[PATCH v2] c-user: Document new clock manager directives
Sebastian Huber
Tue Nov 9 12:06:51 UTC 2021
On 09/11/2021 08:50, Sebastian Huber wrote:
> On 09/11/2021 08:41, Chris Johns wrote:
>>> We could also use something like this:
>>> static inline struct timespec rtems_clock_get_realtime(void)
>>> struct timespec time_snapshot;
>>> _Timecounter_Nanotime( &time_snapshot );
>>> return time_snapshot;
>>> Unfortunately GCC is not able to optimize this.
>> Ah OK. This can be fixed and the performance improved but once the API
>> is set it
>> cannot change or do you think we can add a check later and not break
>> the API?
> I filed a GCC bug for this:
> https://gcc.gnu.org/bugzilla/show_bug.cgi?id=103150
> It seems I was not the only one noticing issues related to structure
> returns:
> https://gcc.gnu.org/bugzilla/show_bug.cgi?id=101926
> However, if we want a foolproof API, then I would prefer the structure
> return over the return status and pointer argument. Compilers may get
> better in the future. clang has similar issues, so this is not only a
> GCC problem.
We have at least three options for the API:
1. Use the existing FreeBSD implementation as is:
void rtems_clock_get_realtime(struct timespec *);
This is the easiest and most efficient approach.
2. Check for NULL and return a status:
rtems_status_code rtems_clock_get_realtime(struct timespec *);
This requires a wrapper function which is a bit less efficient and needs
more code/testing:
rtems_status_code
rtems_clock_get_realtime(struct timespec *time_snapshot)
if ( time_snapshot == NULL ) {
return RTEMS_INVALID_ADDRESS;
_Timecounter_Nanotime( time_snapshot );
return RTEMS_SUCCESSFUL;
3. Return the structure and use the existing implementation:
This is currently not well supported by existing compilers:
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax: +49-89-18 94 741 - 08
Registernummer: HRB 157899
