015a74 0000108c T _IO_Vprintf
40001420 00002000 B _ISR_Stack_area_begin
======= powerpc-mpc5668g-minimum.exe =====
54829 8468 261512 324809 4f4c9 powerpc-mpc5668g-minimum.exe
00011b78 0000045c T _RBTree_Extract
00013d18 000004c4 T _CPU_Exception_frame_print
0001a3b4 000004f4 T rtems_termios_enqueue_raw_characters
000156c0 0000108c T _IO_Vprintf
40001040 00002000 B _ISR_Stack_area_begin
======= powerpc-mpc5674fevb-minimum.exe =====
56361 8632 785808 850801 cfb71 powerpc-mpc5674fevb-minimum.exe
00014278 000004c4 T _CPU_Exception_frame_print
0001a6e0 000004f4 T rtems_termios_enqueue_raw_characters
40000998 00000ff0 B bsp_interrupt_handler_table
000159ec 0000108c T _IO_Vprintf
20000200 00002000 B _ISR_Stack_area_begin
======= powerpc-mpc8260ads-minimum.exe =====
35844 1620 142280 179744 2be20 powerpc-mpc8260ads-minimum.exe
00011230 00000408 T _Heap_Extend
000191b8 00000410 B bsp_interrupt_handler_table
00012344 0000059c T _CPU_Exception_frame_print
00014f5c 00001064 T _IO_Vprintf
00019e40 00002000 B _ISR_Stack_area_begin
======= powerpc-mpc8309som-minimum.exe =====
61769 9868 268298224 268369861 ffeffc5 powerpc-mpc8309som-minimum.exe
00013d94 0000059c T _CPU_Exception_frame_print
000225cc 000005c0 b mpc83xx_ipic_prio2mask
00021da8 00000810 B bsp_interrupt_handler_table
00018234 00001064 T _IO_Vprintf
00022ee0 00002000 B _ISR_Stack_area_begin
======= powerpc-mpc8313erdb-minimum.exe =====
61517 9764 134080880 134152161 7feffe1 powerpc-mpc8313erdb-minimum.exe
00017710 000004f4 T rtems_termios_enqueue_raw_characters
00013dd4 0000059c T _CPU_Exception_frame_print
00021c28 00000810 B bsp_interrupt_handler_table
00018138 00001064 T _IO_Vprintf
000227a0 00002000 B _ISR_Stack_area_begin
======= powerpc-mpc8349eamds-minimum.exe =====
62117 9868 268297872 268369857 ffeffc1 powerpc-mpc8349eamds-minimum.exe
00013ef4 0000059c T _CPU_Exception_frame_print
0002272c 000005c0 b mpc83xx_ipic_prio2mask
00021f08 00000810 B bsp_interrupt_handler_table
00018394 00001064 T _IO_Vprintf
00023040 00002000 B _ISR_Stack_area_begin
======= powerpc-mtx603e-minimum.exe =====
130673 24324 380496 535493 82bc5 powerpc-mtx603e-minimum.exe
00016d4c 00002988 T _vfprintf_r
FOUND: close()
======= powerpc-mvme2100-minimum.exe =====
124253 22916 380484 527653 80d25 powerpc-mvme2100-minimum.exe
0008aec0 00002000 B _ISR_Stack_area_begin
000156ec 00002988 T _vfprintf_r
FOUND: close()
======= powerpc-mvme2307-minimum.exe =====
131029 24240 380496 535765 82cd5 powerpc-mvme2307-minimum.exe
00016ea8 000029e8 T _vfprintf_r
FOUND: close()
======= powerpc-mvme3100-minimum.exe =====
168173 27216 25081 220470 35d36 powerpc-mvme3100-minimum.exe
00016174 0000107c T _IO_Vprintf
0001f9dc 0000171c T _dtoa_r
00019ea4 00002a50 T _svfprintf_r
0001c8fc 00002b18 T _vfprintf_r
00035a80 00004000 B _ISR_Stack_area_begin
FOUND: close()
======= powerpc-mvme5500-minimum.exe =====
121013 19128 93696 233837 3916d powerpc-mvme5500-minimum.exe
