[PATCH v2] c-user: Document new clock manager directives
Tue Nov 9 07:41:07 UTC 2021
On 9/11/21 5:57 pm, Sebastian Huber wrote:
> On 09/11/2021 03:46, Chris Johns wrote:
>> On 20/10/21 2:25 am, Sebastian Huber wrote:
>>> Add new clock manager directives to get all times provided by the
>>> timehands.
>>> Update #4527.
>>> For an updated document to review see:
>>> https://ftp.rtems.org/pub/rtems/people/sebh/c-user.pdf
>>> v2: Clarify boot time.
>>>   c-user/clock/directives.rst   | 835 ++++++++++++++++++++++++++++++++++
>>>   c-user/clock/introduction.rst |  81 ++++
>>>   2 files changed, 916 insertions(+)
>>> diff --git a/c-user/clock/directives.rst b/c-user/clock/directives.rst
>>> index bdb7680..8f2d7ea 100644
>>> --- a/c-user/clock/directives.rst
>>> +++ b/c-user/clock/directives.rst
>>> @@ -224,6 +224,841 @@ The following constraints apply to this directive:
>>>     Applications which are restricted to only use interfaces of the
>>> pre-qualified
>>>     feature set of RTEMS shall not use the directive.
>>>   +.. Generated from spec:/rtems/clock/if/get-realtime
>>> +.. raw:: latex
>>> +    \clearpage
>>> +.. index:: rtems_clock_get_realtime()
>>> +.. _InterfaceRtemsClockGetRealtime:
>>> +rtems_clock_get_realtime()
>>> +Gets the time elapsed since the :term:`Unix epoch` measured using
>>> +:term:`CLOCK_REALTIME` in seconds and nanoseconds format.
>>> +.. rubric:: CALLING SEQUENCE:
>>> +.. code-block:: c
>>> +    void rtems_clock_get_realtime( struct timespec *time_snapshot );
>>> +.. rubric:: PARAMETERS:
>>> +``time_snapshot``
>>> +    This parameter is the pointer to a `struct timespec
>>> +<https://en.cppreference.com/w/c/chrono/timespec>`_ object. The time> +
>>> elapsed since the :term:`Unix epoch` measured using the
>>> +    :term:`CLOCK_REALTIME` at some time point during the directive call will be
>>> +    stored in this object.  Calling the directive with a pointer equal to `NULL
>>> +<https://en.cppreference.com/w/c/types/NULL>`_ is undefined behaviour.
>> Why not return an invalid error status? Same question for the same thing below.
> I just documented the existing implementation. If you want an error status and
> NULL pointer checks, then we have to add a wrapper function around the FreeBSD
> interface. We still have to export the FreeBSD interface since it is used by
> libbsd.
Sure. I was only comparing this against the other APIs we have and a NULL is
checked.
> The functions just have a single parameter and no return value currently. Why
> would someone pass a NULL pointer to such functions?
> We could also change
> RTEMS_ALIAS(_Timecounter_Nanotime)
> void rtems_clock_get_realtime(struct timespec *);
> to
> rtems_status_code
> rtems_clock_get_realtime(struct timespec *time_snapshot)
>   if ( time_snapshot == NULL ) {
>     return RTEMS_INVALID_ADDRESS;
>   _Timecounter_Nanotime( time_snapshot );
>   return RTEMS_SUCCESSFUL;
> However, this is less efficient. You need an extra comparison, a branch, a stack
> frame, push/pop of the return address, and an extra function call.
> We could also use something like this:
> static inline struct timespec rtems_clock_get_realtime(void)
>   struct timespec time_snapshot;
>   _Timecounter_Nanotime( &time_snapshot );
>   return time_snapshot;
> Unfortunately GCC is not able to optimize this.
Ah OK. This can be fixed and the performance improved but once the API is set it
cannot change or do you think we can add a check later and not break the API?
