[PATCH RSB v2] rtems-kernel: Implement kernel recipe using waf
Ryan Long
ryan.long at oarcorp.com
Tue Nov 2 17:13:28 UTC 2021
-----Original Message-----
Sent: Monday, November 1, 2021 8:48 PM
To: Ryan Long <ryan.long at oarcorp.com>; devel at rtems.org
Subject: Re: [PATCH RSB v2] rtems-kernel: Implement kernel recipe using waf
On 28/10/21 2:09 am, Ryan Long wrote:
> Closes #4145
> rtems/config/tools/rtems-kernel-6.cfg | 6 +-
> rtems/config/tools/rtems-kernel-common.cfg | 125 ++++++++++++------------
> source-builder/rtems-kernel-config-check | 147 +++++++++++++++++++++++++++++
> source-builder/sb/options.py | 135 +++++++++++++-------------
> 4 files changed, 283 insertions(+), 130 deletions(-) create mode
> 100755 source-builder/rtems-kernel-config-check
> diff --git a/rtems/config/tools/rtems-kernel-6.cfg
> b/rtems/config/tools/rtems-kernel-6.cfg
> index f1d0990..9120862 100644
> --- a/rtems/config/tools/rtems-kernel-6.cfg
> +++ b/rtems/config/tools/rtems-kernel-6.cfg
> @@ -2,10 +2,10 @@
> # RTEMS 5
> -%define rtems_kernel_version 3ec5f20484cc4201e1d7b87844505644533b6148
> -%hash sha512 rtems-kernel-%{rtems_kernel_version}.tar.bz2 \
> - BjMKrf5n1YR6IpiZrY5TUEzKATPRJxA2/6m6f833DdRu+RyLxccXqA4gHRdVUqFelFNQ3o0XdG4o1naBKYfhkQ==
> +%define rtems_kernel_version 3bb97a30b17b6c138dead3e3a6b329c3b301cdb3
> +%hash sha512 rtems-kernel-%{rtems_kernel_version}.tar.gz \
> +m/ogwrJj4X60ewDIbV6WRj1MJa/22gQHQd56XiNMfvCr0nsvcXdkXKAObLIGYIGYfUyEw
> +lVk3SRjjRFkFalDGQ==
> # The RTEMS build instructions.
> diff --git a/rtems/config/tools/rtems-kernel-common.cfg
> b/rtems/config/tools/rtems-kernel-common.cfg
> index 157c7a4..d5b67dd 100644
> --- a/rtems/config/tools/rtems-kernel-common.cfg
> +++ b/rtems/config/tools/rtems-kernel-common.cfg
> @@ -9,7 +9,7 @@
> # and BSPs. Only after the source to download.
> %if %{_dry_run} && %{defined with_download}
> - %log Kenrel configuration errors ignored
> + %log Kernel configuration errors ignored
> %define rtems_kernel_error 0
> %else
> %define rtems_kernel_error 1
> @@ -19,10 +19,15 @@
> %define rtems_kernel_version %{rsb_version} %endif
> +%if %{defined with_rtems_bsp_config}
> + %define _target
> +%(%{_topdir}/../source-builder/rtems-kernel-config-check -v
> +%{rtems_version} -t %{with_rtems_bsp_config})
There is a variable called `_sbdir` that is normally used to find internal helper scripts located in the source builder...
https://docs.rtems.org/branches/master/user/rsb/configuration.html#configuration
If you add `rtems-kernel-config-check` to `source-builder` it becomes a user facing tool and needs documentation and a controlled user interface. If you use:
%{_sbdir}/sb/rtems-kernel-config-check
the helper script is internal to the source builder. Is the script internal?
[Ryan Long] I think it would only be useful in this case, so I'll move that to sb.
> + %define rtems_bsp
> + %(%{_topdir}/../source-builder/rtems-kernel-config-check -b
> + %{with_rtems_bsp_config})
How are config file errors handled? I normally return `ERROR` or something that can be checked.
[Ryan Long] Right now the script is handling all the errors. I'll add some error checking to rtems-kernel-common.cfg.
> +%endif
> # The target. It could be set in rtems_target.
