[RSB v1 1/2] rtems-tools-6.cfg: Bump rtems-tools hash
Sun Nov 7 22:18:27 UTC 2021
 rtems/config/tools/rtems-tools-6.cfg | 4 ++--
 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/rtems/config/tools/rtems-tools-6.cfg b/rtems/config/tools/rtems-tools-6.cfg
index 4158753..6d05d12 100644
--- a/rtems/config/tools/rtems-tools-6.cfg
+++ b/rtems/config/tools/rtems-tools-6.cfg
@@ -10,14 +10,14 @@
  %define rtems_tools_source rtems-tools-%{rtems_tools_version}
  %define rtems_tools_ext xz
 %else
- %define rtems_tools_version 323007a6b520140a20b2e268c90b78ff67afaf45
+ %define rtems_tools_version d1df4f6e02fe22d2cb542adbd6ba4248ee077892
  %define rtems_tools_ext bz2
 %endif
 %source set rtems-tools https://git.rtems.org/rtems-tools/snapshot/%{rtems_tools_source}.tar.%{rtems_tools_ext}
 %hash   sha512 rtems-tools-%{rtems_tools_version}.tar.bz2 \
-         yo5i1HEaYyOOX8JJGr+kok0vIEZGpXjeZmA44gqTow101PhtlwhebvgTS0SeMe8L68wTDqdjZe5QVnsjKgYOhw==
+         zhSEMRbpLdeDTg6RI5U1e/TU9FsN09cS/NPQrXCMU6QJsCdDWIzA0HwTq54/apM7RW38uQkmaW9cPk5RVU3e1A==
 # Optionally enable/disable building the RTEMS Tools via the command line.
2.24.4
