[PATCH v2] cpukit/libmisc/monitor: Fix src/dest overlap of strcpy in mon-editor.c
Fri May 28 19:08:12 UTC 2021
This looks OK.
On Thu, May 27, 2021 at 7:32 PM Harrison Edward Gerber <gerberhe11 at gmail.com>
wrote:
> From: Harrison Edward Gerber <gerberhe11 at gmail.com>
> See also CID 1399727
> Closes #4444
>  cpukit/libmisc/monitor/mon-editor.c | 12 +++++++++++-
>  1 file changed, 11 insertions(+), 1 deletion(-)
> diff --git a/cpukit/libmisc/monitor/mon-editor.c
> b/cpukit/libmisc/monitor/mon-editor.c
> index dcea9fcc69..4287b399a5 100644
> --- a/cpukit/libmisc/monitor/mon-editor.c
> +++ b/cpukit/libmisc/monitor/mon-editor.c
> @@ -360,7 +360,17 @@ rtems_monitor_line_editor (
>                int bs;
>                pos--;
> -              strcpy (buffer + pos, buffer + pos + 1);
> +               * Memory operation used here instead of string
> +               * method due the src and dest of buffer overlapping.
> +              memmove(
> +                buffer + pos,
> +                buffer + pos + 1,
> +                RTEMS_COMMAND_BUFFER_SIZE - pos - 1
> +              buffer[RTEMS_COMMAND_BUFFER_SIZE - 1] = '\0';
>                fprintf(stdout,"\b%s \b", buffer + pos);
>                for (bs = 0; bs < ((int) strlen (buffer) - pos); bs++)
>                  putchar ('\b');
> 2.25.1
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210528/970884b8/attachment.html>
