[PATCH RSB v2] rtems-kernel: Implement kernel recipe using waf
Tue Nov 2 01:48:28 UTC 2021
On 28/10/21 2:09 am, Ryan Long wrote:
> Closes #4145
>  rtems/config/tools/rtems-kernel-6.cfg      |   6 +-
>  rtems/config/tools/rtems-kernel-common.cfg | 125 ++++++++++++------------
>  source-builder/rtems-kernel-config-check   | 147 +++++++++++++++++++++++++++++
>  source-builder/sb/options.py               | 135 +++++++++++++-------------
>  4 files changed, 283 insertions(+), 130 deletions(-)
>  create mode 100755 source-builder/rtems-kernel-config-check
> diff --git a/rtems/config/tools/rtems-kernel-6.cfg b/rtems/config/tools/rtems-kernel-6.cfg
> index f1d0990..9120862 100644
> --- a/rtems/config/tools/rtems-kernel-6.cfg
> +++ b/rtems/config/tools/rtems-kernel-6.cfg
> @@ -2,10 +2,10 @@
>  # RTEMS 5
> -%define rtems_kernel_version 3ec5f20484cc4201e1d7b87844505644533b6148
> -%hash sha512 rtems-kernel-%{rtems_kernel_version}.tar.bz2 \
> -              BjMKrf5n1YR6IpiZrY5TUEzKATPRJxA2/6m6f833DdRu+RyLxccXqA4gHRdVUqFelFNQ3o0XdG4o1naBKYfhkQ==
> +%define rtems_kernel_version 3bb97a30b17b6c138dead3e3a6b329c3b301cdb3
> +%hash sha512 rtems-kernel-%{rtems_kernel_version}.tar.gz \
> +              m/ogwrJj4X60ewDIbV6WRj1MJa/22gQHQd56XiNMfvCr0nsvcXdkXKAObLIGYIGYfUyEwlVk3SRjjRFkFalDGQ==
>  # The RTEMS build instructions.
> diff --git a/rtems/config/tools/rtems-kernel-common.cfg b/rtems/config/tools/rtems-kernel-common.cfg
> index 157c7a4..d5b67dd 100644
> --- a/rtems/config/tools/rtems-kernel-common.cfg
> +++ b/rtems/config/tools/rtems-kernel-common.cfg
> @@ -9,7 +9,7 @@
>  # and BSPs. Only after the source to download.
>  %if %{_dry_run} && %{defined with_download}
> - %log Kenrel configuration errors ignored
> + %log Kernel configuration errors ignored
>   %define rtems_kernel_error 0
>  %else
>   %define rtems_kernel_error 1
> @@ -19,10 +19,15 @@
>   %define rtems_kernel_version %{rsb_version}
>  %endif
> +%if %{defined with_rtems_bsp_config}
> + %define _target %(%{_topdir}/../source-builder/rtems-kernel-config-check -v %{rtems_version} -t %{with_rtems_bsp_config})
There is a variable called `_sbdir` that is normally used to find internal
helper scripts located in the source builder...
https://docs.rtems.org/branches/master/user/rsb/configuration.html#configuration
If you add `rtems-kernel-config-check` to `source-builder` it becomes a user
facing tool and needs documentation and a controlled user interface. If you use:
 %{_sbdir}/sb/rtems-kernel-config-check
the helper script is internal to the source builder. Is the script internal?
> + %define rtems_bsp %(%{_topdir}/../source-builder/rtems-kernel-config-check -b %{with_rtems_bsp_config})
How are config file errors handled? I normally return `ERROR` or something that
can be checked.
> +%endif
>  # The target. It could be set in rtems_target.
> -%if %{defined rtems_target}
> +%if %{defined rtems_target} && !%{defined with_rtems_bsp_config}
>   %define _target %{rtems_target}
>  %endif
>  %if %{_target} == %{nil} && %{rtems_kernel_error}
> @@ -32,10 +37,21 @@
>  # The BSP.
> -%if !%{defined with_rtems_bsp} && %{rtems_kernel_error}
> +%if !%{defined with_rtems_bsp} && %{rtems_kernel_error} && !%{defined with_rtems_bsp_config}
>   %error No RTEMS BSP specified: --with-rtems-bsp=bsp
>  %endif
> -%define rtems_bsp %{with_rtems_bsp}
> +%if !%{defined with_rtems_bsp_config}
> + %define rtems_bsp %{with_rtems_bsp}
> +%endif
> +# Configuration file used with waf
> +%ifn %{defined with_rtems_bsp_config}
> + %define config_file config-%{_target}-%{rtems_bsp}.ini
> +%else
> + %define config_file %{with_rtems_bsp_config}
> +%endif
>  # If no tools are provided use the prefix.
