[PATCH 2/6] score: Add _Thread_MP_Extract_proxy()
Mon Nov 15 17:08:56 UTC 2021
Remove _Thread_queue_Extract_with_proxy() and move the proxy extraction
to _Thread_MP_Extract_proxy().  Move similar code blocks of the previous
caller of _Thread_queue_Extract_with_proxy() to helper functions.
Update #4546.
 cpukit/include/rtems/score/objectdata.h    |  2 +-
 cpukit/include/rtems/score/threadmp.h      | 13 ++++++
 cpukit/include/rtems/score/threadqimpl.h   | 18 ---------
 cpukit/posix/src/psignalunblockthread.c    | 16 +++++---
 cpukit/score/src/threadqextractwithproxy.c | 46 +++++++++++-----------
 cpukit/score/src/threadrestart.c           | 17 +++++---
 spec/build/cpukit/librtemscpu.yml          |  1 -
 spec/build/cpukit/objmpci.yml              |  1 +
 8 files changed, 60 insertions(+), 54 deletions(-)
diff --git a/cpukit/include/rtems/score/objectdata.h b/cpukit/include/rtems/score/objectdata.h
index 149498df9c..c7fb33ca5b 100644
--- a/cpukit/include/rtems/score/objectdata.h
+++ b/cpukit/include/rtems/score/objectdata.h
@@ -286,7 +286,7 @@ struct Objects_Information {
 #if defined(RTEMS_MULTIPROCESSING)
-   * @brief This method is used by _Thread_queue_Extract_with_proxy().
+   * @brief This method is used by _Thread_MP_Extract_proxy().
    * This member is statically initialized and read-only.
diff --git a/cpukit/include/rtems/score/threadmp.h b/cpukit/include/rtems/score/threadmp.h
index 6cc68e6320..81a22e665e 100644
--- a/cpukit/include/rtems/score/threadmp.h
+++ b/cpukit/include/rtems/score/threadmp.h
@@ -97,6 +97,19 @@ Thread_Control *_Thread_MP_Find_proxy (
 #define _Thread_MP_Is_receive(_the_thread) \
   ((_the_thread) == _MPCI_Receive_server_tcb)
+ * @brief Extracts the proxy of the thread if necessary.
+ * This routine ensures that if there is a proxy for this thread on another
+ * node, it is also dealt with. A proxy is a data data that is on the thread
+ * queue on the remote node and acts as a proxy for the local thread. If the
+ * local thread was waiting on a remote operation, then the remote side of the
+ * operation must be cleaned up.
+ * @param[in, out] the_thread is the thread to determine the proxy.
+void _Thread_MP_Extract_proxy( Thread_Control *the_thread );
  * @brief Trees a proxy control block to the inactive chain of free proxy
  *      control blocks.
diff --git a/cpukit/include/rtems/score/threadqimpl.h b/cpukit/include/rtems/score/threadqimpl.h
index 7e6f2665be..18317873c4 100644
--- a/cpukit/include/rtems/score/threadqimpl.h
+++ b/cpukit/include/rtems/score/threadqimpl.h
@@ -983,24 +983,6 @@ void _Thread_queue_Resume(
 void _Thread_queue_Extract( Thread_Control *the_thread );
- * @brief Extracts the_thread from the_thread_queue.
- * This routine extracts the_thread from the_thread_queue
- * and ensures that if there is a proxy for this task on
- * another node, it is also dealt with. A proxy is a data
- * data that is on the thread queue on the remote node and
- * acts as a proxy for the local thread. If the local thread
- * was waiting on a remote operation, then the remote side
- * of the operation must be cleaned up.
- * @param[in, out] the_thread The pointer to a thread control block that
- *     is to be removed
-void _Thread_queue_Extract_with_proxy(
-  Thread_Control       *the_thread
  * @brief Surrenders the thread queue previously owned by the thread to the
  * first enqueued thread.
diff --git a/cpukit/posix/src/psignalunblockthread.c b/cpukit/posix/src/psignalunblockthread.c
index de814c13cd..1133234554 100644
--- a/cpukit/posix/src/psignalunblockthread.c
+++ b/cpukit/posix/src/psignalunblockthread.c
@@ -175,6 +175,15 @@ static bool _POSIX_signals_Unblock_thread_done(
   return status;
+static void _POSIX_signals_Interrupt_thread( Thread_Control *the_thread )
+#if defined(RTEMS_MULTIPROCESSING)
+  _Thread_MP_Extract_proxy( the_thread );
+#endif
+  the_thread->Wait.return_code = STATUS_INTERRUPTED;
+  _Thread_queue_Extract( the_thread );
 bool _POSIX_signals_Unblock_thread(
   Thread_Control  *the_thread,
   int              signo,
@@ -196,8 +205,6 @@ bool _POSIX_signals_Unblock_thread(
   if ( _States_Is_interruptible_signal( the_thread->current_state ) ) {
     if ( (the_thread->Wait.option & mask) || (api->signals_unblocked & mask) ) {
-      the_thread->Wait.return_code = STATUS_INTERRUPTED;
       the_info = (siginfo_t *) the_thread->Wait.return_argument;
       if ( !info ) {
@@ -208,7 +215,7 @@ bool _POSIX_signals_Unblock_thread(
         *the_info = *info;
-      _Thread_queue_Extract_with_proxy( the_thread );
+      _POSIX_signals_Interrupt_thread( the_thread );
       return _POSIX_signals_Unblock_thread_done( the_thread, api, true );
@@ -238,8 +245,7 @@ bool _POSIX_signals_Unblock_thread(
     if ( _States_Is_interruptible_by_signal( the_thread->current_state ) ) {
   return _POSIX_signals_Unblock_thread_done( the_thread, api, false );
diff --git a/cpukit/score/src/threadqextractwithproxy.c b/cpukit/score/src/threadqextractwithproxy.c
index 1370aecb86..a61934a2b1 100644
--- a/cpukit/score/src/threadqextractwithproxy.c
+++ b/cpukit/score/src/threadqextractwithproxy.c
@@ -4,7 +4,7 @@
  * @ingroup RTEMSScoreThreadQueue
  * @brief This source file contains the implementation of
- *   _Thread_queue_Extract_with_proxy().
