[PATCH v2 3/3] main_help.c: Do not care what char is returned by getchar()
Ryan Long ryan.long at oarcorp.com
Fri May 28 15:11:21 UTC 2021
You acked them, and I sent the tarball with the patches to Joel. So I think Joel just forgot to put them in.
-----Original Message-----
Sent: Friday, May 28, 2021 9:55 AM
To: Ryan Long <ryan.long at oarcorp.com>
Cc: devel at rtems.org
Subject: Re: [PATCH v2 3/3] main_help.c: Do not care what char is returned by getchar()
Are these three still pending? If so, can you ping the other 2 or advise what is blocking?
On Mon, Apr 5, 2021 at 7:28 AM Ryan Long <ryan.long at oarcorp.com> wrote:
> CID 1437650: Unchecked return value from library in rtems_shell_help().
> Closes #4291
>  cpukit/libmisc/shell/main_help.c | 2 +-
>  1 file changed, 1 insertion(+), 1 deletion(-)
> diff --git a/cpukit/libmisc/shell/main_help.c
> b/cpukit/libmisc/shell/main_help.c
> index 9f59e9d..564bc30 100644
> --- a/cpukit/libmisc/shell/main_help.c
> +++ b/cpukit/libmisc/shell/main_help.c
> @@ -148,7 +148,7 @@ static int rtems_shell_help(
>          line+= rtems_shell_help_cmd(shell_cmd);
>        if (lines && (line > lines)) {
>          printf("Press any key to continue...");
> -        getchar();
> +        (void) getchar();
>          printf("\n");
>          line = 0;
> 1.8.3.1
> devel mailing list
> devel at rtems.org