> -%if %{defined rtems_target}
> +%if %{defined rtems_target} && !%{defined with_rtems_bsp_config}
> %define _target %{rtems_target}
> %endif
> %if %{_target} == %{nil} && %{rtems_kernel_error} @@ -32,10 +37,21 @@
> # # The BSP.
> -%if !%{defined with_rtems_bsp} && %{rtems_kernel_error}
> +%if !%{defined with_rtems_bsp} && %{rtems_kernel_error} && !%{defined
> +with_rtems_bsp_config}
> %error No RTEMS BSP specified: --with-rtems-bsp=bsp %endif -%define
> rtems_bsp %{with_rtems_bsp}
> +%if !%{defined with_rtems_bsp_config} %define rtems_bsp
> +%{with_rtems_bsp} %endif
> +# Configuration file used with waf
> +%ifn %{defined with_rtems_bsp_config} %define config_file
> +config-%{_target}-%{rtems_bsp}.ini
> +%else
> + %define config_file %{with_rtems_bsp_config} %endif
> # If no tools are provided use the prefix.
> @@ -98,14 +114,6 @@ URL: https://www.rtems.org/
> %define rtems_posix 0
> %endif
> -%if %{defined with_rtems_legacy_network}
> - %define rtems_networking 1
> -%endif
> -%if %{defined with_rtems_cxx}
> - %define rtems_cxx 1
> -%endif
> %if %{defined with_rtems_bspopts}
> %define bspopts %{with_rtems_bspopts} %endif
> @@ -143,43 +151,43 @@ URL: https://www.rtems.org/
> # --without-rtems-tests : Supported, forced to no
> # --with-rtems-smp : Supported
> # --without-rtems-smp : Don't care
> -# --with-rtems-legacy-network : Supported
> +# --with-rtems-legacy-network : Unsupported
> # --without-rtems-legacy-network : Don't care
> -# --with-rtems-bspopts : Supported, quote for a list
> -# --without-rtems-bspopts : Don't care
> %if %{defined without_rtemsbsp}
> %error Option --without-rtemsbsp is not supported.
> %endif
> +%if %{defined with_rtems_legacy_network} echo "RTEMS legacy network
> +has been removed."
> + echo "Please review and update your configuration."
> + exit 1
> +%endif
> +%if %{defined enable_cxx}
> + echo CXX has been removed."
> + exit 1
> +%endif
> %if %{defined without_rtems_tests}
> - %define with_rtems_tests no
> + %define rtems_tests False
> + %define rtems_sample_tests False
> %endif
> %if %{defined with_rtems_tests}
> %if %{with_rtems_tests} == 1
> - %define with_rtems_tests yes
> + %define rtems_tests True
> + %define rtems_sample_tests True
> %endif
> - %if %{with_rtems_tests} == yes || \
> - %{with_rtems_tests} == no || \
> - %{with_rtems_tests} == samples
> - %define rtems_tests %{with_rtems_tests}
> + %if %{with_rtems_tests} == samples
> %endif
> %endif
> %if %{defined with_rtems_smp}
> %define rtems_smp 1
> %endif
> -%endif
> %define rtems_bspopts %{with_rtems_bspopts} %endif
> -# If C++ defined for the tool set use it to control RTEMS's setting..
> -%if %{defined enable_cxx}
> - %define rtems_cxx %{enable_cxx}
> -%endif
> # Default set up. Override these in a BSP if you want a
> @@ -188,14 +196,9 @@ URL: https://www.rtems.org/
> %ifn %{defined rtems_posix}
> %define rtems_posix 1
> %endif
> -%ifn %{defined rtems_networking}
> - %define rtems_networking 0
> -%endif
> -%ifn %{defined rtems_cxx}
> -%endif
> %ifn %{defined rtems_tests}
> - %define rtems_tests samples
> %endif
> %ifn %{defined rtems_bspopts}
> %define rtems_bspopts %{nil}
> @@ -213,8 +216,6 @@ URL: https://www.rtems.org/
> %if %{defined _internal_autotools_path}
> export PATH="%{_internal_autotools_path}/bin:${PATH}"
> %endif
> - ./bootstrap -c
> - ./rtems-bootstrap
> %endif
> cd ..
