[PATCH v2] c-user: Document new clock manager directives
Thu Nov 11 07:02:01 UTC 2021
On 09/11/2021 13:06, Sebastian Huber wrote:
> On 09/11/2021 08:50, Sebastian Huber wrote:
>> On 09/11/2021 08:41, Chris Johns wrote:
>>>> We could also use something like this:
>>>> static inline struct timespec rtems_clock_get_realtime(void)
>>>>    struct timespec time_snapshot;
>>>>    _Timecounter_Nanotime( &time_snapshot );
>>>>    return time_snapshot;
>>>> Unfortunately GCC is not able to optimize this.
>>> Ah OK. This can be fixed and the performance improved but once the
>>> API is set it
>>> cannot change or do you think we can add a check later and not break
>>> the API?
>> I filed a GCC bug for this:
>> https://gcc.gnu.org/bugzilla/show_bug.cgi?id=103150
>> It seems I was not the only one noticing issues related to structure
>> returns:
>> https://gcc.gnu.org/bugzilla/show_bug.cgi?id=101926
>> However, if we want a foolproof API, then I would prefer the structure
>> return over the return status and pointer argument. Compilers may get
>> better in the future. clang has similar issues, so this is not only a
>> GCC problem.
> We have at least three options for the API:
> 1. Use the existing FreeBSD implementation as is:
> void rtems_clock_get_realtime(struct timespec *);
> This is the easiest and most efficient approach.
> 2. Check for NULL and return a status:
> rtems_status_code rtems_clock_get_realtime(struct timespec *);
> This requires a wrapper function which is a bit less efficient and needs
> more code/testing:
> rtems_status_code
> rtems_clock_get_realtime(struct timespec *time_snapshot)
>    if ( time_snapshot == NULL ) {
>      return RTEMS_INVALID_ADDRESS;
>    _Timecounter_Nanotime( time_snapshot );
>    return RTEMS_SUCCESSFUL;
> 3. Return the structure and use the existing implementation:
> This is currently not well supported by existing compilers:
4. Do nothing for a NULL pointer:
This requires a wrapper function which can use a tail call optimization:
void
     return;
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax:   +49-89-18 94 741 - 08
Registernummer: HRB 157899