00036d54 00000de4 b rtemsIrq
000136a4 00001088 T _IO_Vprintf
00018ca4 00001398 T _dtoa_r
00015d14 000029c8 T _vfprintf_r
000386a0 00004000 B _ISR_Stack_area_begin
FOUND: close()
======= powerpc-pghplus-minimum.exe =====
40156 6312 134105692 134152160 7feffe0 powerpc-pghplus-minimum.exe
00011554 00000428 T _Heap_Extend
00012fac 000004cc T _CPU_Exception_frame_print
00017160 00000590 t two_way_long_needle
0001510c 0000106c T _IO_Vprintf
0001c060 00002000 B _ISR_Stack_area_begin
======= powerpc-phycore_mpc5554-minimum.exe =====
55857 8536 4259248 4323641 41f939 powerpc-phycore_mpc5554-minimum.exe
00014178 000004c4 T _CPU_Exception_frame_print
0001a5b4 000004f4 T rtems_termios_enqueue_raw_characters
000158c0 0000108c T _IO_Vprintf
21000d80 00002000 B _ISR_Stack_area_begin
======= powerpc-pm520_cr825-minimum.exe =====
38368 25216 11136 74720 123e0 powerpc-pm520_cr825-minimum.exe
0001591c 00001064 T _IO_Vprintf
000203e0 00002000 B _ISR_Stack_area_begin
======= powerpc-pm520_ze30-minimum.exe =====
38464 25216 11136 74816 12440 powerpc-pm520_ze30-minimum.exe
000126d0 000003d8 T get_ppc_cpu_type
00013528 0000059c T _CPU_Exception_frame_print
0001597c 00001064 T _IO_Vprintf
00020440 00002000 B _ISR_Stack_area_begin
======= powerpc-psim-minimum.exe =====
45076 5884 268384476 268435436 fffffec powerpc-psim-minimum.exe
000053ac 00000540 T openpic_init
00003024 0000059c T _CPU_Exception_frame_print
00003828 00000ba4 t setbat
0000773c 00001064 T _IO_Vprintf
0001d100 00002000 B _ISR_Stack_area_begin
======= powerpc-qemuppc-minimum.exe =====
36424 4892 4185616 4226932 407f74 powerpc-qemuppc-minimum.exe
ffc013cc 00000408 T _Heap_Extend
ffc02c90 00000414 T get_ppc_cpu_type
ffc02594 000005c8 T _CPU_Exception_frame_print
ffc05018 00001064 T _IO_Vprintf
00002a80 00002000 B _ISR_Stack_area_begin
======= powerpc-qemuprep-altivec-minimum.exe =====
126669 23060 379760 529489 81451 powerpc-qemuprep-altivec-minimum.exe
0008ac00 00002000 B _ISR_Stack_area_begin
00015ed0 000029c8 T _vfprintf_r
FOUND: close()
======= powerpc-qemuprep-minimum.exe =====
123765 22980 379760 526505 808a9 powerpc-qemuprep-minimum.exe
000154c0 000029bc T _vfprintf_r
FOUND: close()
======= powerpc-qoriq_core_0-minimum.exe =====
312340 8036 33277808 33598184 200aae8 powerpc-qoriq_core_0-minimum.exe
000082ec 000004c4 T _CPU_Exception_frame_print
02000784 00000680 B bsp_interrupt_handler_table
00009b78 0000108c T _IO_Vprintf
020010e0 00002000 B _ISR_Stack_area_begin
01000160 00040000 r bsp_fdt_blob
FOUND: bsp_fdt_blob
======= powerpc-qoriq_core_1-minimum.exe =====
312308 7964 66788536 67108808 3ffffc8 powerpc-qoriq_core_1-minimum.exe
040042ec 000004c4 T _CPU_Exception_frame_print
06000764 00000680 B bsp_interrupt_handler_table
04005b78 0000108c T _IO_Vprintf
060010c0 00002000 B _ISR_Stack_area_begin
05000160 00040000 r bsp_fdt_blob
FOUND: bsp_fdt_blob
======= powerpc-qoriq_e500-minimum.exe =====
312340 8036 519817056 520137432 1f00aad8 powerpc-qoriq_e500-minimum.exe
