Minimum.exe Text Size Outliers
Christian Mauderer oss at c-mauderer.de
Tue May 25 18:33:53 UTC 2021
Hello Joel,
On 25/05/2021 19:10, Joel Sherrill wrote:
> Thanks for the feedback. I did save all of the minimum.exe files as
> @CPU at -@BSP at -minimum.exe so they could be analysed. For exe, I did a
> size, the tail -5,  and also looked for some symbols that are hints of
> dependency chains to things not needed. close(), atexit(), and
> rtems_libio_post_driver() being the ones I know of now. I also did a
> similar check for the bsp_fdt_blob since that does indicate a large area
> is being reserved.
> I agree that bsp_fdt_blob() is in "r" memory and being included in the
> text report. Not sure if that's right since you are implying it is
> copied into so I would have expected BSS.
Depends on the BSP: Some have it read only. Some have it read write. For
the BSPs that have it read only it can still be correct. Take Beagle or
i.MX7 as an example: These BSPs expect the following boot:
- U-Boot runs
- U-Boot reads the application from some storage like eMMC and loads it
into memory at the right location.
- U-Boot reads the FDT blob from some storage and loads it into the
memory somewhere without knowing where it should be.
- U-Boot puts the location of the FDT into one register and then starts
the RTEMS application.
- RTEMS does _very_ few basic initialization. Then it reads the register
and copies the FDT to wherever it expects it. I think it's even done
before other segments (like BSS) would be initialized. It's certainly
done before MMU is set up.
- The FDT is never changed after that.
So for BSPs that only run from RAM putting FDT into a "read only"
section is completely OK. It's not OK for BSPs that might run from real
read only storage like flash. If such a BSP would use that method, it
would be a bug.
> I thought Sebastian added a "malloc" for the BSP to use before the heap
> was initialized. But I don't remember the name. Am I remembering correctly?
I don't really know that malloc. But I doubt that it works that early.
Again: Copying the FDT is one of the first things that these BSPs do. If
you want to know the exact location: For ARM it's here:
https://git.rtems.org/rtems/tree/bsps/arm/shared/start/start.S#n325
So it's really basic setup before that. It's interrupt stack, switching
modes, setup stack pointer and then it's already copy FDT.
> It is promising that 24 of the BSPs do have the FDT blob. Getting that
> out of the .text section report would possibly drop about half of the
> BSPs' minimum below 64k. Plus I expect some like pc386 and
> motorola_powerpc are > 64k for good reasons not worth investigating.
Which of the BSPs are left on the list if you cross out the ones with
the FDT blob?
Best regards
Christian
> --joel
> On Tue, May 25, 2021 at 10:13 AM Christian MAUDERER
> <christian.mauderer at embedded-brains.de
> <mailto:christian.mauderer at embedded-brains.de>> wrote:
>     Hello Joel,
>     I think we currently have very few BSPs with a linked in device tree
>     blob. I know only of the new imxrt (which isn't in your list) and I
>     think one Xilinx something BSP.
>     For imx: I only have a build for some minimum based on 5 at hand right
>     now. I have to re-build an up to date version to double check that. For
>     this BSP there is 0x000069bc text size and 0x00040ebc rodata. So the
>     rodata is the odd part.
>     nm -S --size-sort
>     ./build/b-imx7/arm-rtems5/c/imx7/testsuites/samples/minimum.exe |
>     tail -5
>     gives a
>     80205e40 000004e0 T memcpy
>     80203a00 0000078c T _IO_Vprintf
>     80300c2c 00000a00 B bsp_interrupt_handler_table
>     80301ac0 00001000 B _ISR_Stack_area_begin
>     80207080 00040000 r bsp_fdt_blob
>     So yes: For some reason there is a big bsp_fdt_blob there even if none
>     should be linked in. I had a look at that variable:
>     https://git.rtems.org/rtems/tree/bsps/shared/start/bsp-fdt.c
>     <https://git.rtems.org/rtems/tree/bsps/shared/start/bsp-fdt.c>
>     U-Boot passes a FDT blob and the BSP copies it into that area that is
>     reserved with a fixed size. Seems reasonable because we can't easily
>     allocate memory when we copy the FDT. It's done during initialization
>     and therefore there is no heap yet.
>     If you still have the binaries: Maybe you can call the nm command like
>     above for the other BSPs too so we can see what the biggest objects are?
>     Best regards
>     Christian
>     Am 24.05.21 um 15:00 schrieb Joel Sherrill:
>      > Hi
>      > I built all 187 BSPs overnight and saved minimum.exe. Although I
>     think
>      > 64K is still too much code, I am using that as an initial cutoff
>     when
>      > asking for some help in identifying why minimum.exe is surprisingly
>      > large for some BSPs. 146 stayed under 64k which leaves 41 needing
>     some
>      > investigation or explanation.  I suspect some might have a device
>     tree
>      > blob linked in. The surprising ones are the riscv, stmh7, beagle,
>     and qoriq.
