[PATCH v2 3/3] main_help.c: Do not care what char is returned by getchar()
Vijay Kumar Banerjee
vijay at rtems.org
Fri May 28 16:22:56 UTC 2021
Hi all,
On Fri, May 28, 2021, 08:54 Gedare Bloom <gedare at rtems.org> wrote:
> Are these three still pending? If so, can you ping the other 2 or
> advise what is blocking?
> On Mon, Apr 5, 2021 at 7:28 AM Ryan Long <ryan.long at oarcorp.com> wrote:
> > CID 1437650: Unchecked return value from library in rtems_shell_help().
> > Closes #4291
> > cpukit/libmisc/shell/main_help.c | 2 +-
> > 1 file changed, 1 insertion(+), 1 deletion(-)
> > diff --git a/cpukit/libmisc/shell/main_help.c
> b/cpukit/libmisc/shell/main_help.c
> > index 9f59e9d..564bc30 100644
> > --- a/cpukit/libmisc/shell/main_help.c
> > +++ b/cpukit/libmisc/shell/main_help.c
> > @@ -148,7 +148,7 @@ static int rtems_shell_help(
> > line+= rtems_shell_help_cmd(shell_cmd);
> > if (lines && (line > lines)) {
> > printf("Press any key to continue...");
Unrelated to this patch, but shouldn't the above line say "Press ENTER to
continue"? :D
> - getchar();
> > + (void) getchar();
> > printf("\n");
> > line = 0;
> > 1.8.3.1
> > devel mailing list
> > devel at rtems.org
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210528/ece7cb8c/attachment.html>
