[PATCH v2] c-user: Document new clock manager directives
Tue Nov 9 06:57:56 UTC 2021
On 09/11/2021 03:46, Chris Johns wrote:
> On 20/10/21 2:25 am, Sebastian Huber wrote:
>> Add new clock manager directives to get all times provided by the
>> timehands.
>> Update #4527.
>> For an updated document to review see:
>> https://ftp.rtems.org/pub/rtems/people/sebh/c-user.pdf
>> v2: Clarify boot time.
>>   c-user/clock/directives.rst   | 835 ++++++++++++++++++++++++++++++++++
>>   c-user/clock/introduction.rst |  81 ++++
>>   2 files changed, 916 insertions(+)
>> diff --git a/c-user/clock/directives.rst b/c-user/clock/directives.rst
>> index bdb7680..8f2d7ea 100644
>> --- a/c-user/clock/directives.rst
>> +++ b/c-user/clock/directives.rst
>> @@ -224,6 +224,841 @@ The following constraints apply to this directive:
>>     Applications which are restricted to only use interfaces of the pre-qualified
>>     feature set of RTEMS shall not use the directive.
>> +.. Generated from spec:/rtems/clock/if/get-realtime
>> +.. raw:: latex
>> +    \clearpage
>> +.. index:: rtems_clock_get_realtime()
>> +.. _InterfaceRtemsClockGetRealtime:
>> +rtems_clock_get_realtime()
>> +Gets the time elapsed since the :term:`Unix epoch` measured using
>> +:term:`CLOCK_REALTIME` in seconds and nanoseconds format.
>> +.. rubric:: CALLING SEQUENCE:
>> +.. code-block:: c
>> +    void rtems_clock_get_realtime( struct timespec *time_snapshot );
>> +.. rubric:: PARAMETERS:
>> +``time_snapshot``
>> +    This parameter is the pointer to a `struct timespec
>> +<https://en.cppreference.com/w/c/chrono/timespec>`_ object. The time> +    elapsed since the :term:`Unix epoch` measured using the
>> +    :term:`CLOCK_REALTIME` at some time point during the directive call will be
>> +    stored in this object.  Calling the directive with a pointer equal to `NULL
>> +<https://en.cppreference.com/w/c/types/NULL>`_ is undefined behaviour.
> Why not return an invalid error status? Same question for the same thing below.
I just documented the existing implementation. If you want an error
status and NULL pointer checks, then we have to add a wrapper function
around the FreeBSD interface. We still have to export the FreeBSD
interface since it is used by libbsd.
The functions just have a single parameter and no return value
currently. Why would someone pass a NULL pointer to such functions?
We could also change
RTEMS_ALIAS(_Timecounter_Nanotime)
void rtems_clock_get_realtime(struct timespec *);
to
rtems_status_code
rtems_clock_get_realtime(struct timespec *time_snapshot)
   if ( time_snapshot == NULL ) {
     return RTEMS_INVALID_ADDRESS;
   _Timecounter_Nanotime( time_snapshot );
   return RTEMS_SUCCESSFUL;
However, this is less efficient. You need an extra comparison, a branch,
a stack frame, push/pop of the return address, and an extra function call.
We could also use something like this:
static inline struct timespec rtems_clock_get_realtime(void)
   struct timespec time_snapshot;
   _Timecounter_Nanotime( &time_snapshot );
   return time_snapshot;
Unfortunately GCC is not able to optimize this.
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax:   +49-89-18 94 741 - 08
Registernummer: HRB 157899
