[PATCH v2] c-user: Document new clock manager directives
Tue Nov 9 02:46:22 UTC 2021
On 20/10/21 2:25 am, Sebastian Huber wrote:
> Add new clock manager directives to get all times provided by the
> timehands.
> Update #4527.
> For an updated document to review see:
> https://ftp.rtems.org/pub/rtems/people/sebh/c-user.pdf
> v2: Clarify boot time.
>  c-user/clock/directives.rst   | 835 ++++++++++++++++++++++++++++++++++
>  c-user/clock/introduction.rst |  81 ++++
>  2 files changed, 916 insertions(+)
> diff --git a/c-user/clock/directives.rst b/c-user/clock/directives.rst
> index bdb7680..8f2d7ea 100644
> --- a/c-user/clock/directives.rst
> +++ b/c-user/clock/directives.rst
> @@ -224,6 +224,841 @@ The following constraints apply to this directive:
>    Applications which are restricted to only use interfaces of the pre-qualified
>    feature set of RTEMS shall not use the directive.
> +.. Generated from spec:/rtems/clock/if/get-realtime
> +.. raw:: latex
> +    \clearpage
> +.. index:: rtems_clock_get_realtime()
> +.. _InterfaceRtemsClockGetRealtime:
> +rtems_clock_get_realtime()
> +Gets the time elapsed since the :term:`Unix epoch` measured using
> +:term:`CLOCK_REALTIME` in seconds and nanoseconds format.
> +.. rubric:: CALLING SEQUENCE:
> +.. code-block:: c
> +    void rtems_clock_get_realtime( struct timespec *time_snapshot );
> +.. rubric:: PARAMETERS:
> +``time_snapshot``
> +    This parameter is the pointer to a `struct timespec
> +    <https://en.cppreference.com/w/c/chrono/timespec>`_ object. The time> +    elapsed since the :term:`Unix epoch` measured using the
> +    :term:`CLOCK_REALTIME` at some time point during the directive call will be
> +    stored in this object.  Calling the directive with a pointer equal to `NULL
> +    <https://en.cppreference.com/w/c/types/NULL>`_ is undefined behaviour.
Why not return an invalid error status? Same question for the same thing below.
> +.. rubric:: NOTES:
> +The directive accesses a device provided by the :term:`Clock Driver` to get the
> +time in the highest precision available to the system.  Alternatively, the
> +:ref:`InterfaceRtemsClockGetRealtimeCoarse` directive may be used to get the
> +time with less precision and less runtime overhead.
> +See :ref:`InterfaceRtemsClockGetRealtimeBintime` and
> +:ref:`InterfaceRtemsClockGetRealtimeTimeval` to get the time in alternative
> +formats.
> +.. rubric:: CONSTRAINTS:
> +The following constraints apply to this directive:
> +* The directive may be called from within any runtime context.
> +* The directive will not cause the calling task to be preempted.
> +* The directive requires a :term:`Clock Driver`.
> +.. Generated from spec:/rtems/clock/if/get-realtime-bintime
> +.. raw:: latex
> +    \clearpage
> +.. index:: rtems_clock_get_realtime_bintime()
> +.. _InterfaceRtemsClockGetRealtimeBintime:
> +rtems_clock_get_realtime_bintime()
> +:term:`CLOCK_REALTIME` in binary time format.
> +.. code-block:: c
> +    void rtems_clock_get_realtime_bintime( struct bintime *time_snapshot );
> +``time_snapshot``
> +    This parameter is the pointer to a :c:type:`bintime` object.  The time
> +.. rubric:: NOTES:
> +:ref:`InterfaceRtemsClockGetRealtimeCoarseBintime` directive may be used to get
> +the time with less precision and less runtime overhead.
> +See :ref:`InterfaceRtemsClockGetRealtime` and
> +formats.
> +.. Generated from spec:/rtems/clock/if/get-realtime-timeval
> +.. raw:: latex
> +    \clearpage
> +.. index:: rtems_clock_get_realtime_timeval()
> +.. _InterfaceRtemsClockGetRealtimeTimeval:
> +rtems_clock_get_realtime_timeval()
> +:term:`CLOCK_REALTIME` in seconds and microseconds format.
