[RSB v1 0/2] Update rtems-tools and move dtc to base set
Sun Nov 7 22:18:26 UTC 2021
Hi
I'm putting these out for review while the tools are still building.
If anyone sees an issue with these, I am sure you will comment. :)
Otherwise, I am likely to push these Tuesday.
--joel
Joel Sherrill (2):
  rtems-tools-6.cfg: Bump rtems-tools hash
  config/[67]/rtems-*.bset: Move dtc to default set
 rtems/config/6/rtems-default.bset    | 2 ++
 rtems/config/6/rtems-microblaze.bset | 2 --
 rtems/config/6/rtems-moxie.bset      | 1 -
 rtems/config/7/rtems-default.bset    | 2 ++
 rtems/config/7/rtems-moxie.bset      | 1 -
 rtems/config/tools/rtems-tools-6.cfg | 4 ++--
 6 files changed, 6 insertions(+), 6 deletions(-)
2.24.4
