[PATCH rtems] i2c: Add non blocking read / write
Christian Mauderer christian.mauderer at embedded-brains.de
Wed May 26 14:39:47 UTC 2021
This adds the possibility to open an I2C bus with O_NONBLOCK (or set it
later via fcntl) to get non-blocking transmissions. This means that if
the bus is busy, a read, write or transfer ioctl will return with a
EAGAIN errno.
NOTE: This patch needs
https://lists.rtems.org/pipermail/devel/2021-May/067462.html applied too.
 cpukit/dev/i2c/i2c-bus.c         |  45 ++++++++++--
 cpukit/include/dev/i2c/i2c.h     |  44 ++++++++++-
 testsuites/libtests/i2c01/init.c | 121 ++++++++++++++++++++++++++++++-
 3 files changed, 203 insertions(+), 7 deletions(-)
diff --git a/cpukit/dev/i2c/i2c-bus.c b/cpukit/dev/i2c/i2c-bus.c
index 472222c4ab..618a817b1a 100644
--- a/cpukit/dev/i2c/i2c-bus.c
+++ b/cpukit/dev/i2c/i2c-bus.c
@@ -31,6 +31,11 @@
+int i2c_bus_try_obtain(i2c_bus *bus)
+  return rtems_recursive_mutex_try_lock(&bus->mutex);
 void i2c_bus_obtain(i2c_bus *bus)
   rtems_recursive_mutex_lock(&bus->mutex);
@@ -41,7 +46,12 @@ void i2c_bus_release(i2c_bus *bus)
   rtems_recursive_mutex_unlock(&bus->mutex);
-int i2c_bus_transfer(i2c_bus *bus, i2c_msg *msgs, uint32_t msg_count)
+int i2c_bus_do_transfer(
+  i2c_bus *bus,
+  i2c_msg *msgs,
+  uint32_t msg_count,
+  uint32_t flags
   int err;
   uint32_t i;
@@ -63,13 +73,24 @@ int i2c_bus_transfer(i2c_bus *bus, i2c_msg *msgs, uint32_t msg_count)
-  i2c_bus_obtain(bus);
+  if ((flags & I2C_BUS_NOBLOCK) != 0) {
+    if (i2c_bus_try_obtain(bus) != 0) {
+      return -EAGAIN;
+  } else {
+    i2c_bus_obtain(bus);
   err = (*bus->transfer)(bus, msgs, msg_count);
   i2c_bus_release(bus);
   return err;
+int i2c_bus_transfer(i2c_bus *bus, i2c_msg *msgs, uint32_t msg_count)
+  return i2c_bus_do_transfer(bus, msgs, msg_count, 0);
 static ssize_t i2c_bus_read(
   rtems_libio_t *iop,
   void *buffer,
@@ -84,12 +105,17 @@ static ssize_t i2c_bus_read(
     .buf = buffer
   int err;
+  unsigned flags = 0;
   if (bus->ten_bit_address) {
     msg.flags |= I2C_M_TEN;
-  err = i2c_bus_transfer(bus, &msg, 1);
+  if (rtems_libio_iop_is_no_delay(iop)) {
+    flags |= I2C_BUS_NOBLOCK;
+  err = i2c_bus_do_transfer(bus, &msg, 1, flags);
   if (err == 0) {
     return msg.len;
   } else {
@@ -111,12 +137,17 @@ static ssize_t i2c_bus_write(
     .buf = RTEMS_DECONST(void *, buffer)
   int err;
   if (err == 0) {
     return msg.len;
   } else {
@@ -133,12 +164,16 @@ static int i2c_bus_ioctl(
   i2c_bus *bus = IMFS_generic_get_context_by_iop(iop);
   i2c_rdwr_ioctl_data *rdwr;
   int err;
   switch (command) {
     case I2C_RDWR:
       rdwr = arg;
       if (rdwr->nmsgs > 0) {
-        err = i2c_bus_transfer(bus, rdwr->msgs, rdwr->nmsgs);
+        err = i2c_bus_do_transfer(bus, rdwr->msgs, rdwr->nmsgs, flags);
       } else {
         err = 0;
diff --git a/cpukit/include/dev/i2c/i2c.h b/cpukit/include/dev/i2c/i2c.h
index ac2c369785..5aa45e390c 100644
--- a/cpukit/include/dev/i2c/i2c.h
+++ b/cpukit/include/dev/i2c/i2c.h
@@ -242,6 +242,16 @@ int i2c_bus_register(
   const char *bus_path
+ * @brief Try to obtain the bus.
+ * @param[in] bus The bus control.
+ * @retval 0 Successful operation.
+ * @retval EBUSY if mutex is already locked.
+int i2c_bus_try_obtain(i2c_bus *bus);
  * @brief Obtains the bus.
@@ -259,7 +269,8 @@ void i2c_bus_release(i2c_bus *bus);
  * @brief Transfers I2C messages.
- * The bus is obtained before the transfer and released afterwards.
+ * The bus is obtained before the transfer and released afterwards. This is the
+ * same like calling @ref i2c_bus_do_transfer with flags set to 0.
  * @param[in] msgs The messages to transfer.