02010704 00000680 B bsp_interrupt_handler_table
02011060 00002000 B _ISR_Stack_area_begin
FOUND: bsp_fdt_blob
======= powerpc-qoriq_e6500_32-minimum.exe =====
316944 8060 519816888 520141892 1f00bc44 powerpc-qoriq_e6500_32-minimum.exe
00008e70 000006d4 T _CPU_Exception_frame_print
0000a940 000010f4 T _IO_Vprintf
05010884 00001280 B bsp_interrupt_handler_table
05011e00 00002000 B _ISR_Stack_area_begin
04000180 00040000 r bsp_fdt_blob
FOUND: bsp_fdt_blob
======= powerpc-qoriq_e6500_64-minimum.exe =====
331076 1304 519814736 520147116 1f00d0ac powerpc-qoriq_e6500_64-minimum.exe
0000000000009e10 0000000000000700 T _CPU_Exception_frame_print
000000000000b7f0 0000000000000ee4 T _IO_Vprintf
0000000005013600 0000000000002000 B _ISR_Stack_area_begin
0000000005010d68 0000000000002500 B bsp_interrupt_handler_table
0000000004000180 0000000000040000 r bsp_fdt_blob
FOUND: bsp_fdt_blob
======= powerpc-ss555-minimum.exe =====
33676 492 12112 46280 b4c8 powerpc-ss555-minimum.exe
00001478 00000404 T _Heap_Extend
000035c8 00000414 T get_ppc_cpu_type
000026bc 000005c8 T _CPU_Exception_frame_print
00004894 0000106c T _IO_Vprintf
003fa940 00002000 B _ISR_Stack_area_begin
======= powerpc-t32mppc-minimum.exe =====
36148 5036 134176492 134217676 7ffffcc powerpc-t32mppc-minimum.exe
00004ed4 000003b8 T __udivdi3
00004364 00000470 T _CPU_Exception_frame_print
000049d8 00000474 T get_ppc_cpu_type
00005580 00000be0 T _IO_Vprintf
0000a9a0 00002000 B _ISR_Stack_area_begin
======= powerpc-tqm8xx_stk8xx-minimum.exe =====
40156 6312 134105692 134152160 7feffe0 powerpc-tqm8xx_stk8xx-minimum.exe
======= powerpc-virtex4-minimum.exe =====
30673 548 18389 49610 c1ca powerpc-virtex4-minimum.exe
00004000 000003bc T __udivdi3
0000595c 00000404 T _Heap_Extend
000068e8 00000410 T get_ppc_cpu_type
00007e34 0000106c T _IO_Vprintf
0000b1e0 00004000 B _ISR_Stack_area_begin
======= powerpc-virtex5-minimum.exe =====
31073 548 18401 50022 c366 powerpc-virtex5-minimum.exe
00001300 000003bc T __udivdi3
00002cb8 00000408 T _Heap_Extend
00003c78 00000410 T get_ppc_cpu_type
000051c8 0000106c T _IO_Vprintf
00008580 00004000 B _ISR_Stack_area_begin
======= powerpc-virtex-minimum.exe =====
44072 5052 134168572 134217696 7ffffe0 powerpc-virtex-minimum.exe
00004974 000003d4 T get_ppc_cpu_type
00003494 00000404 T _Heap_Extend
000043e4 000004cc T _CPU_Exception_frame_print
00006ca4 0000107c T _IO_Vprintf
0000c7e0 00002000 B _ISR_Stack_area_begin
======= riscv-frdme310arty-minimum.exe =====
88509 452 268346424 268435385 fffffb9 riscv-frdme310arty-minimum.exe
80001a78 000003a4 T __udivdi3
800161d8 00000420 B bsp_interrupt_handler_table
80002bf6 00000704 T _IO_Vprintf
80016880 00001000 B _ISR_Stack_area_begin
80004940 00010000 r bsp_fdt_blob
FOUND: bsp_fdt_blob
======= riscv-griscv-minimum.exe =====
34340 388 16742468 16777196 ffffec riscv-griscv-minimum.exe
40008d80 00000420 B bsp_interrupt_handler_table
