Minimum.exe Text Size Outliers
Christian Mauderer
oss at c-mauderer.de
Tue May 25 18:57:50 UTC 2021
Hello Joel,
missed the attachement. So if we leave out the ones with bsp_fdt_blob
and the ones that you marked with "FOUND close()" that leaves the
following ones (if I didn't miss any):
======= arm-nucleo-h743zi-minimum.exe =====
======= arm-stm32h7-minimum.exe =====
======= i386-pc386-minimum.exe =====
======= i386-pc486-minimum.exe =====
======= i386-pc586-minimum.exe =====
======= i386-pc586-sse-minimum.exe =====
======= i386-pc686-minimum.exe =====
======= i386-pcp4-minimum.exe =====
======= mips-malta-minimum.exe =====
Already a quite short list where it's unclear why they are so big.
I assume the ones with close() need some work. But at least it's already
at least a trace why they are so big.
Best regards
Christian
On 25/05/2021 20:33, Christian Mauderer wrote:
> Hello Joel,
> On 25/05/2021 19:10, Joel Sherrill wrote:
>> Thanks for the feedback. I did save all of the minimum.exe files as
>> @CPU at -@BSP at -minimum.exe so they could be analysed. For exe, I did a
>> size, the tail -5, and also looked for some symbols that are hints of
>> dependency chains to things not needed. close(), atexit(), and
>> rtems_libio_post_driver() being the ones I know of now. I also did a
>> similar check for the bsp_fdt_blob since that does indicate a large
>> area is being reserved.
>> I agree that bsp_fdt_blob() is in "r" memory and being included in the
>> text report. Not sure if that's right since you are implying it is
>> copied into so I would have expected BSS.
> Depends on the BSP: Some have it read only. Some have it read write. For
> the BSPs that have it read only it can still be correct. Take Beagle or
> i.MX7 as an example: These BSPs expect the following boot:
> - U-Boot runs
> - U-Boot reads the application from some storage like eMMC and loads it
> into memory at the right location.
> - U-Boot reads the FDT blob from some storage and loads it into the
> memory somewhere without knowing where it should be.
> - U-Boot puts the location of the FDT into one register and then starts
> the RTEMS application.
> - RTEMS does _very_ few basic initialization. Then it reads the register
> and copies the FDT to wherever it expects it. I think it's even done
> before other segments (like BSS) would be initialized. It's certainly
> done before MMU is set up.
> - The FDT is never changed after that.
> So for BSPs that only run from RAM putting FDT into a "read only"
> section is completely OK. It's not OK for BSPs that might run from real
> read only storage like flash. If such a BSP would use that method, it
> would be a bug.
>> I thought Sebastian added a "malloc" for the BSP to use before the
>> heap was initialized. But I don't remember the name. Am I remembering
>> correctly?
> I don't really know that malloc. But I doubt that it works that early.
> Again: Copying the FDT is one of the first things that these BSPs do. If
> you want to know the exact location: For ARM it's here:
> https://git.rtems.org/rtems/tree/bsps/arm/shared/start/start.S#n325
> So it's really basic setup before that. It's interrupt stack, switching
> modes, setup stack pointer and then it's already copy FDT.
>> It is promising that 24 of the BSPs do have the FDT blob. Getting that
>> out of the .text section report would possibly drop about half of the
>> BSPs' minimum below 64k. Plus I expect some like pc386 and
>> motorola_powerpc are > 64k for good reasons not worth investigating.
> Which of the BSPs are left on the list if you cross out the ones with
> the FDT blob?
> Best regards
> Christian
>> --joel
>> On Tue, May 25, 2021 at 10:13 AM Christian MAUDERER
>> <christian.mauderer at embedded-brains.de
>> <mailto:christian.mauderer at embedded-brains.de>> wrote:
>> Hello Joel,
>> I think we currently have very few BSPs with a linked in device tree
>> blob. I know only of the new imxrt (which isn't in your list) and I
>> think one Xilinx something BSP.
