[PATCH 3/6] score: Simplify thread wait state handling
Mon Nov 15 17:08:57 UTC 2021
Remove the THREAD_WAIT_STATE_READY_AGAIN and simply use the initial value to
indicate that a thread does not wait on something.  Rename
THREAD_WAIT_FLAGS_INITIAL to THREAD_WAIT_STATE_READY.  This change is necessary
so that _Thread_Continue() can be called for threads which never waited on
something (for example dormant threads).
Update #4546.
 cpukit/include/rtems/rtems/ratemonimpl.h   |  3 ---
 cpukit/include/rtems/score/thread.h        |  2 +-
 cpukit/include/rtems/score/threadimpl.h    | 19 ++++++++-----------
 cpukit/rtems/src/eventsurrender.c          | 12 ++++--------
 cpukit/rtems/src/ratemonperiod.c           |  2 +-
 cpukit/rtems/src/ratemontimeout.c          |  4 ++--
 cpukit/score/src/threadinitialize.c        |  2 +-
 cpukit/score/src/threadqenqueue.c          |  9 +++------
 cpukit/score/src/threadtimeout.c           |  8 +++-----
 testsuites/sptests/spintrcritical08/init.c | 13 +------------
 testsuites/sptests/spintrcritical09/init.c |  2 +-
 testsuites/sptests/spintrcritical10/init.c |  9 +++------
 testsuites/sptests/spintrcritical22/init.c |  2 +-
 13 files changed, 29 insertions(+), 58 deletions(-)
diff --git a/cpukit/include/rtems/rtems/ratemonimpl.h b/cpukit/include/rtems/rtems/ratemonimpl.h
index 62327c5b09..d17c7fe4de 100644
--- a/cpukit/include/rtems/rtems/ratemonimpl.h
+++ b/cpukit/include/rtems/rtems/ratemonimpl.h
@@ -48,9 +48,6 @@ extern "C" {
 #define RATE_MONOTONIC_BLOCKED \
   ( THREAD_WAIT_CLASS_PERIOD | THREAD_WAIT_STATE_BLOCKED )
-#define RATE_MONOTONIC_READY_AGAIN \
-  ( THREAD_WAIT_CLASS_PERIOD | THREAD_WAIT_STATE_READY_AGAIN )
  *  @brief Allocates a period control block from
  *  the inactive chain of free period control blocks.
diff --git a/cpukit/include/rtems/score/thread.h b/cpukit/include/rtems/score/thread.h
index 23ed8e1406..c3c37eb160 100644
--- a/cpukit/include/rtems/score/thread.h
+++ b/cpukit/include/rtems/score/thread.h
@@ -404,7 +404,7 @@ typedef union {
  * The mutually exclusive wait state flags are
  * - @ref THREAD_WAIT_STATE_INTEND_TO_BLOCK,
  * - @ref THREAD_WAIT_STATE_BLOCKED, and
- * - @ref THREAD_WAIT_STATE_READY_AGAIN.
+ * - @ref THREAD_WAIT_STATE_READY.
 typedef unsigned int Thread_Wait_flags;
diff --git a/cpukit/include/rtems/score/threadimpl.h b/cpukit/include/rtems/score/threadimpl.h
index 86a2abeb38..c5563915bd 100644
--- a/cpukit/include/rtems/score/threadimpl.h
+++ b/cpukit/include/rtems/score/threadimpl.h
@@ -2217,14 +2217,18 @@ RTEMS_INLINE_ROUTINE void _Thread_Wait_cancel(
- * @brief The initial thread wait flags value set by _Thread_Initialize().
+ * @brief Mask to get the thread wait state flags.
-#define THREAD_WAIT_FLAGS_INITIAL 0x0U
+#define THREAD_WAIT_STATE_MASK 0xffU
- * @brief Mask to get the thread wait state flags.
+ * @brief Indicates that the thread does not wait on something.
+ * In this wait state, the wait class is zero.  This wait state is set
+ * initially by _Thread_Initialize() and after each wait operation once the
+ * thread is ready again.
