[PATCH] cpukit/libmisc/monitor: Fixed src/dest overlap in strcpy in mon-editor.c
Gedare Bloom
gedare at rtems.org
Thu May 27 01:46:19 UTC 2021
On Wed, May 26, 2021 at 4:35 PM Harrison Edward Gerber
<gerberhe11 at gmail.com> wrote:
> See also CID 1399727
> Closes #4444
> cpukit/libmisc/monitor/mon-editor.c | 3 ++-
> 1 file changed, 2 insertions(+), 1 deletion(-)
> diff --git a/cpukit/libmisc/monitor/mon-editor.c b/cpukit/libmisc/monitor/mon-editor.c
> index dcea9fcc69..1392be51f1 100644
> --- a/cpukit/libmisc/monitor/mon-editor.c
> +++ b/cpukit/libmisc/monitor/mon-editor.c
> @@ -360,7 +360,8 @@ rtems_monitor_line_editor (
> int bs;
> pos--;
> - strcpy (buffer + pos, buffer + pos + 1);
> + memmove(buffer + pos, buffer + pos + 1, RTEMS_COMMAND_BUFFER_SIZE - pos - 1);
This exceeds 80 character line limit, please break the line length as
directed by
https://docs.rtems.org/branches/master/eng/coding-formatting.html#eighty-character-line-limit
> + buffer[RTEMS_COMMAND_BUFFER_SIZE - 1] = "\0";
This should be '\0' not "\0". I don't know if the compiler would
correct that for you or not.
> fprintf(stdout,"\b%s \b", buffer + pos);
> for (bs = 0; bs < ((int) strlen (buffer) - pos); bs++)
> putchar ('\b');
> 2.25.1
> devel mailing list
> devel at rtems.org