> +.. code-block:: c
> +    void rtems_clock_get_realtime_timeval( struct timeval *time_snapshot );
> +``time_snapshot``
> +    This parameter is the pointer to a `struct timeval
> +    <https://pubs.opengroup.org/onlinepubs/009695399/basedefs/sys/time.h.html>`_
> +    object.  The time elapsed since the :term:`Unix epoch` measured using the
> +.. rubric:: NOTES:
> +:ref:`InterfaceRtemsClockGetRealtimeCoarseTimeval` directive may be used to get
> +:ref:`InterfaceRtemsClockGetRealtimeBintime` to get the time in alternative
> +formats.
> +.. Generated from spec:/rtems/clock/if/get-realtime-coarse
> +.. raw:: latex
> +    \clearpage
> +.. index:: rtems_clock_get_realtime_coarse()
> +.. _InterfaceRtemsClockGetRealtimeCoarse:
> +rtems_clock_get_realtime_coarse()
> +:term:`CLOCK_REALTIME` in coarse precision in seconds and nanoseconds format.
> +.. code-block:: c
> +    void rtems_clock_get_realtime_coarse( struct timespec *time_snapshot );
> +``time_snapshot``
> +    :term:`CLOCK_REALTIME` at some time point close to the directive call will
> +    be stored in this object.  Calling the directive with a pointer equal to
> +    `NULL <https://en.cppreference.com/w/c/types/NULL>`_ is undefined
> +    behaviour.
> +.. rubric:: NOTES:
> +The directive does not access a device to get the time.  It uses a recent
> +snapshot provided by the :term:`Clock Driver`.  Alternatively, the
> +:ref:`InterfaceRtemsClockGetRealtime` directive may be used to get the time
> +with higher precision and higher runtime overhead.
> +See :ref:`InterfaceRtemsClockGetRealtimeCoarseBintime` and
> +:ref:`InterfaceRtemsClockGetRealtimeCoarseTimeval` to get the time in
> +alternative formats.
> +.. Generated from spec:/rtems/clock/if/get-realtime-coarse-bintime
> +.. raw:: latex
> +    \clearpage
> +.. index:: rtems_clock_get_realtime_coarse_bintime()
> +.. _InterfaceRtemsClockGetRealtimeCoarseBintime:
> +rtems_clock_get_realtime_coarse_bintime()
> +:term:`CLOCK_REALTIME` in coarse precision in binary time format.
> +.. code-block:: c
> +    void rtems_clock_get_realtime_coarse_bintime( struct bintime *time_snapshot );
> +``time_snapshot``
> +    behaviour.
> +.. rubric:: NOTES:
> +:ref:`InterfaceRtemsClockGetRealtimeBintime` directive may be used to get the
> +time with higher precision and higher runtime overhead.
> +See :ref:`InterfaceRtemsClockGetRealtimeCoarse` and
> +.. Generated from spec:/rtems/clock/if/get-realtime-coarse-timeval
> +.. raw:: latex
> +    \clearpage
> +.. index:: rtems_clock_get_realtime_coarse_timeval()
> +.. _InterfaceRtemsClockGetRealtimeCoarseTimeval:
> +rtems_clock_get_realtime_coarse_timeval()
> +:term:`CLOCK_REALTIME` in coarse precision in seconds and microseconds format.
> +.. code-block:: c
> +    void rtems_clock_get_realtime_coarse_timeval( struct timeval *time_snapshot );
> +``time_snapshot``
> +    behaviour.
> +.. rubric:: NOTES:
> +:ref:`InterfaceRtemsClockGetRealtimeTimeval` directive may be used to get the
> +.. Generated from spec:/rtems/clock/if/get-monotonic
> +.. raw:: latex
> +    \clearpage
> +.. index:: rtems_clock_get_monotonic()
> +.. _InterfaceRtemsClockGetMonotonic:
> +rtems_clock_get_monotonic()
> +Gets the time elapsed since some fixed time point in the past measured using
> +the :term:`CLOCK_MONOTONIC` in seconds and nanoseconds format.
> +.. code-block:: c
> +    void rtems_clock_get_monotonic( struct timespec *time_snapshot );
> +``time_snapshot``
> +    elapsed since some fixed time point in the past measured using the
> +    :term:`CLOCK_MONOTONIC` at some time point during the directive call will
> +    behaviour.
> +.. rubric:: NOTES:
> +:ref:`InterfaceRtemsClockGetMonotonicCoarse` directive may be used to get the
> +See :ref:`InterfaceRtemsClockGetMonotonicBintime`,
> +:ref:`InterfaceRtemsClockGetMonotonicSbintime`, and
> +:ref:`InterfaceRtemsClockGetMonotonicTimeval` to get the time in alternative
> +formats.
