[PATCH RSB] rtems-tools-6.cfg: Bump hash to get fix for rtems-test
Fri Nov 12 14:54:21 UTC 2021
 rtems/config/tools/rtems-tools-6.cfg | 4 ++--
 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/rtems/config/tools/rtems-tools-6.cfg b/rtems/config/tools/rtems-tools-6.cfg
index 6d05d12..cf895d6 100644
--- a/rtems/config/tools/rtems-tools-6.cfg
+++ b/rtems/config/tools/rtems-tools-6.cfg
@@ -10,14 +10,14 @@
  %define rtems_tools_source rtems-tools-%{rtems_tools_version}
  %define rtems_tools_ext xz
 %else
- %define rtems_tools_version d1df4f6e02fe22d2cb542adbd6ba4248ee077892
+ %define rtems_tools_version 6b31bb03aaf98232a21813c471d0298c170dde60
  %define rtems_tools_ext bz2
 %endif
 %source set rtems-tools https://git.rtems.org/rtems-tools/snapshot/%{rtems_tools_source}.tar.%{rtems_tools_ext}
 %hash   sha512 rtems-tools-%{rtems_tools_version}.tar.bz2 \
-         zhSEMRbpLdeDTg6RI5U1e/TU9FsN09cS/NPQrXCMU6QJsCdDWIzA0HwTq54/apM7RW38uQkmaW9cPk5RVU3e1A==
+         +TKPQxx2HdnSBW7QcgfzFZCjRw7mssXHaJSxDd0v1KJ/VLeWcdus/MELH7oq0WyEMpqAyd1+1HpMVuFrMFyvcw==
 # Optionally enable/disable building the RTEMS Tools via the command line.
2.24.4