@@ -271,6 +282,37 @@ void i2c_bus_release(i2c_bus *bus);
 int i2c_bus_transfer(i2c_bus *bus, i2c_msg *msgs, uint32_t msg_count);
+ * @brief Transfers I2C messages with optional flags.
+ * The bus is obtained before the transfer and released afterwards. If the flag
+ * I2C_BUS_NOBLOCK is set and the bus is already obtained, nothing will be
+ * transfered and the function returns with an -EAGAIN.
+ * @param[in] msgs The messages to transfer.
+ * @param[in] msg_count The count of messages to transfer.  It must be
+ * positive.
+ * @param[in] flags Options for the whole transfer.
+ * @retval -EAGAIN if @ref I2C_BUS_NOBLOCK is set and the bus is already
+ * obtained.
+ * @retval negative Negative error number in case of an error.
+  i2c_bus *bus,
+  i2c_msg *msgs,
+  uint32_t flags
+ * @brief I2C bus transfer flag to indicate that the task should not block if
+ * the bus is busy on a new transfer.
+#define I2C_BUS_NOBLOCK (1u << 0)
diff --git a/testsuites/libtests/i2c01/init.c b/testsuites/libtests/i2c01/init.c
index 83027ed548..c71b78c275 100644
--- a/testsuites/libtests/i2c01/init.c
+++ b/testsuites/libtests/i2c01/init.c
@@ -336,6 +336,124 @@ static void test_simple_read_write(test_bus *bus, int fd)
   rtems_test_assert(memcmp(&buf[0], &abc[0], sizeof(buf)) == 0);
+typedef struct {
+  rtems_id caller;
+  int fd;
+} bus_obtainer_ctx;
+static void bus_obtainer_task(rtems_task_argument arg)
+  rtems_event_set e = 0;
+  bus_obtainer_ctx *c = (bus_obtainer_ctx *) arg;
+  int rv;
+  rtems_status_code sc;
+  rv = ioctl(c->fd, I2C_BUS_OBTAIN);
+  rtems_test_assert(rv == 0);
+  sc = rtems_event_send(c->caller, RTEMS_EVENT_1);
+  rtems_test_assert(sc == RTEMS_SUCCESSFUL);
+  sc = rtems_event_receive(
+    RTEMS_EVENT_1,
+    RTEMS_EVENT_ANY | RTEMS_WAIT,
+    100,
+    &e
+  rv = ioctl(c->fd, I2C_BUS_RELEASE);
+static void test_nonblock_read_write(test_bus *bus, int fd)
+  int flags;
+  int rv;
+  char buf[3];
+  ssize_t n;
+  i2c_msg msgs[] = {{
+    .addr = 1,
+    .flags = I2C_M_STOP,
+    .len = sizeof(buf),
+    .buf = (uint8_t *) buf,
+  struct i2c_rdwr_ioctl_data payload = {
+    .msgs = msgs,
+    .nmsgs = sizeof(msgs)/sizeof(msgs[0]),
+  rtems_id id;
+  bus_obtainer_ctx ctx = {
+    .caller = rtems_task_self(),
+    .fd = fd,
+  flags = fcntl(fd, F_GETFL, 0);
+  rtems_test_assert(flags > 0);
+  rv = fcntl(fd, F_SETFL, flags | O_NONBLOCK);
+  rtems_test_assert(rv != -1);
+  sc = rtems_task_create(
+    rtems_build_name('O', 'B', 'T', 'A'),
+    2,
+    RTEMS_MINIMUM_STACK_SIZE,
+    RTEMS_DEFAULT_MODES,
+    RTEMS_DEFAULT_ATTRIBUTES,
+    &id
+  sc = rtems_task_start(
+    id,
+    bus_obtainer_task,
+    (rtems_task_argument) &ctx
+    RTEMS_EVENT_1,
+    100,
+    &e
+  errno = 0;
+  n = read(fd, &buf[0], sizeof(buf));
+  rtems_test_assert(n == -1);
+  rtems_test_assert(errno == EAGAIN);
+  errno = 0;
+  n = write(fd, &buf[0], sizeof(buf));
+  errno = 0;
+  rv = ioctl(fd, I2C_RDWR, &payload);
+  rtems_test_assert(rv == -1);
+  sc = rtems_event_send(id, RTEMS_EVENT_1);
+    RTEMS_EVENT_1,
+    100,
+    &e
+  sc = rtems_task_delete(id);
+  rv = fcntl(fd, F_SETFL, flags);
 static void test_gpio_nxp_pca9535(void)
   int rv;
@@ -627,6 +745,7 @@ static void test(void)
   rtems_test_assert(bus->base.timeout == 0);
   test_simple_read_write(bus, fd);
+  test_nonblock_read_write(bus, fd);
   test_eeprom(bus);
   test_gpio_nxp_pca9535();
   test_switch_nxp_pca9548a();
@@ -657,7 +776,7 @@ static void Init(rtems_task_argument arg)
 #define CONFIGURE_MAXIMUM_FILE_DESCRIPTORS 7
-#define CONFIGURE_MAXIMUM_TASKS 1
+#define CONFIGURE_MAXIMUM_TASKS 2
 #define CONFIGURE_MAXIMUM_SEMAPHORES 1
2.26.2