-#define THREAD_WAIT_STATE_MASK 0xffU
+#define THREAD_WAIT_STATE_READY 0x0U
  * @brief Indicates that the thread begins with the blocking operation.
@@ -2240,13 +2244,6 @@ RTEMS_INLINE_ROUTINE void _Thread_Wait_cancel(
 #define THREAD_WAIT_STATE_BLOCKED 0x2U
- * @brief Indicates that a condition to end the thread wait occurred.
- * This could be a timeout, a signal, an event or a resource availability.
-#define THREAD_WAIT_STATE_READY_AGAIN 0x4U
  * @brief Mask to get the thread wait class flags.
diff --git a/cpukit/rtems/src/eventsurrender.c b/cpukit/rtems/src/eventsurrender.c
index 48c08e486f..0623977c8b 100644
--- a/cpukit/rtems/src/eventsurrender.c
+++ b/cpukit/rtems/src/eventsurrender.c
@@ -42,12 +42,10 @@ static bool _Event_Is_blocking_on_event(
   Thread_Wait_flags wait_flags;
-  Thread_Wait_flags wait_mask;
   wait_flags = _Thread_Wait_flags_get( the_thread );
-  wait_mask = THREAD_WAIT_CLASS_MASK | THREAD_WAIT_STATE_READY_AGAIN;
-  return ( wait_flags & wait_mask ) == wait_class;
+  return ( wait_flags & THREAD_WAIT_CLASS_MASK ) == wait_class;
 static bool _Event_Is_satisfied(
@@ -88,16 +86,14 @@ rtems_status_code _Event_Surrender(
     _Event_Is_blocking_on_event( the_thread, wait_class )
       && _Event_Is_satisfied( the_thread, pending_events, &seized_events )
-    Thread_Wait_flags ready_again;
-    bool              success;
+    bool success;
     _Event_Satisfy( the_thread, event, pending_events, seized_events );
-    ready_again = wait_class | THREAD_WAIT_STATE_READY_AGAIN;
     success = _Thread_Wait_flags_try_change_release(
       the_thread,
       wait_class | THREAD_WAIT_STATE_INTEND_TO_BLOCK,
-      ready_again
+      THREAD_WAIT_STATE_READY
     if ( success ) {
@@ -107,7 +103,7 @@ rtems_status_code _Event_Surrender(
           == ( wait_class | THREAD_WAIT_STATE_BLOCKED )
-      _Thread_Wait_flags_set( the_thread, ready_again );
+      _Thread_Wait_flags_set( the_thread, THREAD_WAIT_STATE_READY );
       unblock = true;
   } else {
diff --git a/cpukit/rtems/src/ratemonperiod.c b/cpukit/rtems/src/ratemonperiod.c
index 32ac688a7f..a8697abf3c 100644
--- a/cpukit/rtems/src/ratemonperiod.c
+++ b/cpukit/rtems/src/ratemonperiod.c
@@ -247,7 +247,7 @@ static rtems_status_code _Rate_monotonic_Block_while_active(
   if ( !success ) {
     _Assert(
-      _Thread_Wait_flags_get( executing ) == RATE_MONOTONIC_READY_AGAIN
+      _Thread_Wait_flags_get( executing ) == THREAD_WAIT_STATE_READY
     _Thread_Unblock( executing );
diff --git a/cpukit/rtems/src/ratemontimeout.c b/cpukit/rtems/src/ratemontimeout.c
index b20e1e15db..375c5f081f 100644
--- a/cpukit/rtems/src/ratemontimeout.c
+++ b/cpukit/rtems/src/ratemontimeout.c
@@ -74,13 +74,13 @@ void _Rate_monotonic_Timeout( Watchdog_Control *the_watchdog )
       owner,
       RATE_MONOTONIC_INTEND_TO_BLOCK,
-      RATE_MONOTONIC_READY_AGAIN
     if ( success ) {
       unblock = false;
     } else {
       _Assert( _Thread_Wait_flags_get( owner ) == RATE_MONOTONIC_BLOCKED );
-      _Thread_Wait_flags_set( owner, RATE_MONOTONIC_READY_AGAIN );