> +.. Generated from spec:/rtems/clock/if/get-monotonic-bintime
> +.. raw:: latex
> +    \clearpage
> +.. index:: rtems_clock_get_monotonic_bintime()
> +.. _InterfaceRtemsClockGetMonotonicBintime:
> +rtems_clock_get_monotonic_bintime()
> +the :term:`CLOCK_MONOTONIC` in binary time format.
> +.. code-block:: c
> +    void rtems_clock_get_monotonic_bintime( struct bintime *time_snapshot );
> +``time_snapshot``
> +    behaviour.
> +.. rubric:: NOTES:
> +:ref:`InterfaceRtemsClockGetMonotonicCoarseBintime` directive may be used to
> +get the time with less precision and less runtime overhead.
> +See :ref:`InterfaceRtemsClockGetMonotonic`,
> +formats.
> +.. Generated from spec:/rtems/clock/if/get-monotonic-sbintime
> +.. raw:: latex
> +    \clearpage
> +.. index:: rtems_clock_get_monotonic_sbintime()
> +.. _InterfaceRtemsClockGetMonotonicSbintime:
> +rtems_clock_get_monotonic_sbintime()
> +the :term:`CLOCK_MONOTONIC` in signed binary time format.
> +.. code-block:: c
> +    int64_t rtems_clock_get_monotonic_sbintime( void );
> +.. rubric:: RETURN VALUES:
> +Returns the time elapsed since some fixed time point in the past measured using
> +the :term:`CLOCK_MONOTONIC` at some time point during the directive call.
> +.. rubric:: NOTES:
> +:ref:`InterfaceRtemsClockGetMonotonicBintime`, and
> +formats.
> +.. Generated from spec:/rtems/clock/if/get-monotonic-timeval
> +.. raw:: latex
> +    \clearpage
> +.. index:: rtems_clock_get_monotonic_timeval()
> +.. _InterfaceRtemsClockGetMonotonicTimeval:
> +rtems_clock_get_monotonic_timeval()
> +the :term:`CLOCK_MONOTONIC` in seconds and microseconds format.
> +.. code-block:: c
> +    void rtems_clock_get_monotonic_timeval( struct timeval *time_snapshot );
> +``time_snapshot``
> +    behaviour.
> +.. rubric:: NOTES:
> +:ref:`InterfaceRtemsClockGetMonotonicCoarseTimeval` directive may be used to
> +:ref:`InterfaceRtemsClockGetMonotonicSbintime` to get the time in alternative
> +formats.
> +.. Generated from spec:/rtems/clock/if/get-monotonic-coarse
> +.. raw:: latex
> +    \clearpage
> +.. index:: rtems_clock_get_monotonic_coarse()
> +.. _InterfaceRtemsClockGetMonotonicCoarse:
> +rtems_clock_get_monotonic_coarse()
> +the :term:`CLOCK_MONOTONIC` in coarse precision in seconds and nanoseconds
> +format.
> +.. code-block:: c
> +    void rtems_clock_get_monotonic_coarse( struct timespec *time_snapshot );
> +``time_snapshot``
> +    :term:`CLOCK_MONOTONIC` at some time point close to the directive call will
> +    behaviour.
> +.. rubric:: NOTES:
> +:ref:`InterfaceRtemsClockGetMonotonic` directive may be used to get the time
> +See :ref:`InterfaceRtemsClockGetMonotonicCoarseBintime` and
> +:ref:`InterfaceRtemsClockGetMonotonicCoarseTimeval` to get the time in
> +.. Generated from spec:/rtems/clock/if/get-monotonic-coarse-bintime
> +.. raw:: latex
> +    \clearpage
> +.. index:: rtems_clock_get_monotonic_coarse_bintime()
> +.. _InterfaceRtemsClockGetMonotonicCoarseBintime:
> +rtems_clock_get_monotonic_coarse_bintime()
> +the :term:`CLOCK_MONOTONIC` in coarse precision in binary time format.
> +.. code-block:: c
> +    void rtems_clock_get_monotonic_coarse_bintime( struct bintime *time_snapshot );
> +``time_snapshot``
> +    behaviour.