40006f6c 00000460 T __umoddi3
40003304 000004a0 T __udivdi3
40003c1c 00000a7c T _IO_Vprintf
40009400 00001000 B _ISR_Stack_area_begin
======= riscv-grv32imac-minimum.exe =====
24836 388 67083588 67108812 3ffffcc riscv-grv32imac-minimum.exe
80004ba2 0000038c T __umoddi3
800021d2 000003a4 T __udivdi3
80006840 00000420 B bsp_interrupt_handler_table
80002842 00000704 T _IO_Vprintf
80006ec0 00001000 B _ISR_Stack_area_begin
======= riscv-grv32imafdc-minimum.exe =====
25130 388 67083268 67108786 3ffffb2 riscv-grv32imafdc-minimum.exe
80004cb8 0000038c T __umoddi3
800022ce 000003a4 T __udivdi3
800069c0 00000420 B bsp_interrupt_handler_table
8000293e 000006ee T _IO_Vprintf
80007040 00001000 B _ISR_Stack_area_begin
======= riscv-grv32i-minimum.exe =====
36176 388 67072244 67108808 3ffffc8 riscv-grv32i-minimum.exe
80009470 00000420 B bsp_interrupt_handler_table
800074bc 000005d8 T __umoddi3
80003420 00000648 T __udivdi3
800040e8 00000ae4 T _IO_Vprintf
80009b00 00001000 B _ISR_Stack_area_begin
======= riscv-grv32im-minimum.exe =====
34048 388 67074356 67108792 3ffffb8 riscv-grv32im-minimum.exe
80008c30 00000420 B bsp_interrupt_handler_table
80006e58 00000460 T __umoddi3
800031a0 000004a0 T __udivdi3
80003ab8 00000ae4 T _IO_Vprintf
800092c0 00001000 B _ISR_Stack_area_begin
======= riscv-rv32iac-minimum.exe =====
90267 452 67018040 67108759 3ffff97 riscv-rv32iac-minimum.exe
80001a6c 0000044a T __udivdi3
800042da 0000044a T __umoddi3
80002d62 00000704 T _IO_Vprintf
80017000 00001000 B _ISR_Stack_area_begin
80004f80 00010000 r bsp_fdt_blob
FOUND: bsp_fdt_blob
======= riscv-rv32imac-minimum.exe =====
89279 452 67019064 67108795 3ffffbb riscv-rv32imac-minimum.exe
800019ee 000003a4 T __udivdi3
800164d8 00000420 B bsp_interrupt_handler_table
80002b3e 00000704 T _IO_Vprintf
80016c00 00001000 B _ISR_Stack_area_begin
80004c00 00010000 r bsp_fdt_blob
FOUND: bsp_fdt_blob
======= riscv-rv32imafc-minimum.exe =====
89561 452 67018808 67108821 3ffffd5 riscv-rv32imafc-minimum.exe
80001ade 000003a4 T __udivdi3
800165d8 00000420 B bsp_interrupt_handler_table
80002c2e 000006ee T _IO_Vprintf
80016d00 00001000 B _ISR_Stack_area_begin
80004d00 00010000 r bsp_fdt_blob
FOUND: bsp_fdt_blob
======= riscv-rv32imafdc-minimum.exe =====
89577 452 67018744 67108773 3ffffa5 riscv-rv32imafdc-minimum.exe
80001aee 000003a4 T __udivdi3
80016658 00000420 B bsp_interrupt_handler_table
80002c3e 000006ee T _IO_Vprintf
80016d80 00001000 B _ISR_Stack_area_begin
80004d40 00010000 r bsp_fdt_blob
FOUND: bsp_fdt_blob
======= riscv-rv32imafd-minimum.exe =====
98071 452 67010296 67108819 3ffffd3 riscv-rv32imafd-minimum.exe
80005ef0 00000460 T __umoddi3
800026cc 000004a0 T __udivdi3
800040ec 00000a7c T _IO_Vprintf
80018e80 00001000 B _ISR_Stack_area_begin
80006e40 00010000 r bsp_fdt_blob
FOUND: bsp_fdt_blob
======= riscv-rv32i-minimum.exe =====
99587 452 67008744 67108783 3ffffaf riscv-rv32i-minimum.exe
80006228 000005d8 T __umoddi3