> @@ -98,14 +114,6 @@ URL: 	 https://www.rtems.org/
>   %define rtems_posix 0
>  %endif
> -%if %{defined with_rtems_legacy_network}
> - %define rtems_networking 1
> -%endif
> -%if %{defined with_rtems_cxx}
> - %define rtems_cxx 1
> -%endif
>  %if %{defined with_rtems_bspopts}
>   %define bspopts %{with_rtems_bspopts}
>  %endif
> @@ -143,43 +151,43 @@ URL: 	 https://www.rtems.org/
>  # --without-rtems-tests          : Supported, forced to no
>  # --with-rtems-smp               : Supported
>  # --without-rtems-smp            : Don't care
> -# --with-rtems-legacy-network    : Supported
> +# --with-rtems-legacy-network    : Unsupported
>  # --without-rtems-legacy-network : Don't care
> -# --with-rtems-bspopts           : Supported, quote for a list
> -# --without-rtems-bspopts        : Don't care
>  %if %{defined without_rtemsbsp}
>   %error Option --without-rtemsbsp is not supported.
>  %endif
> +%if %{defined with_rtems_legacy_network}
> + echo "RTEMS legacy network has been removed."
> + echo "Please review and update your configuration."
> + exit 1
> +%endif
> +%if %{defined enable_cxx}
> + echo CXX has been removed."
> + exit 1
> +%endif
>  %if %{defined without_rtems_tests}
> - %define with_rtems_tests no
> + %define rtems_tests False
> + %define rtems_sample_tests False
>  %endif
>  %if %{defined with_rtems_tests}
>   %if %{with_rtems_tests} == 1
> -  %define with_rtems_tests yes
> +   %define rtems_tests True
> +   %define rtems_sample_tests True
>   %endif
> - %if %{with_rtems_tests} == yes || \
> -     %{with_rtems_tests} == no || \
> -     %{with_rtems_tests} == samples
> -  %define rtems_tests %{with_rtems_tests}
> +  %if %{with_rtems_tests} == samples
>   %endif
>  %endif
>  %if %{defined with_rtems_smp}
>   %define rtems_smp 1
>  %endif
> -%endif
>   %define rtems_bspopts %{with_rtems_bspopts}
>  %endif
> -# If C++ defined for the tool set use it to control RTEMS's setting..
> -%if %{defined enable_cxx}
> - %define rtems_cxx %{enable_cxx}
> -%endif
>  # Default set up. Override these in a BSP if you want a
> @@ -188,14 +196,9 @@ URL: 	 https://www.rtems.org/
>  %ifn %{defined rtems_posix}
>   %define rtems_posix 1
>  %endif
> -%ifn %{defined rtems_networking}
> - %define rtems_networking 0
> -%endif
> -%ifn %{defined rtems_cxx}
> -%endif
>  %ifn %{defined rtems_tests}
> - %define rtems_tests samples
>  %endif
>  %ifn %{defined rtems_bspopts}
>   %define rtems_bspopts %{nil}
> @@ -213,8 +216,6 @@ URL: 	 https://www.rtems.org/
>      %if %{defined _internal_autotools_path}
>        export PATH="%{_internal_autotools_path}/bin:${PATH}"
>      %endif
> -    ./bootstrap -c
> -    ./rtems-bootstrap
>    %endif
>    cd ..