> +.. rubric:: NOTES:
> +:ref:`InterfaceRtemsClockGetMonotonicBintime` directive may be used to get the
> +See :ref:`InterfaceRtemsClockGetMonotonicCoarse` and
> +.. Generated from spec:/rtems/clock/if/get-monotonic-coarse-timeval
> +.. raw:: latex
> +    \clearpage
> +.. index:: rtems_clock_get_monotonic_coarse_timeval()
> +.. _InterfaceRtemsClockGetMonotonicCoarseTimeval:
> +rtems_clock_get_monotonic_coarse_timeval()
> +the :term:`CLOCK_MONOTONIC` in coarse precision in seconds and microseconds
> +format.
> +.. code-block:: c
> +    void rtems_clock_get_monotonic_coarse_timeval( struct timeval *time_snapshot );
> +``time_snapshot``
> +    behaviour.
> +.. rubric:: NOTES:
> +:ref:`InterfaceRtemsClockGetMonotonicTimeval` directive may be used to get the
> +:ref:`InterfaceRtemsClockGetMonotonicCoarseBintime` to get the time in
> +.. Generated from spec:/rtems/clock/if/get-boot-time
> +.. raw:: latex
> +    \clearpage
> +.. index:: rtems_clock_get_boot_time()
> +.. _InterfaceRtemsClockGetBootTime:
> +rtems_clock_get_boot_time()
> +Gets the time elapsed since the :term:`Unix epoch` at some time point during
> +system initialization in seconds and nanoseconds format.
> +.. code-block:: c
> +    void rtems_clock_get_boot_time( struct timespec *boot_time );
> +``boot_time``
> +    elapsed since the :term:`Unix epoch` at some time point during system
> +    initialization call will be stored in this object.  Calling the directive
> +    with a pointer equal to `NULL
> +.. rubric:: NOTES:
> +See :ref:`InterfaceRtemsClockGetBootTimeBintime` and
> +:ref:`InterfaceRtemsClockGetBootTimeTimeval` to get the boot time in
> +alternative formats.  Setting the :term:`CLOCK_REALTIME` will also set the boot
> +time.
> +.. Generated from spec:/rtems/clock/if/get-boot-time-bintime
> +.. raw:: latex
> +    \clearpage
> +.. index:: rtems_clock_get_boot_time_bintime()
> +.. _InterfaceRtemsClockGetBootTimeBintime:
> +rtems_clock_get_boot_time_bintime()
> +system initialization in binary time format.
> +.. code-block:: c
> +    void rtems_clock_get_boot_time_bintime( struct bintime *boot_time );
> +``boot_time``
> +.. rubric:: NOTES:
> +See :ref:`InterfaceRtemsClockGetBootTime` and
> +time.
> +.. Generated from spec:/rtems/clock/if/get-boot-time-timeval
> +.. raw:: latex
> +    \clearpage
> +.. index:: rtems_clock_get_boot_time_timeval()
> +.. _InterfaceRtemsClockGetBootTimeTimeval:
> +rtems_clock_get_boot_time_timeval()
> +system initialization in seconds and microseconds format.
> +.. code-block:: c
> +    void rtems_clock_get_boot_time_timeval( struct timeval *boot_time );
> +``boot_time``
> +    object.  The time elapsed since the :term:`Unix epoch` at some time point
> +    during system initialization call will be stored in this object.  Calling
> +    the directive with a pointer equal to `NULL
> +.. rubric:: NOTES:
> +:ref:`InterfaceRtemsClockGetBootTimeBintime` to get the boot time in
> +time.
>  .. Generated from spec:/rtems/clock/if/get-seconds-since-epoch
>  .. raw:: latex
> diff --git a/c-user/clock/introduction.rst b/c-user/clock/introduction.rst
> index ad4b14c..cfc8871 100644
> --- a/c-user/clock/introduction.rst
> +++ b/c-user/clock/introduction.rst
> @@ -29,6 +29,22 @@ Introduction
>  .. spec:/rtems/clock/if/set
>  .. spec:/rtems/clock/if/get-tod
>  .. spec:/rtems/clock/if/get-tod-timeval
> +.. spec:/rtems/clock/if/get-realtime
> +.. spec:/rtems/clock/if/get-realtime-bintime
> +.. spec:/rtems/clock/if/get-realtime-timeval
> +.. spec:/rtems/clock/if/get-realtime-coarse
> +.. spec:/rtems/clock/if/get-realtime-coarse-bintime
> +.. spec:/rtems/clock/if/get-realtime-coarse-timeval
> +.. spec:/rtems/clock/if/get-monotonic
> +.. spec:/rtems/clock/if/get-monotonic-bintime
> +.. spec:/rtems/clock/if/get-monotonic-sbintime
> +.. spec:/rtems/clock/if/get-monotonic-timeval
> +.. spec:/rtems/clock/if/get-monotonic-coarse
> +.. spec:/rtems/clock/if/get-monotonic-coarse-bintime
> +.. spec:/rtems/clock/if/get-monotonic-coarse-timeval
> +.. spec:/rtems/clock/if/get-boot-time
> +.. spec:/rtems/clock/if/get-boot-time-bintime
> +.. spec:/rtems/clock/if/get-boot-time-timeval
>  .. spec:/rtems/clock/if/get-seconds-since-epoch
>  .. spec:/rtems/clock/if/get-ticks-per-second
>  .. spec:/rtems/clock/if/get-ticks-since-boot
> @@ -52,6 +68,71 @@ capabilities. The directives provided by the Clock Manager are:
>  * :ref:`InterfaceRtemsClockGetTodTimeval` - Gets the seconds and microseconds
>    elapsed since the :term:`Unix epoch` and the current :term:`CLOCK_REALTIME`.
