[RTEMS v2] optvermaj.yml: Allow __RTEMS_MAJOR__ to be overridden so RTEMS 7 tools can be tested
Joel Sherrill
joel at rtems.org
Fri Nov 12 16:03:13 UTC 2021
spec/build/cpukit/optvermaj.yml | 8 +++++---
1 file changed, 5 insertions(+), 3 deletions(-)
diff --git a/spec/build/cpukit/optvermaj.yml b/spec/build/cpukit/optvermaj.yml
index 2596e6ef6a..e1a5eae5b3 100644
--- a/spec/build/cpukit/optvermaj.yml
+++ b/spec/build/cpukit/optvermaj.yml
@@ -1,14 +1,16 @@
SPDX-License-Identifier: CC-BY-SA-4.0 OR BSD-2-Clause
actions:
-- set-value: '6'
+- get-string: null
- env-assign: null
build-type: option
copyrights:
- Copyright (C) 2020 embedded brains GmbH (http://www.embedded-brains.de)
-default: null
+default: 6
default-by-variant: []
-description: ''
+description: |
+ Major Component of the RTEMS Version Number
enabled-by: true
+format: '{}'
links: []
type: build
2.24.4