> @@ -225,38 +226,42 @@ URL: 	 https://www.rtems.org/
>    else
>      build_dir="build"
>    fi
> +  cd ${source_dir_rtems}
> +  %if %{defined without_rtems_bsp_config}
> +    cpu=`echo %{_target} | cut -d- -f1`
> +    echo "[${cpu}/%{rtems_bsp}]" > %{config_file}
> +    echo "RTEMS_POSIX_API = %{?rtems_posix:True}%{!?rtems_posix:False}" >> %{config_file}
> +    echo "RTEMS_SMP = %{?rtems_smp:True}%{!?rtems_smp:False}" >> %{config_file}
> +    echo "BUILD_TESTS = %{rtems_tests}" >> %{config_file}
> +    echo "BUILD_SAMPLES = %{rtems_sample_tests}" >> %{config_file}
> +  %endif
>    mkdir -p ${build_dir}
> -  cd ${build_dir}
> -  ../${source_dir_rtems}/configure \
> -    --build=%{_build} --host=%{_host} \
> -    --target=%{_target} \
> -    --enable-rtemsbsp="%{rtems_bsp}" \
> -    %{?rtems_cxx:--enable-cxx}%{!?rtems_cxx:--disable-cxx} \
> -    %{?rtems_posix:--enable-posix}%{!?rtems_posix:--disable-posix} \
> -    %{?rtems_networking:--enable-networking}%{!?rtems_networking:--disable-networking} \
> -    %{?rtems_tests:--enable-tests=%{rtems_tests}} \
> -    %{?rtems_smp:--enable-smp} \
> +  ./waf configure \
> +    --rtems-bsps=%{_target}/%{rtems_bsp} \
>      --prefix=%{_prefix} --bindir=%{_bindir} \
> -    --exec-prefix=%{_exec_prefix} \
> -    --includedir=%{_includedir} --libdir=%{_libdir} \
> -    --mandir=%{_mandir} --infodir=%{_infodir} \
> -    %{rtems_bspopts}
> +    --rtems-config=%{config_file}
> +  ./waf %{?_smp_mflags}
> -  %{__make} %{?_smp_mflags} all
>    cd ..
>  %install
>    %{__rmdir} $SB_BUILD_ROOT
> -  cd ${build_dir}
> -  %{__make} DESTDIR=$SB_BUILD_ROOT install
> +  ./waf --destdir=$SB_BUILD_ROOT install
> +  echo "rtems_tests: %{rtems_tests}"
> -  %if %{rtems_tests} != no
> +  %if %{rtems_tests} != False
>     %define rtems_test_install %{_target}/%{rtems_bsp}/tests
>     mkdir -p $SB_BUILD_ROOT/%{_prefix}/%{rtems_test_install}
>     find . -name \*.exe -and -not -name \*.norun.exe \
>        -exec cp -v \{\} $SB_BUILD_ROOT/%{_prefix}/%{rtems_test_install}/ \;
>    %endif
> -  cd ..
> +  cd -
> diff --git a/source-builder/rtems-kernel-config-check b/source-builder/rtems-kernel-config-check
> new file mode 100755
> index 0000000..9bdff22
> --- /dev/null
> +++ b/source-builder/rtems-kernel-config-check
> @@ -0,0 +1,147 @@
> +#! /usr/bin/env python
> +SPDX-License-Identifier: BSD-2-Clause
> +COPYRIGHT (C) 2021 On-Line Applications Research Corporation (OAR).
> +Redistribution and use in source and binary forms, with or without
> +modification, are permitted provided that the following conditions
> +are met:
> +1. Redistributions of source code must retain the above copyright
> +   notice, this list of conditions and the following disclaimer.
> +2. Redistributions in binary form must reproduce the above copyright
> +   notice, this list of conditions and the following disclaimer in the
> +   documentation and/or other materials provided with the distribution.
> +THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
> +AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
> +IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
> +ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
> +LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
> +CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
> +SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
> +INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
> +CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
> +ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
> +POSSIBILITY OF SUCH DAMAGE.
> +from __future__ import print_function
> +import sys
> +import argparse
> +from os.path import exists
> +try:
> +    import ConfigParser
> +    configparser = ConfigParser # used for python2
> +except ImportError:
> +    try:
> +        import configparser # used for python3
> +    except ImportError:
> +        print("Could not import configparser. Exiting...", file = sys.stderr)
> +        sys.exit(1)
> +def run():
> +    parser = argparse.ArgumentParser()
> +    parser.add_argument("config", help="path to config file")
> +        "-a",
> +        "--arch",
> +        help="return target architecture specified in the config",
> +        action="store_true"
> +        "-b",
> +        "--bsp",
> +        help="return BSP specified in the config",
> +        "-c",
> +        "--arch-bsp",
> +        help="return target architecture and BSP specified in the config",
> +        "-v",
> +        "--rtems-version",
> +        help="version of RTEMS",
> +        type=int,
> +        default=6
> +        "-t",
> +        "--target",
> +        help="return target (<arch-rtems<rtems-version>)",
> +    args = parser.parse_args()
> +    config = configparser.ConfigParser()
> +    if args.config[-4:] != ".ini":
> +        print(
> +            "The config file is missing an *.ini extension.",
> +            file = sys.stderr
> +        sys.exit(1)
> +    try:
> +        config.read(args.config)
> +    except configparser.MissingSectionHeaderError:
> +        print(
> +            "There is no section header in the config file",
> +            file = sys.stderr
> +        sys.exit(1)
> +    except configparser.ParsingError:
> +        print(
> +            "An exception occured when parsing the config file",
> +            file = sys.stderr
> +        sys.exit(1)
> +    except:
> +        print(
> +            "An unknown exception occured",
> +            file = sys.stderr
> +    if len(config.sections()) != 1:
> +        print(
> +            "You can only have one arch/bsp section in your config.",
> +            file = sys.stderr
> +        sys.exit(1)
> +    arch_bsp_str = config.sections()[0]
> +    if arch_bsp_str.find("/") == -1:
> +        print(
> +            "arch/bsp section in config is missing '/'",
> +            file = sys.stderr
> +        sys.exit(1)
> +    if ( args.arch or args.bsp) and args.arch_bsp:
> +        args.arch = False
> +    if args.arch:
> +        print(arch_bsp_str.split("/")[0])
> +        return
> +    if args.bsp:
> +        print(arch_bsp_str.split("/")[1])
> +        return
> +    if args.arch_bsp:
> +        print(arch_bsp_str.replace("/", " "))
> +        return
> +    if args.target:
> +        arch = arch_bsp_str.split("/")[0]
> +        print(arch + "-rtems" + str(args.rtems_version))
> +        return
> +if __name__ == "__main__":
> +    run()
> diff --git a/source-builder/sb/options.py b/source-builder/sb/options.py
> index a0f196b..6cf4d12 100644
> --- a/source-builder/sb/options.py
> +++ b/source-builder/sb/options.py
> @@ -55,39 +55,39 @@ class command_line:
>      def __init__(self, argv, optargs, _defaults, command_path):
>          self._long_opts = {
>              # key                       macro                handler            param  defs   init
> -            '--prefix'               : ('_prefix',           self._lo_path,     True,  None,  False),
> -            '--topdir'               : ('_topdir',           self._lo_path,     True,  None,  False),
> -            '--configdir'            : ('_configdir',        self._lo_path,     True,  None,  False),
> -            '--builddir'             : ('_builddir',         self._lo_path,     True,  None,  False),
> -            '--sourcedir'            : ('_sourcedir',        self._lo_path,     True,  None,  False),
> -            '--patchdir'             : ('_patchdir',         self._lo_path,     True,  None,  False),
> -            '--tmppath'              : ('_tmppath',          self._lo_path,     True,  None,  False),
> -            '--jobs'                 : ('_jobs',             self._lo_jobs,     True,  'max', True),
> -            '--log'                  : ('_logfile',          self._lo_string,   True,  None,  False),
> -            '--url'                  : ('_url_base',         self._lo_string,   True,  None,  False),
> -            '--no-download'          : ('_disable_download', self._lo_bool,     False, '0',   True),
> -            '--macros'               : ('_macros',           self._lo_string,   True,  None,  False),
> -            '--source-only-download' : ('_source_download',  self._lo_bool,     False, '0',   True),
> -            '--targetcflags'         : ('_targetcflags',     self._lo_string,   True,  None,  False),
> -            '--targetcxxflags'       : ('_targetcxxflags',   self._lo_string,   True,  None,  False),
> -            '--libstdcxxflags'       : ('_libstdcxxflags',   self._lo_string,   True,  None,  False),
> -            '--force'                : ('_force',            self._lo_bool,     False, '0',   True),
> -            '--quiet'                : ('_quiet',            self._lo_bool,     False, '0',   True),
> -            '--trace'                : ('_trace',            self._lo_bool,     False, '0',   True),
> -            '--dry-run'              : ('_dry_run',          self._lo_bool,     False, '0',   True),
> -            '--warn-all'             : ('_warn_all',         self._lo_bool,     False, '0',   True),
> -            '--no-clean'             : ('_no_clean',         self._lo_bool,     False, '0',   True),
> -            '--keep-going'           : ('_keep_going',       self._lo_bool,     False, '0',   True),
> -            '--always-clean'         : ('_always_clean',     self._lo_bool,     False, '0',   True),
> -            '--no-install'           : ('_no_install',       self._lo_bool,     False, '0',   True),
> -            '--regression'           : ('_regression',       self._lo_bool,     False, '0',   True),
> -            '--host'                 : ('_host',             self._lo_triplets, True,  None,  False),
> -            '--build'                : ('_build',            self._lo_triplets, True,  None,  False),
> -            '--target'               : ('_target',           self._lo_triplets, True,  None,  False),
> -            '--rtems-tools'          : ('_rtems_tools',      self._lo_string,   True,  None,  False),
> -            '--rtems-bsp'            : ('_rtems_bsp',        self._lo_string,   True,  None,  False),