80002668 00000648 T __udivdi3
800043a0 00000ae4 T _IO_Vprintf
80019440 00001000 B _ISR_Stack_area_begin
800073c0 00010000 r bsp_fdt_blob
FOUND: bsp_fdt_blob
======= riscv-rv32im-minimum.exe =====
97787 452 67010536 67108775 3ffffa7 riscv-rv32im-minimum.exe
80005de4 00000460 T __umoddi3
80002570 000004a0 T __udivdi3
80003f90 00000ae4 T _IO_Vprintf
80018d40 00001000 B _ISR_Stack_area_begin
80006d40 00010000 r bsp_fdt_blob
FOUND: bsp_fdt_blob
======= riscv-rv64imac_medany-minimum.exe =====
88647 760 67019328 67108735 3ffff7f riscv-rv64imac_medany-minimum.exe
0000000080016050 00000000000003d0 b _Thread_Objects
000000008000296e 0000000000000670 T _IO_Vprintf
00000000800167c8 0000000000000840 B bsp_interrupt_handler_table
0000000080017400 0000000000002000 B _ISR_Stack_area_begin
0000000080004700 0000000000010000 r bsp_fdt_blob
FOUND: bsp_fdt_blob
======= riscv-rv64imac-minimum.exe =====
88697 760 67019328 67108785 3ffffb1 riscv-rv64imac-minimum.exe
0000000070016050 00000000000003d0 b _Thread_Objects
0000000070002956 00000000000006aa T _IO_Vprintf
00000000700167c8 0000000000000840 B bsp_interrupt_handler_table
0000000070017400 0000000000002000 B _ISR_Stack_area_begin
0000000070004700 0000000000010000 r bsp_fdt_blob
FOUND: bsp_fdt_blob
======= riscv-rv64imafdc_medany-minimum.exe =====
88955 760 67019072 67108787 3ffffb3 riscv-rv64imafdc_medany-minimum.exe
0000000080016150 0000000000000438 b _Thread_Objects
0000000080002a5e 0000000000000670 T _IO_Vprintf
0000000080016908 0000000000000840 B bsp_interrupt_handler_table
0000000080017540 0000000000002000 B _ISR_Stack_area_begin
0000000080004800 0000000000010000 r bsp_fdt_blob
FOUND: bsp_fdt_blob
======= riscv-rv64imafdc-minimum.exe =====
88947 760 67019072 67108779 3ffffab riscv-rv64imafdc-minimum.exe
0000000070016150 0000000000000438 b _Thread_Objects
0000000070002a46 0000000000000670 T _IO_Vprintf
0000000070016908 0000000000000840 B bsp_interrupt_handler_table
0000000070017540 0000000000002000 B _ISR_Stack_area_begin
0000000070004800 0000000000010000 r bsp_fdt_blob
FOUND: bsp_fdt_blob
======= riscv-rv64imafd_medany-minimum.exe =====
96523 760 67011520 67108803 3ffffc3 riscv-rv64imafd_medany-minimum.exe
0000000080017ed0 0000000000000438 b _Thread_Objects
0000000080018688 0000000000000840 B bsp_interrupt_handler_table
0000000080003cfc 0000000000000960 T _IO_Vprintf
00000000800192c0 0000000000002000 B _ISR_Stack_area_begin
0000000080006580 0000000000010000 r bsp_fdt_blob
FOUND: bsp_fdt_blob
======= riscv-rv64imafd-minimum.exe =====
96547 760 67011456 67108763 3ffff9b riscv-rv64imafd-minimum.exe
0000000070017f10 0000000000000438 b _Thread_Objects
00000000700186c8 0000000000000840 B bsp_interrupt_handler_table
0000000070003ce0 0000000000000984 T _IO_Vprintf
0000000070019300 0000000000002000 B _ISR_Stack_area_begin
00000000700065c0 0000000000010000 r bsp_fdt_blob
FOUND: bsp_fdt_blob
======= sh-gensh1-minimum.exe =====