> @@ -225,38 +226,42 @@ URL: https://www.rtems.org/
> else
> build_dir="build"
> fi
> + cd ${source_dir_rtems}
> + %if %{defined without_rtems_bsp_config}
> + cpu=`echo %{_target} | cut -d- -f1`
> + echo "[${cpu}/%{rtems_bsp}]" > %{config_file}
> + echo "RTEMS_POSIX_API = %{?rtems_posix:True}%{!?rtems_posix:False}" >> %{config_file}
> + echo "RTEMS_SMP = %{?rtems_smp:True}%{!?rtems_smp:False}" >> %{config_file}
> + echo "BUILD_TESTS = %{rtems_tests}" >> %{config_file}
> + echo "BUILD_SAMPLES = %{rtems_sample_tests}" >> %{config_file}
> + %endif
> mkdir -p ${build_dir}
> - cd ${build_dir}
> - ../${source_dir_rtems}/configure \
> - --build=%{_build} --host=%{_host} \
> - --target=%{_target} \
> - --enable-rtemsbsp="%{rtems_bsp}" \
> - %{?rtems_cxx:--enable-cxx}%{!?rtems_cxx:--disable-cxx} \
> - %{?rtems_posix:--enable-posix}%{!?rtems_posix:--disable-posix} \
> - %{?rtems_networking:--enable-networking}%{!?rtems_networking:--disable-networking} \
> - %{?rtems_tests:--enable-tests=%{rtems_tests}} \
> - %{?rtems_smp:--enable-smp} \
> + ./waf configure \
> + --rtems-bsps=%{_target}/%{rtems_bsp} \
> --prefix=%{_prefix} --bindir=%{_bindir} \
> - --exec-prefix=%{_exec_prefix} \
> - --includedir=%{_includedir} --libdir=%{_libdir} \
> - --mandir=%{_mandir} --infodir=%{_infodir} \
> - %{rtems_bspopts}
> + --rtems-config=%{config_file}
> + ./waf %{?_smp_mflags}
> - %{__make} %{?_smp_mflags} all
> cd ..
> %install
> %{__rmdir} $SB_BUILD_ROOT
> - cd ${build_dir}
> - %{__make} DESTDIR=$SB_BUILD_ROOT install
> + ./waf --destdir=$SB_BUILD_ROOT install
> + echo "rtems_tests: %{rtems_tests}"
> - %if %{rtems_tests} != no
> + %if %{rtems_tests} != False
> %define rtems_test_install %{_target}/%{rtems_bsp}/tests
> mkdir -p $SB_BUILD_ROOT/%{_prefix}/%{rtems_test_install}
> find . -name \*.exe -and -not -name \*.norun.exe \
> -exec cp -v \{\} $SB_BUILD_ROOT/%{_prefix}/%{rtems_test_install}/ \;
> %endif
> - cd ..
> + cd -
> diff --git a/source-builder/rtems-kernel-config-check
> b/source-builder/rtems-kernel-config-check
> new file mode 100755
> index 0000000..9bdff22
> --- /dev/null
> +++ b/source-builder/rtems-kernel-config-check
> @@ -0,0 +1,147 @@
> +#! /usr/bin/env python
> +SPDX-License-Identifier: BSD-2-Clause
> +COPYRIGHT (C) 2021 On-Line Applications Research Corporation (OAR).
> +Redistribution and use in source and binary forms, with or without
> +modification, are permitted provided that the following conditions
> +are met:
> +1. Redistributions of source code must retain the above copyright
> + notice, this list of conditions and the following disclaimer.
> +2. Redistributions in binary form must reproduce the above copyright
> + notice, this list of conditions and the following disclaimer in the
> + documentation and/or other materials provided with the distribution.
