[PATCH v2] c-user: Document new clock manager directives
Sebastian Huber
Tue Nov 9 07:50:02 UTC 2021
On 09/11/2021 08:41, Chris Johns wrote:
>> We could also use something like this:
>> static inline struct timespec rtems_clock_get_realtime(void)
>> struct timespec time_snapshot;
>> _Timecounter_Nanotime( &time_snapshot );
>> return time_snapshot;
>> Unfortunately GCC is not able to optimize this.
> Ah OK. This can be fixed and the performance improved but once the API is set it
> cannot change or do you think we can add a check later and not break the API?
I filed a GCC bug for this:
https://gcc.gnu.org/bugzilla/show_bug.cgi?id=103150
It seems I was not the only one noticing issues related to structure
returns:
https://gcc.gnu.org/bugzilla/show_bug.cgi?id=101926
However, if we want a foolproof API, then I would prefer the structure
return over the return status and pointer argument. Compilers may get
better in the future. clang has similar issues, so this is not only a
GCC problem.
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax: +49-89-18 94 741 - 08
Registernummer: HRB 157899