>      > Here is the list:
>      >   73680     504 34135552        34209736        209ffc8
>      > minimum-exes/arm-nucleo-h743zi-minimum.exe
>      > minimum-exes/arm-stm32h7-minimum.exe
>      >    88509     452 268346424       268435385       fffffb9
>      > minimum-exes/riscv-frdme310arty-minimum.exe
>      >    88647     760 67019328        67108735        3ffff7f
>      > minimum-exes/riscv-rv64imac_medany-minimum.exe
>      >    88697     760 67019328        67108785        3ffffb1
>      > minimum-exes/riscv-rv64imac-minimum.exe
>      >    88947     760 67019072        67108779        3ffffab
>      > minimum-exes/riscv-rv64imafdc-minimum.exe
>      >    88955     760 67019072        67108787        3ffffb3
>      > minimum-exes/riscv-rv64imafdc_medany-minimum.exe
>      >    89279     452 67019064        67108795        3ffffbb
>      > minimum-exes/riscv-rv32imac-minimum.exe
>      >    89561     452 67018808        67108821        3ffffd5
>      > minimum-exes/riscv-rv32imafc-minimum.exe
>      >    89577     452 67018744        67108773        3ffffa5
>      > minimum-exes/riscv-rv32imafdc-minimum.exe
>      >    90267     452 67018040        67108759        3ffff97
>      > minimum-exes/riscv-rv32iac-minimum.exe
>      >    96523     760 67011520        67108803        3ffffc3
>      > minimum-exes/riscv-rv64imafd_medany-minimum.exe
>      >    96547     760 67011456        67108763        3ffff9b
>      > minimum-exes/riscv-rv64imafd-minimum.exe
>      >    97787     452 67010536        67108775        3ffffa7
>      > minimum-exes/riscv-rv32im-minimum.exe
>      >    98071     452 67010296        67108819        3ffffd3
>      > minimum-exes/riscv-rv32imafd-minimum.exe
>      >    99587     452 67008744        67108783        3ffffaf
>      > minimum-exes/riscv-rv32i-minimum.exe
>      >   100328    9148   24320  133796   20aa4
>     minimum-exes/i386-pc386-minimum.exe
>      >   103344    9436   24256  137036   2174c
>     minimum-exes/i386-pcp4-minimum.exe
>      >   108836    9148   24320  142304   22be0
>     minimum-exes/i386-pc486-minimum.exe
>      >   111956    9148   24320  145424   23810
>     minimum-exes/i386-pc586-minimum.exe
>      >   112148    9372   24256  145776   23970
>      > minimum-exes/i386-pc586-sse-minimum.exe
>      >   114612    9148   24320  148080   24270
>     minimum-exes/i386-pc686-minimum.exe
>      >   121013   19128   93696  233837   3916d
>      > minimum-exes/powerpc-mvme5500-minimum.exe
>      >   123765   22980  379760  526505   808a9
>      > minimum-exes/powerpc-qemuprep-minimum.exe
>      >   124253   22916  380484  527653   80d25
>      > minimum-exes/powerpc-mvme2100-minimum.exe
>      >   126669   23060  379760  529489   81451
>      > minimum-exes/powerpc-qemuprep-altivec-minimum.exe
>      >   129820    1024   11872  142716   22d7c
>     minimum-exes/mips-malta-minimum.exe
>      >   130673   24324  380496  535493   82bc5
>      > minimum-exes/powerpc-mtx603e-minimum.exe
>      >   130977   24380  380496  535853   82d2d
>      > minimum-exes/powerpc-mcp750-minimum.exe
>      >   131029   24240  380496  535765   82cd5
>      > minimum-exes/powerpc-mvme2307-minimum.exe
>      >   154493   23912   92876  271281   423b1
>      > minimum-exes/powerpc-beatnik-minimum.exe
>      >   168173   27216   25081  220470   35d36
>      > minimum-exes/powerpc-mvme3100-minimum.exe
>      >   289136     424 535532700       535822260       1fefffb4
>      >   minimum-exes/arm-imx7-minimum.exe
>      >   312308    7964 66788536        67108808        3ffffc8
>      > minimum-exes/powerpc-qoriq_core_1-minimum.exe
>      >   312340    8036 33277808        33598184        200aae8
>      > minimum-exes/powerpc-qoriq_core_0-minimum.exe
>      >   312340    8036 519817056       520137432       1f00aad8
>      >   minimum-exes/powerpc-qoriq_e500-minimum.exe
>      >   316944    8060 519816888       520141892       1f00bc44
>      >   minimum-exes/powerpc-qoriq_e6500_32-minimum.exe
>      >   331076    1304 519814736       520147116       1f00d0ac
>      >   minimum-exes/powerpc-qoriq_e6500_64-minimum.exe
>      > Help in reducing and/or explaining is appreciated.
>      > --joel
>      > _______________________________________________
>      > devel mailing list
>      > devel at rtems.org <mailto:devel at rtems.org>
>      > http://lists.rtems.org/mailman/listinfo/devel
>     <http://lists.rtems.org/mailman/listinfo/devel>
>     embedded brains GmbH
>     Herr Christian MAUDERER
>     Dornierstr. 4
>     82178 Puchheim
>     Germany
>     email: christian.mauderer at embedded-brains.de
>     phone: +49-89-18 94 741 - 18
>     fax:   +49-89-18 94 741 - 08
>     Registergericht: Amtsgericht München
>     Registernummer: HRB 157899
>     Vertretungsberechtigte Geschäftsführer: Peter Rasmussen, Thomas Dörfler
>     Unsere Datenschutzerklärung finden Sie hier:
>     https://embedded-brains.de/datenschutzerklaerung/
>     <https://embedded-brains.de/datenschutzerklaerung/>
> devel mailing list
> devel at rtems.org
