[PATCH 3/3] sysinit: Do not open console when just referencing reentrancy structure.
Joel Sherrill
joel at rtems.org
Fri May 28 03:00:31 UTC 2021
I have already pushed it. Does a ticket need to be manually closed?
On Thu, May 27, 2021, 9:29 PM Gedare Bloom <gedare at rtems.org> wrote:
> The patch set looks ok, fixing the ticket number on 2/3.
> On Fri, May 21, 2021 at 3:36 PM Joel Sherrill <joel at rtems.org> wrote:
> > This change eliminates a system initialization dependentcy which resulted
> > in an application without a file system or console referencing errno
> being
> > forced to include the code to open(/dev/console), close(), atexit(),
> > and the unmount infrastructure.
> > Closes #4439.
> > cpukit/include/rtems/confdefs/iodrivers.h | 21 +++++++++++++++++++++
> > cpukit/libcsupport/src/libio_init.c | 6 ------
> > 2 files changed, 21 insertions(+), 6 deletions(-)
> > diff --git a/cpukit/include/rtems/confdefs/iodrivers.h
> b/cpukit/include/rtems/confdefs/iodrivers.h
> > index e12640624d..a7de77a8c3 100644
> > --- a/cpukit/include/rtems/confdefs/iodrivers.h
> > +++ b/cpukit/include/rtems/confdefs/iodrivers.h
> > @@ -189,6 +189,27 @@ RTEMS_SYSINIT_ITEM(
> > || CONFIGURE_APPLICATION_NEEDS_ZERO_DRIVER
> > || CONFIGURE_MAXIMUM_DRIVERS */
> > + * If any flavor of console driver is configured, then configure the
> post
> > + * driver hook which opens /dev/console as stdin, stdout, and stderr.
> > + * NOTE: This also results in an atexit() handler being registered to
> close
> > + * /dev/console.
> > +#if defined(CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER) || \
> > + defined(CONFIGURE_APPLICATION_NEEDS_SIMPLE_CONSOLE_DRIVER) || \
> > + defined(CONFIGURE_APPLICATION_NEEDS_SIMPLE_TASK_CONSOLE_DRIVER)
> > + #include <rtems/libio.h>
> > + RTEMS_SYSINIT_ITEM(
> > + rtems_libio_post_driver,
> > + RTEMS_SYSINIT_STD_FILE_DESCRIPTORS,
> > + RTEMS_SYSINIT_ORDER_MIDDLE
> > +#endif
> > #endif /* CONFIGURE_INIT */
> > #endif /* _RTEMS_CONFDEFS_IODRIVERS_H */
> > diff --git a/cpukit/libcsupport/src/libio_init.c
> b/cpukit/libcsupport/src/libio_init.c
> > index d5814ca5a2..2bfc7664d7 100644
> > --- a/cpukit/libcsupport/src/libio_init.c
> > +++ b/cpukit/libcsupport/src/libio_init.c
> > @@ -65,9 +65,3 @@ RTEMS_SYSINIT_ITEM(
> > RTEMS_SYSINIT_LIBIO,
> > -RTEMS_SYSINIT_ITEM(
> > - rtems_libio_post_driver,
> > - RTEMS_SYSINIT_STD_FILE_DESCRIPTORS,
> > - RTEMS_SYSINIT_ORDER_MIDDLE
> > 2.24.4
> > devel mailing list
> > devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210527/4f6b8a7f/attachment-0001.html>