> +THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
> +AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO,
> +THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A
> +PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
> +OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
> +SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
> +LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
> +DATA, OR PROFITS; OR BUSINESS
> +INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER
> +IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
> +OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN
> +IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
> +from __future__ import print_function
> +import sys
> +import argparse
> +from os.path import exists
> +try:
> + import ConfigParser
> + configparser = ConfigParser # used for python2 except
> +ImportError:
> + try:
> + import configparser # used for python3
> + except ImportError:
> + print("Could not import configparser. Exiting...", file = sys.stderr)
> + sys.exit(1)
> +def run():
> + parser = argparse.ArgumentParser()
> + parser.add_argument("config", help="path to config file")
> + "-a",
> + "--arch",
> + help="return target architecture specified in the config",
> + action="store_true"
> + "-b",
> + "--bsp",
> + help="return BSP specified in the config",
> + "-c",
> + "--arch-bsp",
> + help="return target architecture and BSP specified in the config",
> + "-v",
> + "--rtems-version",
> + help="version of RTEMS",
> + type=int,
> + default=6
> + "-t",
> + "--target",
> + help="return target (<arch-rtems<rtems-version>)",
> + args = parser.parse_args()
> + config = configparser.ConfigParser()
> + if args.config[-4:] != ".ini":
> + print(
> + "The config file is missing an *.ini extension.",
> + file = sys.stderr
> + sys.exit(1)
> + try:
> + config.read(args.config)
> + except configparser.MissingSectionHeaderError:
> + print(
> + "There is no section header in the config file",
> + file = sys.stderr
> + sys.exit(1)
> + except configparser.ParsingError:
> + print(
> + "An exception occured when parsing the config file",
> + file = sys.stderr
> + sys.exit(1)
> + except:
> + print(
> + "An unknown exception occured",
> + file = sys.stderr
> + if len(config.sections()) != 1:
> + print(
> + "You can only have one arch/bsp section in your config.",
> + file = sys.stderr
> + sys.exit(1)
> + arch_bsp_str = config.sections()[0]
> + if arch_bsp_str.find("/") == -1:
> + print(
> + "arch/bsp section in config is missing '/'",
> + file = sys.stderr
> + sys.exit(1)
> + if ( args.arch or args.bsp) and args.arch_bsp:
> + args.arch = False
> + if args.arch:
> + print(arch_bsp_str.split("/")[0])
> + return
> + if args.bsp:
> + print(arch_bsp_str.split("/")[1])
> + return
> + if args.arch_bsp:
> + print(arch_bsp_str.replace("/", " "))
> + return
> + if args.target:
> + arch = arch_bsp_str.split("/")[0]
> + print(arch + "-rtems" + str(args.rtems_version))
> + return
> +if __name__ == "__main__":
> + run()
> diff --git a/source-builder/sb/options.py
> b/source-builder/sb/options.py index a0f196b..6cf4d12 100644
> --- a/source-builder/sb/options.py
> +++ b/source-builder/sb/options.py
> @@ -55,39 +55,39 @@ class command_line:
> def __init__(self, argv, optargs, _defaults, command_path):
> self._long_opts = {
> # key macro handler param defs init
> - '--prefix' : ('_prefix', self._lo_path, True, None, False),
> - '--topdir' : ('_topdir', self._lo_path, True, None, False),
> - '--configdir' : ('_configdir', self._lo_path, True, None, False),
> - '--builddir' : ('_builddir', self._lo_path, True, None, False),
> - '--sourcedir' : ('_sourcedir', self._lo_path, True, None, False),
> - '--patchdir' : ('_patchdir', self._lo_path, True, None, False),
> - '--tmppath' : ('_tmppath', self._lo_path, True, None, False),
> - '--jobs' : ('_jobs', self._lo_jobs, True, 'max', True),
> - '--log' : ('_logfile', self._lo_string, True, None, False),
> - '--url' : ('_url_base', self._lo_string, True, None, False),
> - '--no-download' : ('_disable_download', self._lo_bool, False, '0', True),
> - '--macros' : ('_macros', self._lo_string, True, None, False),
> - '--source-only-download' : ('_source_download', self._lo_bool, False, '0', True),
> - '--targetcflags' : ('_targetcflags', self._lo_string, True, None, False),
> - '--targetcxxflags' : ('_targetcxxflags', self._lo_string, True, None, False),
> - '--libstdcxxflags' : ('_libstdcxxflags', self._lo_string, True, None, False),
> - '--force' : ('_force', self._lo_bool, False, '0', True),