+      _Thread_Wait_flags_set( owner, THREAD_WAIT_STATE_READY );
       unblock = true;
diff --git a/cpukit/score/src/threadinitialize.c b/cpukit/score/src/threadinitialize.c
index 01ef479537..2682a9428c 100644
--- a/cpukit/score/src/threadinitialize.c
+++ b/cpukit/score/src/threadinitialize.c
@@ -299,7 +299,7 @@ static bool _Thread_Try_initialize(
   the_thread->Wait.operations         = &_Thread_queue_Operations_default;
   the_thread->Start.initial_priority  = config->priority;
-  RTEMS_STATIC_ASSERT( THREAD_WAIT_FLAGS_INITIAL == 0, Wait_flags );
+  RTEMS_STATIC_ASSERT( THREAD_WAIT_STATE_READY == 0, Wait_flags );
   /* POSIX Keys */
   _RBTree_Initialize_empty( &the_thread->Keys.Key_value_pairs );
diff --git a/cpukit/score/src/threadqenqueue.c b/cpukit/score/src/threadqenqueue.c
index 2e31095510..ac532c8b86 100644
--- a/cpukit/score/src/threadqenqueue.c
+++ b/cpukit/score/src/threadqenqueue.c
@@ -41,9 +41,6 @@
 #define THREAD_QUEUE_BLOCKED \
   (THREAD_WAIT_CLASS_OBJECT | THREAD_WAIT_STATE_BLOCKED)
-#define THREAD_QUEUE_READY_AGAIN \
-  (THREAD_WAIT_CLASS_OBJECT | THREAD_WAIT_STATE_READY_AGAIN)
 #if defined(RTEMS_SMP)
  * A global registry of active thread queue links is used to provide deadlock
@@ -560,7 +557,7 @@ static void _Thread_queue_Force_ready_again( Thread_Control *the_thread )
    * We must set the wait flags under protection of the current thread lock,
    * otherwise a _Thread_Timeout() running on another processor may interfere.
-  _Thread_Wait_flags_set( the_thread, THREAD_QUEUE_READY_AGAIN );
   _Thread_Wait_restore_default( the_thread );
@@ -576,13 +573,13 @@ static bool _Thread_queue_Make_ready_again( Thread_Control *the_thread )
     the_thread,
     THREAD_QUEUE_INTEND_TO_BLOCK,
-    THREAD_QUEUE_READY_AGAIN
   if ( success ) {
     unblock = false;
   } else {
     _Assert( _Thread_Wait_flags_get( the_thread ) == THREAD_QUEUE_BLOCKED );
     unblock = true;
diff --git a/cpukit/score/src/threadtimeout.c b/cpukit/score/src/threadtimeout.c
index 2f2017bebe..9431ff253d 100644
--- a/cpukit/score/src/threadtimeout.c
+++ b/cpukit/score/src/threadtimeout.c
@@ -35,9 +35,8 @@ void _Thread_Continue( Thread_Control *the_thread, Status_Control status )
-  if ( ( wait_flags & THREAD_WAIT_STATE_READY_AGAIN ) == 0 ) {
+  if ( wait_flags != THREAD_WAIT_STATE_READY ) {
     Thread_Wait_flags wait_class;
     bool              success;
     _Thread_Wait_cancel( the_thread, &queue_context );
@@ -45,11 +44,10 @@ void _Thread_Continue( Thread_Control *the_thread, Status_Control status )
     the_thread->Wait.return_code = status;
     wait_class = wait_flags & THREAD_WAIT_CLASS_MASK;
       the_thread,
-      ready_again
     if ( success ) {
@@ -59,7 +57,7 @@ void _Thread_Continue( Thread_Control *the_thread, Status_Control status )
       unblock = true;
   } else {
diff --git a/testsuites/sptests/spintrcritical08/init.c b/testsuites/sptests/spintrcritical08/init.c
index 7b55a2e328..39855dfa29 100644
--- a/testsuites/sptests/spintrcritical08/init.c