+ *   _Thread_MP_Extract_proxy().
@@ -20,32 +20,30 @@
 #include "config.h"
 #endif
-#include <rtems/score/threadqimpl.h>
+#include <rtems/score/threadimpl.h>
-  #if defined(RTEMS_MULTIPROCESSING)
-    States_Control state;
-    state = the_thread->current_state;
-    if ( _States_Is_waiting_for_rpc_reply( state ) &&
-         _States_Is_locally_blocked( state ) ) {
-      Objects_Id                            id;
-      Objects_Information                  *the_information;
-      Objects_Thread_queue_Extract_callout  proxy_extract_callout;
-      id = the_thread->Wait.remote_id;
-      the_information = _Objects_Get_information_id( id );
-      proxy_extract_callout = the_information->extract;
-      if ( proxy_extract_callout != NULL )
-        (*proxy_extract_callout)( the_thread, id );
-  #endif
+  States_Control state;
+  state = the_thread->current_state;
+  if (
+    _States_Is_waiting_for_rpc_reply( state ) &&
+    _States_Is_locally_blocked( state )
+    Objects_Id                            id;
+    const Objects_Information            *the_information;
+    Objects_Thread_queue_Extract_callout  proxy_extract_callout;
-  _Thread_queue_Extract( the_thread );
+    id = the_thread->Wait.remote_id;
+    the_information = _Objects_Get_information_id( id );
+    proxy_extract_callout = the_information->extract;
+    if ( proxy_extract_callout != NULL ) {
+      ( *proxy_extract_callout )( the_thread, id );
diff --git a/cpukit/score/src/threadrestart.c b/cpukit/score/src/threadrestart.c
index 12a0329a73..6423c421b4 100644
--- a/cpukit/score/src/threadrestart.c
+++ b/cpukit/score/src/threadrestart.c
@@ -112,6 +112,15 @@ static void _Thread_Wake_up_joining_threads( Thread_Control *the_thread )
+static void _Thread_Remove_timer_and_continue( Thread_Control *the_thread )
+  _Thread_Timer_remove( the_thread );
+#endif
 static void _Thread_Add_to_zombie_registry( Thread_Control *the_thread )
   ISR_lock_Context        lock_context;
@@ -137,8 +146,7 @@ static void _Thread_Make_zombie( Thread_Control *the_thread )
   _Objects_Close( &information->Objects, &the_thread->Object );
   _Thread_Set_state( the_thread, STATES_ZOMBIE );
-  _Thread_Timer_remove( the_thread );
+  _Thread_Remove_timer_and_continue( the_thread );
    * Add the thread to the thread zombie chain before we wake up joining
@@ -358,7 +366,7 @@ static void _Thread_Remove_life_change_request( Thread_Control *the_thread )
      * Do not remove states used for thread queues to avoid race conditions on
      * SMP configurations.  We could interrupt an extract operation on another
      * processor disregarding the thread wait flags.  Rely on
-     * _Thread_queue_Extract_with_proxy() for removal of these states.
+     * _Thread_queue_Extract() for removal of these states.
     _Thread_Clear_state_locked(
       the_thread,
@@ -409,8 +417,7 @@ static void _Thread_Try_life_change_request(
     _Thread_Add_life_change_request( the_thread );
     _Thread_State_release( the_thread, lock_context );
     _Thread_Remove_life_change_request( the_thread );
   } else {
     _Thread_Clear_state_locked( the_thread, STATES_SUSPENDED );
diff --git a/spec/build/cpukit/librtemscpu.yml b/spec/build/cpukit/librtemscpu.yml
index 819c479191..02be1a43ea 100644
--- a/spec/build/cpukit/librtemscpu.yml
+++ b/spec/build/cpukit/librtemscpu.yml
@@ -1559,7 +1559,6 @@ source:
 - cpukit/score/src/threadplaindispatch.c
 - cpukit/score/src/threadq.c
 - cpukit/score/src/threadqenqueue.c
-- cpukit/score/src/threadqextractwithproxy.c
 - cpukit/score/src/threadqfirst.c
 - cpukit/score/src/threadqflush.c
 - cpukit/score/src/threadqgetnameandid.c
diff --git a/spec/build/cpukit/objmpci.yml b/spec/build/cpukit/objmpci.yml
index 24cfca9888..0b9b5c61da 100644
--- a/spec/build/cpukit/objmpci.yml
+++ b/spec/build/cpukit/objmpci.yml
@@ -23,4 +23,5 @@ source:
 - cpukit/score/src/mpcidefault.c
 - cpukit/score/src/objectmp.c
 - cpukit/score/src/threadmp.c
+- cpukit/score/src/threadqextractwithproxy.c
 type: build
2.26.2
