[RSB v1 2/2] config/[67]/rtems-*.bset: Move dtc to default set
Joel Sherrill
joel at rtems.org
Sun Nov 7 22:18:28 UTC 2021
rtems/config/6/rtems-default.bset | 2 ++
rtems/config/6/rtems-microblaze.bset | 2 --
rtems/config/6/rtems-moxie.bset | 1 -
rtems/config/7/rtems-default.bset | 2 ++
rtems/config/7/rtems-moxie.bset | 1 -
5 files changed, 4 insertions(+), 4 deletions(-)
diff --git a/rtems/config/6/rtems-default.bset b/rtems/config/6/rtems-default.bset
index 8bf6922..5ee1daf 100644
--- a/rtems/config/6/rtems-default.bset
+++ b/rtems/config/6/rtems-default.bset
@@ -8,6 +8,8 @@
# GDB needs expat so it needs to be built before.
+devel/dtc-1.6.0-1
devel/expat-2.1.0-1
devel/gmp-6.1.0
tools/rtems-gdb-10
diff --git a/rtems/config/6/rtems-microblaze.bset b/rtems/config/6/rtems-microblaze.bset
index 3eb7a89..4e88043 100644
--- a/rtems/config/6/rtems-microblaze.bset
+++ b/rtems/config/6/rtems-microblaze.bset
@@ -6,8 +6,6 @@
%include 6/rtems-base.bset
-devel/dtc-1.6.0-1
# Build gdb first to raise the Python install error as early as possible.
diff --git a/rtems/config/6/rtems-moxie.bset b/rtems/config/6/rtems-moxie.bset
index a191c5d..c86777e 100644
--- a/rtems/config/6/rtems-moxie.bset
+++ b/rtems/config/6/rtems-moxie.bset
@@ -2,5 +2,4 @@
%define rtems_arch moxie
%define win32-gdb-disable-sim
%define with_libgomp
-devel/dtc-1.6.0-1
%include 6/rtems-default.bset
diff --git a/rtems/config/7/rtems-default.bset b/rtems/config/7/rtems-default.bset
index acb7059..69bdd5b 100644
--- a/rtems/config/7/rtems-default.bset
+++ b/rtems/config/7/rtems-default.bset
@@ -5,6 +5,8 @@
+devel/dtc-1.6.0-1
devel/expat-2.1.0-1
devel/gmp-6.1.0
tools/rtems-gdb-head
diff --git a/rtems/config/7/rtems-moxie.bset b/rtems/config/7/rtems-moxie.bset
index 60fe7f4..8cd3642 100644
--- a/rtems/config/7/rtems-moxie.bset
+++ b/rtems/config/7/rtems-moxie.bset
@@ -2,5 +2,4 @@
-devel/dtc-1.6.0-1
%include 7/rtems-default.bset
2.24.4
