Interested in working on ticket #2902, #4328, or #4334
Matthew Joyce
mfjoyce2004 at gmail.com
Fri Nov 12 11:53:32 UTC 2021
Hi Prateek,
>From the new methods that were added to the latest draft version of the
POSIX standard back around April, you might want to look at posix_getdents,
sem_clockwait, and ppoll. Those ones are still waiting to be added.
My blog post here (
https://mfjoyce2004.medium.com/adding-posix-apis-to-newlib-testing-with-rtems-280975508fb7)
hopefully might help you a little bit as you get started.
Take care and reach out if you have any questions!
Sincerely,
Matt
On Thu, Nov 11, 2021 at 7:06 PM Joel Sherrill <joel at rtems.org> wrote:
> On Thu, Nov 11, 2021 at 10:34 AM Prateek Pardeshi
> <prateekpardeshi9 at gmail.com> wrote:
> > Hello Everyone,
> > I doubt that my email went into spam. Sorry for the inconvenience.
> I have no idea. I know I have been swamped with work and personal matters.
> > Email link:
> > https://lists.rtems.org/pipermail/devel/2021-November/069853.html
> > From now on, I'll be using *Gmail* for sending emails on this list.
> Mostly it is a matter of using text format. Some clients do not do well
> with threaded discussions also.
> And now for the tickets:
> #2902 - Microblaze port
> I just closed this. The Microblaze port was recently merged. It has a
> BSP for HW and Qemu. Network support for libbsd and lwip should be
> close. libdl and libdebugger support are missing. libdl should be
> approachable.
> #4328 - New POSIX APIs from Issue 8 (2021/2022)
> Matthew Joyce worked on this list for GSoC 2021. I've cc'ed him for
> suggestions on which APIs make sense to tackle next.
> #4334 - Replace Mongoose with Civetweb
> Is still an open project. I'm not sure whether we would ultimately
> want a "cloned and owned" snapshot of civitweb or if it would make
> more sense to have an RSB package which could build it.
> It would be a change from the current usage pattern to have it
> from RSB, but that is likely the better long term solution.
> --joel
> > Thanking you,
> > Prateek
> > devel mailing list
> > devel at rtems.org