> - '--quiet' : ('_quiet', self._lo_bool, False, '0', True),
> - '--trace' : ('_trace', self._lo_bool, False, '0', True),
> - '--dry-run' : ('_dry_run', self._lo_bool, False, '0', True),
> - '--warn-all' : ('_warn_all', self._lo_bool, False, '0', True),
> - '--no-clean' : ('_no_clean', self._lo_bool, False, '0', True),
> - '--keep-going' : ('_keep_going', self._lo_bool, False, '0', True),
> - '--always-clean' : ('_always_clean', self._lo_bool, False, '0', True),
> - '--no-install' : ('_no_install', self._lo_bool, False, '0', True),
> - '--regression' : ('_regression', self._lo_bool, False, '0', True),
> - '--host' : ('_host', self._lo_triplets, True, None, False),
> - '--build' : ('_build', self._lo_triplets, True, None, False),
> - '--target' : ('_target', self._lo_triplets, True, None, False),
> - '--rtems-tools' : ('_rtems_tools', self._lo_string, True, None, False),
> - '--rtems-bsp' : ('_rtems_bsp', self._lo_string, True, None, False),
> - '--rtems-version' : ('_rtems_version', self._lo_string, True, None, False),
> - '--help' : (None, self._lo_help, False, None, False)
> + '--prefix' : ('_prefix', self._lo_path, True, None, False),
> + '--topdir' : ('_topdir', self._lo_path, True, None, False),
> + '--configdir' : ('_configdir', self._lo_path, True, None, False),
> + '--builddir' : ('_builddir', self._lo_path, True, None, False),
> + '--sourcedir' : ('_sourcedir', self._lo_path, True, None, False),
> + '--patchdir' : ('_patchdir', self._lo_path, True, None, False),
> + '--tmppath' : ('_tmppath', self._lo_path, True, None, False),
> + '--jobs' : ('_jobs', self._lo_jobs, True, 'max', True),
> + '--log' : ('_logfile', self._lo_string, True, None, False),
> + '--url' : ('_url_base', self._lo_string, True, None, False),
> + '--no-download' : ('_disable_download', self._lo_bool, False, '0', True),
> + '--macros' : ('_macros', self._lo_string, True, None, False),
> + '--source-only-download' : ('_source_download', self._lo_bool, False, '0', True),
> + '--targetcflags' : ('_targetcflags', self._lo_string, True, None, False),
> + '--targetcxxflags' : ('_targetcxxflags', self._lo_string, True, None, False),
> + '--libstdcxxflags' : ('_libstdcxxflags', self._lo_string, True, None, False),
> + '--force' : ('_force', self._lo_bool, False, '0', True),
> + '--quiet' : ('_quiet', self._lo_bool, False, '0', True),
> + '--trace' : ('_trace', self._lo_bool, False, '0', True),
> + '--dry-run' : ('_dry_run', self._lo_bool, False, '0', True),
> + '--warn-all' : ('_warn_all', self._lo_bool, False, '0', True),
> + '--no-clean' : ('_no_clean', self._lo_bool, False, '0', True),
> + '--keep-going' : ('_keep_going', self._lo_bool, False, '0', True),
> + '--always-clean' : ('_always_clean', self._lo_bool, False, '0', True),
> + '--no-install' : ('_no_install', self._lo_bool, False, '0', True),
> + '--regression' : ('_regression', self._lo_bool, False, '0', True),
> + '--host' : ('_host', self._lo_triplets, True, None, False),
> + '--build' : ('_build', self._lo_triplets, True, None, False),
> + '--target' : ('_target', self._lo_triplets, True, None, False),
> + '--rtems-tools' : ('_rtems_tools', self._lo_string, True, None, False),
> + '--rtems-bsp' : ('_rtems_bsp', self._lo_string, True, None, False),
The documented method uses `--with-rtems-bsp=erc32 --with-rtems-tests=yes` ...
https://docs.rtems.org/branches/master/user/start/bsp-build.html#rsb-bsp-build
I prefer we do not changes this. See `--with-<label>`:
https://docs.rtems.org/branches/master/user/rsb/commands.html#set-builder-sb-set-builder
The --with-* method avoids creating a dependency between package configs and the commandline options, ie this source file.
[Ryan Long] I accidentally left these changes in after adding an option here in the previous patchset.
> + '--rtems-version' : ('_rtems_version', self._lo_string, True, None, False),
> + '--help' : (None, self._lo_help, False, None, False)
> self.command_path = command_path @@ -203,40 +203,41 @@ class
> command_line:
> print('%s: [options] [args]' % (self.command_name))
> print('RTEMS Source Builder, an RTEMS Tools Project (c) 2012-2019 Chris Johns')
> print('Options and arguments:')
> - print('--force : Force the build to proceed')
> - print('--quiet : Quiet output (not used)')
> - print('--trace : Trace the execution')
> - print('--dry-run : Do everything but actually run the build')
> - print('--warn-all : Generate warnings')
> - print('--no-clean : Do not clean up the build tree')
> - print('--always-clean : Always clean the build tree, even with an error')
> - print('--keep-going : Do not stop on an error.')
