[PATCH RSB v2] rtems-kernel: Implement kernel recipe using waf
Tue Nov 2 22:14:28 UTC 2021
On 3/11/21 4:13 am, Ryan Long wrote:
> -----Original Message-----
> From: Chris Johns <chrisj at rtems.org>
> Sent: Monday, November 1, 2021 8:48 PM
> To: Ryan Long <ryan.long at oarcorp.com>; devel at rtems.org
> Subject: Re: [PATCH RSB v2] rtems-kernel: Implement kernel recipe using waf
> On 28/10/21 2:09 am, Ryan Long wrote:
>> + %define rtems_bsp
>> + %(%{_topdir}/../source-builder/rtems-kernel-config-check -b
>> + %{with_rtems_bsp_config})
> How are config file errors handled? I normally return `ERROR` or something that can be checked.
> [Ryan Long] Right now the script is handling all the errors. I'll add some error checking to rtems-kernel-common.cfg.
And if the helper script finds and error what happens to the RSB build?