+++ b/testsuites/sptests/spintrcritical08/init.c
@@ -78,7 +78,7 @@ static T_interrupt_test_state interrupt( void *arg )
     T_quiet_eq_int( previous_period_state, RATE_MONOTONIC_ACTIVE );
     T_quiet_eq_int( getState( ctx ), RATE_MONOTONIC_ACTIVE );
     state = T_INTERRUPT_TEST_DONE;
-  } else if ( flags == THREAD_WAIT_FLAGS_INITIAL ) {
+  } else if ( flags == THREAD_WAIT_STATE_READY ) {
     T_quiet_true(
       previous_period_state == RATE_MONOTONIC_ACTIVE
         || previous_period_state == RATE_MONOTONIC_EXPIRED
@@ -100,8 +100,6 @@ static void prepare( void *arg )
   test_context      *ctx;
   rtems_status_code  sc;
-  ISR_Level          level;
-  bool               success;
   ctx = arg;
@@ -119,15 +117,6 @@ static void prepare( void *arg )
     sc = rtems_rate_monotonic_period( ctx->period, 1 );
   } while ( sc != RTEMS_SUCCESSFUL );
-  _ISR_Local_disable( level );
-  success = _Thread_Wait_flags_try_change_release(
-    ctx->thread,
-    RATE_MONOTONIC_READY_AGAIN,
-    THREAD_WAIT_FLAGS_INITIAL
-  _ISR_Local_enable( level );
-  T_quiet_true( success );
 static void action( void *arg )
diff --git a/testsuites/sptests/spintrcritical09/init.c b/testsuites/sptests/spintrcritical09/init.c
index 3d82febd6f..2dec20ef7e 100644
--- a/testsuites/sptests/spintrcritical09/init.c
+++ b/testsuites/sptests/spintrcritical09/init.c
@@ -32,7 +32,7 @@ static bool is_interrupt_timeout( test_context *ctx )
   Thread_Wait_flags flags = _Thread_Wait_flags_get( ctx->thread );
-  return flags == ( THREAD_WAIT_CLASS_OBJECT | THREAD_WAIT_STATE_READY_AGAIN );
+  return flags == THREAD_WAIT_STATE_READY;
diff --git a/testsuites/sptests/spintrcritical10/init.c b/testsuites/sptests/spintrcritical10/init.c
index 8210853588..36f50628fb 100644
--- a/testsuites/sptests/spintrcritical10/init.c
+++ b/testsuites/sptests/spintrcritical10/init.c
@@ -92,8 +92,7 @@ static T_interrupt_test_state any_satisfy_before_timeout_interrupt(void *arg)
     if (state == T_INTERRUPT_TEST_DONE) {
       rtems_test_assert(
-        _Thread_Wait_flags_get(thread)
-          == (THREAD_WAIT_CLASS_EVENT | THREAD_WAIT_STATE_READY_AGAIN)
+        _Thread_Wait_flags_get(thread) == THREAD_WAIT_STATE_READY
@@ -184,8 +183,7 @@ static T_interrupt_test_state all_satisfy_before_timeout_interrupt(void *arg)
       rtems_test_assert(
@@ -261,8 +259,7 @@ static T_interrupt_test_state timeout_before_satisfied_interrupt(void *arg)
       rtems_test_assert(
diff --git a/testsuites/sptests/spintrcritical22/init.c b/testsuites/sptests/spintrcritical22/init.c
index 192a5a98b3..f950307fdc 100644
--- a/testsuites/sptests/spintrcritical22/init.c
+++ b/testsuites/sptests/spintrcritical22/init.c
@@ -56,7 +56,7 @@ static T_interrupt_test_state release_semaphore(void *arg)
     rtems_test_assert(
       _Thread_Wait_flags_get(ctx->main_task_control)
-        == (THREAD_WAIT_CLASS_OBJECT | THREAD_WAIT_STATE_READY_AGAIN)
+        == THREAD_WAIT_STATE_READY
     sem = &ctx->semaphore_control->Core_control.Semaphore;
     rtems_test_assert(sem->count == 0);
2.26.2
