[PATCH 2/6] score: Add _Thread_MP_Extract_proxy()
Gedare Bloom
gedare at rtems.org
Sat Nov 20 16:52:40 UTC 2021
On Mon, Nov 15, 2021 at 10:09 AM Sebastian Huber
> Remove _Thread_queue_Extract_with_proxy() and move the proxy extraction
> to _Thread_MP_Extract_proxy(). Move similar code blocks of the previous
> caller of _Thread_queue_Extract_with_proxy() to helper functions.
> Update #4546.
> cpukit/include/rtems/score/objectdata.h | 2 +-
> cpukit/include/rtems/score/threadmp.h | 13 ++++++
> cpukit/include/rtems/score/threadqimpl.h | 18 ---------
> cpukit/posix/src/psignalunblockthread.c | 16 +++++---
> cpukit/score/src/threadqextractwithproxy.c | 46 +++++++++++-----------
> cpukit/score/src/threadrestart.c | 17 +++++---
> spec/build/cpukit/librtemscpu.yml | 1 -
> spec/build/cpukit/objmpci.yml | 1 +
> 8 files changed, 60 insertions(+), 54 deletions(-)
> diff --git a/cpukit/include/rtems/score/objectdata.h b/cpukit/include/rtems/score/objectdata.h
> index 149498df9c..c7fb33ca5b 100644
> --- a/cpukit/include/rtems/score/objectdata.h
> +++ b/cpukit/include/rtems/score/objectdata.h
> @@ -286,7 +286,7 @@ struct Objects_Information {
> #if defined(RTEMS_MULTIPROCESSING)
> - * @brief This method is used by _Thread_queue_Extract_with_proxy().
> + * @brief This method is used by _Thread_MP_Extract_proxy().
> * This member is statically initialized and read-only.
> diff --git a/cpukit/include/rtems/score/threadmp.h b/cpukit/include/rtems/score/threadmp.h
> index 6cc68e6320..81a22e665e 100644
> --- a/cpukit/include/rtems/score/threadmp.h
> +++ b/cpukit/include/rtems/score/threadmp.h
> @@ -97,6 +97,19 @@ Thread_Control *_Thread_MP_Find_proxy (
> #define _Thread_MP_Is_receive(_the_thread) \
> ((_the_thread) == _MPCI_Receive_server_tcb)
> + * @brief Extracts the proxy of the thread if necessary.
> + * This routine ensures that if there is a proxy for this thread on another
> + * node, it is also dealt with. A proxy is a data data that is on the thread
'data data' already existed / was copy-pasted, feel free to clean-up later