15266 282 5812 21360 5370 sh-gensh1-minimum.exe
0a04577c 000002a4 T ___udivdi3
0a046a54 0000030c T ___umoddi3
0a042000 00000400 T _vectab
0a045b38 000008a8 T __IO_Vprintf
0f000000 00001000 B __ISR_Stack_area_begin
======= sh-gensh2-minimum.exe =====
14866 282 5812 20960 51e0 sh-gensh2-minimum.exe
00444d40 00000250 T __Heap_Extend
00446930 000002b0 T ___umoddi3
00442000 00000400 T _vectab
00445a18 000008c4 T __IO_Vprintf
fffff000 00001000 B __ISR_Stack_area_begin
======= sh-gensh4-minimum.exe =====
15938 278 6092 22308 5724 sh-gensh4-minimum.exe
88100ffc 00000250 T __Heap_Extend
881044a0 00000288 B __Thread_Idle_stacks
881015f8 00000354 T ___sdivsi3_i4i
88101cec 00000a40 T __IO_Vprintf
88104730 00001000 B __ISR_Stack_area_begin
======= sh-simsh1-minimum.exe =====
15186 276 5812 21274 531a sh-simsh1-minimum.exe
000456bc 000002a4 T ___udivdi3
00046a5c 0000030c T ___umoddi3
00042000 00000400 T _vectab
00045b40 000008a8 T __IO_Vprintf
000483a0 00001000 B __ISR_Stack_area_begin
======= sh-simsh2e-minimum.exe =====
15282 276 5812 21370 537a sh-simsh2e-minimum.exe
00044d3c 00000250 T __Heap_Extend
00046b24 000002a8 T ___umoddi3
00045a60 00000a64 T __IO_Vprintf
00048400 00001000 B __ISR_Stack_area_begin
======= sh-simsh2-minimum.exe =====
14770 276 5812 20858 517a sh-simsh2-minimum.exe
00044d34 00000250 T __Heap_Extend
00046918 000002b0 T ___umoddi3
00045a00 000008c4 T __IO_Vprintf
00048200 00001000 B __ISR_Stack_area_begin
======= sh-simsh4-minimum.exe =====
16018 276 6100 22394 577a sh-simsh4-minimum.exe
00048570 00000288 B __Thread_Idle_stacks
0004560c 00000354 T ___sdivsi3_i4i
00045cfc 00000a40 T __IO_Vprintf
00048800 00001000 B __ISR_Stack_area_begin
======= sparc64-niagara-minimum.exe =====
20192 392 2110528 2131112 2084a8 sparc64-niagara-minimum.exe
00000000000058a0 0000000000000330 T _Heap_Extend
0000000000009120 0000000000000460 b _Thread_Objects
00000000000099c8 0000000000000830 b bootinfo
0000000000007160 0000000000000a34 T _IO_Vprintf
000000000000a4c0 0000000000002000 B _ISR_Stack_area_begin
======= sparc64-usiii-minimum.exe =====
61568 400 2110528 2172496 212650 sparc64-usiii-minimum.exe
0000000000005a40 000000000000033c T _Heap_Extend
00000000000132c0 0000000000000460 b _Thread_Objects
0000000000013b68 0000000000000830 b bootinfo
0000000000010520 0000000000000a34 T _IO_Vprintf
0000000000014660 0000000000002000 B _ISR_Stack_area_begin
======= sparc-at697f-minimum.exe =====
26640 256 7248 34144 8560 sparc-at697f-minimum.exe
40007ba8 00000298 b _Thread_Objects
40002c60 00000394 T _Heap_Extend
40008010 00000400 B _ISR_Vector_table
40003dd4 00000bb0 T _IO_Vprintf
40006a40 00001000 B _ISR_Stack_area_begin
======= sparc-erc32-minimum.exe =====
29392 256 7248 36896 9020 sparc-erc32-minimum.exe
02002c38 0000036c T _Heap_Extend
02005d24 00000370 T __umoddi3
02008ad0 00000400 B _ISR_Vector_table
02004638 00000bac T _IO_Vprintf
02007500 00001000 B _ISR_Stack_area_begin
======= sparc-gr712rc-minimum.exe =====
