[PATCH RSB] rtems-tools-6.cfg: Bump hash to get fix for rtems-test
Chris Johns
chrisj at rtems.org
Fri Nov 12 22:53:00 UTC 2021
OK
On 13/11/21 1:54 am, Joel Sherrill wrote:
> rtems/config/tools/rtems-tools-6.cfg | 4 ++--
> 1 file changed, 2 insertions(+), 2 deletions(-)
> diff --git a/rtems/config/tools/rtems-tools-6.cfg b/rtems/config/tools/rtems-tools-6.cfg
> index 6d05d12..cf895d6 100644
> --- a/rtems/config/tools/rtems-tools-6.cfg
> +++ b/rtems/config/tools/rtems-tools-6.cfg
> @@ -10,14 +10,14 @@
> %define rtems_tools_source rtems-tools-%{rtems_tools_version}
> %define rtems_tools_ext xz
> %else
> - %define rtems_tools_version d1df4f6e02fe22d2cb542adbd6ba4248ee077892
> + %define rtems_tools_version 6b31bb03aaf98232a21813c471d0298c170dde60
> %define rtems_tools_ext bz2
> %endif
> %source set rtems-tools https://git.rtems.org/rtems-tools/snapshot/%{rtems_tools_source}.tar.%{rtems_tools_ext}
> %hash sha512 rtems-tools-%{rtems_tools_version}.tar.bz2 \
> - zhSEMRbpLdeDTg6RI5U1e/TU9FsN09cS/NPQrXCMU6QJsCdDWIzA0HwTq54/apM7RW38uQkmaW9cPk5RVU3e1A==
> + +TKPQxx2HdnSBW7QcgfzFZCjRw7mssXHaJSxDd0v1KJ/VLeWcdus/MELH7oq0WyEMpqAyd1+1HpMVuFrMFyvcw==
> # Optionally enable/disable building the RTEMS Tools via the command line.