> -            '--rtems-version'        : ('_rtems_version',    self._lo_string,   True,  None,  False),
> -            '--help'                 : (None,                self._lo_help,     False, None,  False)
> +            '--prefix'                : ('_prefix',           self._lo_path,     True,  None,  False),
> +            '--topdir'                : ('_topdir',           self._lo_path,     True,  None,  False),
> +            '--configdir'             : ('_configdir',        self._lo_path,     True,  None,  False),
> +            '--builddir'              : ('_builddir',         self._lo_path,     True,  None,  False),
> +            '--sourcedir'             : ('_sourcedir',        self._lo_path,     True,  None,  False),
> +            '--patchdir'              : ('_patchdir',         self._lo_path,     True,  None,  False),
> +            '--tmppath'               : ('_tmppath',          self._lo_path,     True,  None,  False),
> +            '--jobs'                  : ('_jobs',             self._lo_jobs,     True,  'max', True),
> +            '--log'                   : ('_logfile',          self._lo_string,   True,  None,  False),
> +            '--url'                   : ('_url_base',         self._lo_string,   True,  None,  False),
> +            '--no-download'           : ('_disable_download', self._lo_bool,     False, '0',   True),
> +            '--macros'                : ('_macros',           self._lo_string,   True,  None,  False),
> +            '--source-only-download'  : ('_source_download',  self._lo_bool,     False, '0',   True),
> +            '--targetcflags'          : ('_targetcflags',     self._lo_string,   True,  None,  False),
> +            '--targetcxxflags'        : ('_targetcxxflags',   self._lo_string,   True,  None,  False),
> +            '--libstdcxxflags'        : ('_libstdcxxflags',   self._lo_string,   True,  None,  False),
> +            '--force'                 : ('_force',            self._lo_bool,     False, '0',   True),
> +            '--quiet'                 : ('_quiet',            self._lo_bool,     False, '0',   True),
> +            '--trace'                 : ('_trace',            self._lo_bool,     False, '0',   True),
> +            '--dry-run'               : ('_dry_run',          self._lo_bool,     False, '0',   True),
> +            '--warn-all'              : ('_warn_all',         self._lo_bool,     False, '0',   True),
> +            '--no-clean'              : ('_no_clean',         self._lo_bool,     False, '0',   True),
> +            '--keep-going'            : ('_keep_going',       self._lo_bool,     False, '0',   True),
> +            '--always-clean'          : ('_always_clean',     self._lo_bool,     False, '0',   True),
> +            '--no-install'            : ('_no_install',       self._lo_bool,     False, '0',   True),
> +            '--regression'            : ('_regression',       self._lo_bool,     False, '0',   True),
> +            '--host'                  : ('_host',             self._lo_triplets, True,  None,  False),
> +            '--build'                 : ('_build',            self._lo_triplets, True,  None,  False),
> +            '--target'                : ('_target',           self._lo_triplets, True,  None,  False),
> +            '--rtems-tools'           : ('_rtems_tools',      self._lo_string,   True,  None,  False),
> +            '--rtems-bsp'             : ('_rtems_bsp',        self._lo_string,   True,  None,  False),
The documented method uses `--with-rtems-bsp=erc32 --with-rtems-tests=yes` ...
https://docs.rtems.org/branches/master/user/start/bsp-build.html#rsb-bsp-build
I prefer we do not changes this. See `--with-<label>`:
https://docs.rtems.org/branches/master/user/rsb/commands.html#set-builder-sb-set-builder
The --with-* method avoids creating a dependency between package configs and the
commandline options, ie this source file.
> +            '--rtems-version'         : ('_rtems_version',    self._lo_string,   True,  None,  False),
> +            '--help'                  : (None,                self._lo_help,     False, None,  False)
>          self.command_path = command_path
> @@ -203,40 +203,41 @@ class command_line:
>          print('%s: [options] [args]' % (self.command_name))
>          print('RTEMS Source Builder, an RTEMS Tools Project (c) 2012-2019 Chris Johns')
>          print('Options and arguments:')
> -        print('--force                : Force the build to proceed')
> -        print('--quiet                : Quiet output (not used)')
> -        print('--trace                : Trace the execution')
> -        print('--dry-run              : Do everything but actually run the build')
> -        print('--warn-all             : Generate warnings')
> -        print('--no-clean             : Do not clean up the build tree')
> -        print('--always-clean         : Always clean the build tree, even with an error')
> -        print('--keep-going           : Do not stop on an error.')