37920 304 7664 45888 b340 sparc-gr712rc-minimum.exe
4000ac50 00000400 B _ISR_Vector_table
400047b4 00000424 t ambapp_scan2
40003a50 000004ec T _RBTree_Extract
40005950 00000be4 T _IO_Vprintf
40009640 00001000 B _ISR_Stack_area_begin
======= sparc-gr740-minimum.exe =====
36304 304 7664 44272 acf0 sparc-gr740-minimum.exe
0000447c 000003f4 t ambapp_scan2
0000a610 00000400 B _ISR_Vector_table
000037c0 00000478 T _RBTree_Extract
000055b8 00000bb0 T _IO_Vprintf
00009000 00001000 B _ISR_Stack_area_begin
======= sparc-leon2-minimum.exe =====
26640 256 7248 34144 8560 sparc-leon2-minimum.exe
======= sparc-leon3-minimum.exe =====
36304 304 7664 44272 acf0 sparc-leon3-minimum.exe
4000447c 000003f4 t ambapp_scan2
4000a610 00000400 B _ISR_Vector_table
400037c0 00000478 T _RBTree_Extract
400055b8 00000bb0 T _IO_Vprintf
40009000 00001000 B _ISR_Stack_area_begin
======= sparc-ut699-minimum.exe =====
38288 304 7664 46256 b4b0 sparc-ut699-minimum.exe
4000add0 00000400 B _ISR_Vector_table
40004858 00000420 t ambapp_scan2
40003ad4 00000514 T _RBTree_Extract
400059ec 00000c08 T _IO_Vprintf
400097c0 00001000 B _ISR_Stack_area_begin
======= sparc-ut700-minimum.exe =====
37920 304 7664 45888 b340 sparc-ut700-minimum.exe
======= v850-v850e1sim-minimum.exe =====
18110 244 5748 24102 5e26 v850-v850e1sim-minimum.exe
00101aee 00000350 T __Heap_Extend
00100924 000003d2 T ___umoddi3
001004be 000003f8 T ___udivdi3
00102528 00000c16 T __IO_Vprintf
00104e40 00001000 B __ISR_Stack_area_begin
======= v850-v850e2sim-minimum.exe =====
23119 644 6172 29935 74ef v850-v850e2sim-minimum.exe
00101afa 00000384 T __RBTree_Extract
00100660 000003d6 T ___umoddi3
0010022c 000003fc T ___udivdi3
0010235c 00000b56 T __IO_Vprintf
00106500 00001000 B __ISR_Stack_area_begin
======= v850-v850e2v3sim-minimum.exe =====
23115 644 6172 29931 74eb v850-v850e2v3sim-minimum.exe
00101af8 00000382 T __RBTree_Extract
00100660 000003d4 T ___umoddi3
00102358 00000b56 T __IO_Vprintf
======= v850-v850esim-minimum.exe =====
22989 644 6172 29805 746d v850-v850esim-minimum.exe
00101aa8 00000384 T __RBTree_Extract
0010065c 000003d2 T ___umoddi3
0010022c 000003f8 T ___udivdi3
00102308 00000b34 T __IO_Vprintf
00106480 00001000 B __ISR_Stack_area_begin
======= v850-v850essim-minimum.exe =====
18110 244 5748 24102 5e26 v850-v850essim-minimum.exe
======= v850-v850sim-minimum.exe =====
19172 244 5748 25164 624c v850-v850sim-minimum.exe
00101f0e 00000350 T __Heap_Extend
00100b3c 000005da T ___umoddi3
0010048e 00000640 T ___udivdi3
00102948 00000c16 T __IO_Vprintf
00105260 00001000 B __ISR_Stack_area_begin
======= x86_64-amd64-minimum.exe =====
24866 912 22368 48146 bc12 x86_64-amd64-minimum.exe
0000000000102580 0000000000000dfb T _IO_Vprintf
000000000030a480 0000000000001000 B amd64_idt
0000000000308000 0000000000001000 B amd64_pdpt
0000000000309000 0000000000001000 B amd64_pml4
000000000070b780 0000000000001000 B _ISR_Stack_area_begin