> - print('--regression : Set --no-install, --keep-going and --always-clean')
> - print('--jobs : Run with specified number of jobs, default: num CPUs.')
> - print('--host : Set the host triplet')
> - print('--build : Set the build triplet')
> - print('--target : Set the target triplet')
> - print('--prefix path : Tools build prefix, ie where they are installed')
> - print('--topdir path : Top of the build tree, default is $PWD')
> - print('--configdir path : Path to the configuration directory, default: ./config')
> - print('--builddir path : Path to the build directory, default: ./build')
> - print('--sourcedir path : Path to the source directory, default: ./source')
> - print('--patchdir path : Path to the patches directory, default: ./patches')
> - print('--tmppath path : Path to the temp directory, default: ./tmp')
> - print('--macros file[,[file] : Macro format files to load after the defaults')
> - print('--log file : Log file where all build out is written too')
> - print('--url url[,url] : URL to look for source')
> - print('--no-download : Disable the source downloader')
> - print('--no-install : Do not install the packages to the prefix')
> - print('--targetcflags flags : List of C flags for the target code')
> - print('--targetcxxflags flags : List of C++ flags for the target code')
> - print('--libstdcxxflags flags : List of C++ flags to build the target libstdc++ code')
> - print('--source-only-download : Only download the source')
> - print('--with-<label> : Add the --with-<label> to the build')
> - print('--without-<label> : Add the --without-<label> to the build')
> - print('--rtems-tools path : Path to an install RTEMS tool set')
> - print('--rtems-bsp arc/bsp : Standard RTEMS architecure and BSP specifier')
> - print('--rtems-version ver : The RTEMS major/minor version string')
> + print('--force : Force the build to proceed')
> + print('--quiet : Quiet output (not used)')
> + print('--trace : Trace the execution')
> + print('--dry-run : Do everything but actually run the build')
> + print('--warn-all : Generate warnings')
> + print('--no-clean : Do not clean up the build tree')
> + print('--always-clean : Always clean the build tree, even with an error')
> + print('--keep-going : Do not stop on an error.')
> + print('--regression : Set --no-install, --keep-going and --always-clean')
> + print('--jobs : Run with specified number of jobs, default: num CPUs.')
> + print('--host : Set the host triplet')
> + print('--build : Set the build triplet')
> + print('--target : Set the target triplet')
> + print('--prefix path : Tools build prefix, ie where they are installed')
> + print('--topdir path : Top of the build tree, default is $PWD')
> + print('--configdir path : Path to the configuration directory, default: ./config')
> + print('--builddir path : Path to the build directory, default: ./build')
> + print('--sourcedir path : Path to the source directory, default: ./source')
> + print('--patchdir path : Path to the patches directory, default: ./patches')
> + print('--tmppath path : Path to the temp directory, default: ./tmp')
> + print('--macros file[,[file] : Macro format files to load after the defaults')
> + print('--log file : Log file where all build out is written too')
> + print('--with-rtems-bsp-config : Configuration file to use')
> + print('--url url[,url] : URL to look for source')
> + print('--no-download : Disable the source downloader')
> + print('--no-install : Do not install the packages to the prefix')
> + print('--targetcflags flags : List of C flags for the target code')
> + print('--targetcxxflags flags : List of C++ flags for the target code')
> + print('--libstdcxxflags flags : List of C++ flags to build the target libstdc++ code')
> + print('--source-only-download : Only download the source')
> + print('--with-<label> : Add the --with-<label> to the build')
> + print('--without-<label> : Add the --without-<label> to the build')
> + print('--rtems-tools path : Path to an install RTEMS tool set')
> + print('--rtems-bsp arc/bsp : Standard RTEMS architecure and BSP specifier')
> + print('--rtems-version ver : The RTEMS major/minor version string')
> if self.optargs:
> for a in self.optargs:
> print('%-22s : %s' % (a, self.optargs[a]))