> -        print('--regression           : Set --no-install, --keep-going and --always-clean')
> -        print('--jobs                 : Run with specified number of jobs, default: num CPUs.')
> -        print('--host                 : Set the host triplet')
> -        print('--build                : Set the build triplet')
> -        print('--target               : Set the target triplet')
> -        print('--prefix path          : Tools build prefix, ie where they are installed')
> -        print('--topdir path          : Top of the build tree, default is $PWD')
> -        print('--configdir path       : Path to the configuration directory, default: ./config')
> -        print('--builddir path        : Path to the build directory, default: ./build')
> -        print('--sourcedir path       : Path to the source directory, default: ./source')
> -        print('--patchdir path        : Path to the patches directory, default: ./patches')
> -        print('--tmppath path         : Path to the temp directory, default: ./tmp')
> -        print('--macros file[,[file]  : Macro format files to load after the defaults')
> -        print('--log file             : Log file where all build out is written too')
> -        print('--url url[,url]        : URL to look for source')
> -        print('--no-download          : Disable the source downloader')
> -        print('--no-install           : Do not install the packages to the prefix')
> -        print('--targetcflags flags   : List of C flags for the target code')
> -        print('--targetcxxflags flags : List of C++ flags for the target code')
> -        print('--libstdcxxflags flags : List of C++ flags to build the target libstdc++ code')
> -        print('--source-only-download : Only download the source')
> -        print('--with-<label>         : Add the --with-<label> to the build')
> -        print('--without-<label>      : Add the --without-<label> to the build')
> -        print('--rtems-tools path     : Path to an install RTEMS tool set')
> -        print('--rtems-bsp arc/bsp    : Standard RTEMS architecure and BSP specifier')
> -        print('--rtems-version ver    : The RTEMS major/minor version string')
> +        print('--force                 : Force the build to proceed')
> +        print('--quiet                 : Quiet output (not used)')
> +        print('--trace                 : Trace the execution')
> +        print('--dry-run               : Do everything but actually run the build')
> +        print('--warn-all              : Generate warnings')
> +        print('--no-clean              : Do not clean up the build tree')
> +        print('--always-clean          : Always clean the build tree, even with an error')
> +        print('--keep-going            : Do not stop on an error.')
> +        print('--regression            : Set --no-install, --keep-going and --always-clean')
> +        print('--jobs                  : Run with specified number of jobs, default: num CPUs.')
> +        print('--host                  : Set the host triplet')
> +        print('--build                 : Set the build triplet')
> +        print('--target                : Set the target triplet')
> +        print('--prefix path           : Tools build prefix, ie where they are installed')
> +        print('--topdir path           : Top of the build tree, default is $PWD')
> +        print('--configdir path        : Path to the configuration directory, default: ./config')
> +        print('--builddir path         : Path to the build directory, default: ./build')
> +        print('--sourcedir path        : Path to the source directory, default: ./source')
> +        print('--patchdir path         : Path to the patches directory, default: ./patches')
> +        print('--tmppath path          : Path to the temp directory, default: ./tmp')
> +        print('--macros file[,[file]   : Macro format files to load after the defaults')
> +        print('--log file              : Log file where all build out is written too')
> +        print('--with-rtems-bsp-config : Configuration file to use')
> +        print('--url url[,url]         : URL to look for source')
> +        print('--no-download           : Disable the source downloader')
> +        print('--no-install            : Do not install the packages to the prefix')
> +        print('--targetcflags flags    : List of C flags for the target code')
> +        print('--targetcxxflags flags  : List of C++ flags for the target code')
> +        print('--libstdcxxflags flags  : List of C++ flags to build the target libstdc++ code')
> +        print('--source-only-download  : Only download the source')
> +        print('--with-<label>          : Add the --with-<label> to the build')
> +        print('--without-<label>       : Add the --without-<label> to the build')
> +        print('--rtems-tools path      : Path to an install RTEMS tool set')
> +        print('--rtems-bsp arc/bsp     : Standard RTEMS architecure and BSP specifier')
> +        print('--rtems-version ver     : The RTEMS major/minor version string')
>          if self.optargs:
>              for a in self.optargs:
>                  print('%-22s : %s' % (a, self.optargs[a]))