>> For imx: I only have a build for some minimum based on 5 at hand
>> right
>> now. I have to re-build an up to date version to double check
>> that. For
>> this BSP there is 0x000069bc text size and 0x00040ebc rodata. So the
>> rodata is the odd part.
>> nm -S --size-sort
>> ./build/b-imx7/arm-rtems5/c/imx7/testsuites/samples/minimum.exe |
>> tail -5
>> gives a
>> 80205e40 000004e0 T memcpy
>> 80203a00 0000078c T _IO_Vprintf
>> 80300c2c 00000a00 B bsp_interrupt_handler_table
>> 80301ac0 00001000 B _ISR_Stack_area_begin
>> 80207080 00040000 r bsp_fdt_blob
>> So yes: For some reason there is a big bsp_fdt_blob there even if
>> none
>> should be linked in. I had a look at that variable:
>> https://git.rtems.org/rtems/tree/bsps/shared/start/bsp-fdt.c
>> <https://git.rtems.org/rtems/tree/bsps/shared/start/bsp-fdt.c>
>> U-Boot passes a FDT blob and the BSP copies it into that area that is
>> reserved with a fixed size. Seems reasonable because we can't easily
>> allocate memory when we copy the FDT. It's done during initialization
>> and therefore there is no heap yet.
>> If you still have the binaries: Maybe you can call the nm command
>> like
>> above for the other BSPs too so we can see what the biggest
>> objects are?
>> Best regards
>> Christian
>> Am 24.05.21 um 15:00 schrieb Joel Sherrill:
>> > Hi
>> > I built all 187 BSPs overnight and saved minimum.exe. Although I
>> think
>> > 64K is still too much code, I am using that as an initial cutoff
>> when
>> > asking for some help in identifying why minimum.exe is
>> surprisingly
>> > large for some BSPs. 146 stayed under 64k which leaves 41 needing
>> some
>> > investigation or explanation. I suspect some might have a device
>> tree
>> > blob linked in. The surprising ones are the riscv, stmh7, beagle,
>> and qoriq.
>> > Here is the list:
>> > 73680 504 34135552 34209736 209ffc8
>> > minimum-exes/arm-nucleo-h743zi-minimum.exe
>> > minimum-exes/arm-stm32h7-minimum.exe
>> > 88509 452 268346424 268435385 fffffb9
>> > minimum-exes/riscv-frdme310arty-minimum.exe
>> > 88647 760 67019328 67108735 3ffff7f
>> > minimum-exes/riscv-rv64imac_medany-minimum.exe
>> > 88697 760 67019328 67108785 3ffffb1
>> > minimum-exes/riscv-rv64imac-minimum.exe
>> > 88947 760 67019072 67108779 3ffffab
>> > minimum-exes/riscv-rv64imafdc-minimum.exe
>> > 88955 760 67019072 67108787 3ffffb3
>> > minimum-exes/riscv-rv64imafdc_medany-minimum.exe
>> > 89279 452 67019064 67108795 3ffffbb
>> > minimum-exes/riscv-rv32imac-minimum.exe
>> > 89561 452 67018808 67108821 3ffffd5
>> > minimum-exes/riscv-rv32imafc-minimum.exe
>> > 89577 452 67018744 67108773 3ffffa5
>> > minimum-exes/riscv-rv32imafdc-minimum.exe
>> > 90267 452 67018040 67108759 3ffff97
>> > minimum-exes/riscv-rv32iac-minimum.exe
>> > 96523 760 67011520 67108803 3ffffc3
>> > minimum-exes/riscv-rv64imafd_medany-minimum.exe
>> > 96547 760 67011456 67108763 3ffff9b
>> > minimum-exes/riscv-rv64imafd-minimum.exe
>> > 97787 452 67010536 67108775 3ffffa7