> +* :ref:`InterfaceRtemsClockGetRealtime` - Gets the time elapsed since the
> +  :term:`Unix epoch` measured using :term:`CLOCK_REALTIME` in seconds and
> +  nanoseconds format.
> +* :ref:`InterfaceRtemsClockGetRealtimeBintime` - Gets the time elapsed since
> +  the :term:`Unix epoch` measured using :term:`CLOCK_REALTIME` in binary time
> +  format.
> +* :ref:`InterfaceRtemsClockGetRealtimeTimeval` - Gets the time elapsed since
> +  the :term:`Unix epoch` measured using :term:`CLOCK_REALTIME` in seconds and
> +  microseconds format.
> +* :ref:`InterfaceRtemsClockGetRealtimeCoarse` - Gets the time elapsed since the
> +  :term:`Unix epoch` measured using :term:`CLOCK_REALTIME` in coarse precision
> +  in seconds and nanoseconds format.
> +* :ref:`InterfaceRtemsClockGetRealtimeCoarseBintime` - Gets the time elapsed
> +  since the :term:`Unix epoch` measured using :term:`CLOCK_REALTIME` in coarse
> +  precision in binary time format.
> +* :ref:`InterfaceRtemsClockGetRealtimeCoarseTimeval` - Gets the time elapsed
> +  precision in seconds and microseconds format.
> +* :ref:`InterfaceRtemsClockGetMonotonic` - Gets the time elapsed since some
> +  fixed time point in the past measured using the :term:`CLOCK_MONOTONIC` in
> +  seconds and nanoseconds format.
> +* :ref:`InterfaceRtemsClockGetMonotonicBintime` - Gets the time elapsed since
> +  some fixed time point in the past measured using the :term:`CLOCK_MONOTONIC`
> +  in binary time format.
> +* :ref:`InterfaceRtemsClockGetMonotonicSbintime` - Gets the time elapsed since
> +  in signed binary time format.
> +* :ref:`InterfaceRtemsClockGetMonotonicTimeval` - Gets the time elapsed since
> +  in seconds and microseconds format.
> +* :ref:`InterfaceRtemsClockGetMonotonicCoarse` - Gets the time elapsed since
> +  in coarse precision in seconds and nanoseconds format.
> +* :ref:`InterfaceRtemsClockGetMonotonicCoarseBintime` - Gets the time elapsed
> +  since some fixed time point in the past measured using the
> +  :term:`CLOCK_MONOTONIC` in coarse precision in binary time format.
> +* :ref:`InterfaceRtemsClockGetMonotonicCoarseTimeval` - Gets the time elapsed
> +  :term:`CLOCK_MONOTONIC` in coarse precision in seconds and microseconds
> +  format.
> +* :ref:`InterfaceRtemsClockGetBootTime` - Gets the time elapsed since the
> +  :term:`Unix epoch` at some time point during system initialization in seconds
> +  and nanoseconds format.
> +* :ref:`InterfaceRtemsClockGetBootTimeBintime` - Gets the time elapsed since
> +  the :term:`Unix epoch` at some time point during system initialization in
> +  binary time format.
> +* :ref:`InterfaceRtemsClockGetBootTimeTimeval` - Gets the time elapsed since
> +  seconds and microseconds format.
>  * :ref:`InterfaceRtemsClockGetSecondsSinceEpoch` - Gets the seconds elapsed
>    since the :term:`RTEMS epoch` and the current :term:`CLOCK_REALTIME`.
