[PATCH v2] cpukit/libmisc/monitor: Fix src/dest overlap of strcpy in mon-editor.c
Vijay Kumar Banerjee
vijay at rtems.org
Fri May 28 22:01:06 UTC 2021
On Fri, May 28, 2021 at 1:08 PM Joel Sherrill <joel at rtems.org> wrote:
> This looks OK.
Pushed. Thanks.
> On Thu, May 27, 2021 at 7:32 PM Harrison Edward Gerber <gerberhe11 at gmail.com> wrote:
>> From: Harrison Edward Gerber <gerberhe11 at gmail.com>
>> See also CID 1399727
>> Closes #4444
>> cpukit/libmisc/monitor/mon-editor.c | 12 +++++++++++-
>> 1 file changed, 11 insertions(+), 1 deletion(-)
>> diff --git a/cpukit/libmisc/monitor/mon-editor.c b/cpukit/libmisc/monitor/mon-editor.c
>> index dcea9fcc69..4287b399a5 100644
>> --- a/cpukit/libmisc/monitor/mon-editor.c
>> +++ b/cpukit/libmisc/monitor/mon-editor.c
>> @@ -360,7 +360,17 @@ rtems_monitor_line_editor (
>> int bs;
>> pos--;
>> - strcpy (buffer + pos, buffer + pos + 1);
>> + * Memory operation used here instead of string
>> + * method due the src and dest of buffer overlapping.
>> + memmove(
>> + buffer + pos,
>> + buffer + pos + 1,
>> + RTEMS_COMMAND_BUFFER_SIZE - pos - 1
>> + buffer[RTEMS_COMMAND_BUFFER_SIZE - 1] = '\0';
>> fprintf(stdout,"\b%s \b", buffer + pos);
>> for (bs = 0; bs < ((int) strlen (buffer) - pos); bs++)
>> putchar ('\b');
>> 2.25.1
>> devel mailing list
>> devel at rtems.org
> devel mailing list
> devel at rtems.org
