[PATCH 00/26] Synchronize timecounter with FreeBSD
Sebastian Huber
Mon Nov 8 06:27:28 UTC 2021
This patch set synchronizes kern_tc.c with the latest FreeBSD version.
Some changes were discussed on a FreeBSD mailing list. Two patches were
integrated in FreeBSD which help using the timecounters in RTEMS.
One patch adds a callback registration for NTP support.
Andrew Turner (1):
Create a new macro for static DPCPU data.
Brooks Davis (1):
Move most of the contents of opt_compat.h
Ed Maste (1):
Remove "All Rights Reserved" from
Konstantin Belousov (7):
Use atomic_load(9) to read ppsinfo sequence numbers.
Make timehands count selectable at boottime.
Initialize timehands linkage much earlier.
Consolidate read code for timecounters
Remove double-calls to tc_get_timecount()
Add ddb 'show timecounter' command.
Make kern.timecounter.hardware tunable
Mark Johnston (3):
timecounter: Let kern.timecounter.stepwarnings be set as a tunable
timecounter: Lock the timecounter list
timecounter: Load the currently selected tc once in tc_windup()
Mateusz Guzik (2):
tc: bcopy -> memcpy
Remove duplicated empty lines from kern/*.c
Olivier Houchard (1):
Instead of using an incomplete list of platforms
Pawel Biernacki (1):
Mark more nodes as CTLFLAG_MPSAFE
Pedro F. Giffuni (1):
SPDX: use the Beerware identifier.
Robert Watson (1):
Changes that improve DTrace FBT reliability
Sebastian Huber (6):
score: Remove FreeBSD identifier
kern_tc.c: Scaling/large delta recalculation
score: Initialize timehand generation to UINT_MAX
score: Port large time delta support to RTEMS
score: Optimize timehand updates for non-SMP
score: Add _Timecounter_Set_NTP_update_second()
Warner Losh (1):
kern: clarify boot time
cpukit/include/rtems/score/timecounter.h | 24 +-
cpukit/score/src/kern_tc.c | 677 ++++++++++++++--------
testsuites/sptests/sptimecounter01/init.c | 4 +-
3 files changed, 449 insertions(+), 256 deletions(-)
2.31.1