>> > minimum-exes/riscv-rv32im-minimum.exe
>> > 98071 452 67010296 67108819 3ffffd3
>> > minimum-exes/riscv-rv32imafd-minimum.exe
>> > 99587 452 67008744 67108783 3ffffaf
>> > minimum-exes/riscv-rv32i-minimum.exe
>> > 100328 9148 24320 133796 20aa4
>> minimum-exes/i386-pc386-minimum.exe
>> > 103344 9436 24256 137036 2174c
>> minimum-exes/i386-pcp4-minimum.exe
>> > 108836 9148 24320 142304 22be0
>> minimum-exes/i386-pc486-minimum.exe
>> > 111956 9148 24320 145424 23810
>> minimum-exes/i386-pc586-minimum.exe
>> > 112148 9372 24256 145776 23970
>> > minimum-exes/i386-pc586-sse-minimum.exe
>> > 114612 9148 24320 148080 24270
>> minimum-exes/i386-pc686-minimum.exe
>> > 121013 19128 93696 233837 3916d
>> > minimum-exes/powerpc-mvme5500-minimum.exe
>> > 123765 22980 379760 526505 808a9
>> > minimum-exes/powerpc-qemuprep-minimum.exe
>> > 124253 22916 380484 527653 80d25
>> > minimum-exes/powerpc-mvme2100-minimum.exe
>> > 126669 23060 379760 529489 81451
>> > minimum-exes/powerpc-qemuprep-altivec-minimum.exe
>> > 129820 1024 11872 142716 22d7c
>> minimum-exes/mips-malta-minimum.exe
>> > 130673 24324 380496 535493 82bc5
>> > minimum-exes/powerpc-mtx603e-minimum.exe
>> > 130977 24380 380496 535853 82d2d
>> > minimum-exes/powerpc-mcp750-minimum.exe
>> > 131029 24240 380496 535765 82cd5
>> > minimum-exes/powerpc-mvme2307-minimum.exe
>> > 154493 23912 92876 271281 423b1
>> > minimum-exes/powerpc-beatnik-minimum.exe
>> > 168173 27216 25081 220470 35d36
>> > minimum-exes/powerpc-mvme3100-minimum.exe
>> > 289136 424 535532700 535822260 1fefffb4
>> > minimum-exes/arm-imx7-minimum.exe
>> > 312308 7964 66788536 67108808 3ffffc8
>> > minimum-exes/powerpc-qoriq_core_1-minimum.exe
>> > 312340 8036 33277808 33598184 200aae8
>> > minimum-exes/powerpc-qoriq_core_0-minimum.exe
>> > 312340 8036 519817056 520137432 1f00aad8
>> > minimum-exes/powerpc-qoriq_e500-minimum.exe
>> > 316944 8060 519816888 520141892 1f00bc44
>> > minimum-exes/powerpc-qoriq_e6500_32-minimum.exe
>> > 331076 1304 519814736 520147116 1f00d0ac
>> > minimum-exes/powerpc-qoriq_e6500_64-minimum.exe
>> > Help in reducing and/or explaining is appreciated.
>> > --joel
>> > _______________________________________________
>> > devel mailing list
>> > devel at rtems.org <mailto:devel at rtems.org>
>> > http://lists.rtems.org/mailman/listinfo/devel
>> <http://lists.rtems.org/mailman/listinfo/devel>
>> embedded brains GmbH
>> Herr Christian MAUDERER
>> Dornierstr. 4
>> 82178 Puchheim
>> Germany
>> email: christian.mauderer at embedded-brains.de
>> phone: +49-89-18 94 741 - 18
>> fax: +49-89-18 94 741 - 08
>> Registergericht: Amtsgericht München
>> Registernummer: HRB 157899
>> Vertretungsberechtigte Geschäftsführer: Peter Rasmussen, Thomas
>> Dörfler
>> Unsere Datenschutzerklärung finden Sie hier:
>> https://embedded-brains.de/datenschutzerklaerung/
>> <https://embedded-brains.de/datenschutzerklaerung/>
>> devel mailing list
>> devel at rtems.org
> devel mailing list
> devel at rtems.org
