[PATCH 03/27] score: Rename _Scheduler_Set_idle_thread()
Sebastian Huber
Mon Nov 15 17:12:35 UTC 2021
Rename _Scheduler_Set_idle_thread() in _Scheduler_Node_set_idle_user() and move
it to <rtems/score/schedulernodeimpl.h>.
Update #4531.
cpukit/include/rtems/score/schedulerimpl.h | 24 ++-----------------
.../include/rtems/score/schedulernodeimpl.h | 21 ++++++++++++++++
2 files changed, 23 insertions(+), 22 deletions(-)
diff --git a/cpukit/include/rtems/score/schedulerimpl.h b/cpukit/include/rtems/score/schedulerimpl.h
index 6e079f3a80..1109933e69 100644
--- a/cpukit/include/rtems/score/schedulerimpl.h
+++ b/cpukit/include/rtems/score/schedulerimpl.h
@@ -899,26 +899,6 @@ RTEMS_INLINE_ROUTINE void _Scheduler_Thread_change_state(
the_thread->Scheduler.state = new_state;
- * @brief Sets the scheduler node's idle thread.
- * @param[in, out] node The node to receive an idle thread.
- * @param idle The idle thread control for the operation.
-RTEMS_INLINE_ROUTINE void _Scheduler_Set_idle_thread(
- Scheduler_Node *node,
- Thread_Control *idle
- _Assert( _Scheduler_Node_get_idle( node ) == NULL );
- _Assert(
- _Scheduler_Node_get_owner( node ) == _Scheduler_Node_get_user( node )
- _Scheduler_Node_set_user( node, idle );
- node->idle = idle;
* @brief Uses an idle thread for this scheduler node.
@@ -941,7 +921,7 @@ RTEMS_INLINE_ROUTINE Thread_Control *_Scheduler_Use_idle_thread(
Thread_Control *idle = ( *get_idle_thread )( context );
- _Scheduler_Set_idle_thread( node, idle );
+ _Scheduler_Node_set_idle_user( node, idle );
_Thread_Set_CPU( idle, cpu );
return idle;
@@ -1079,7 +1059,7 @@ RTEMS_INLINE_ROUTINE void _Scheduler_Exchange_idle_thread(
uses_idle,
_Scheduler_Node_get_owner( uses_idle )
- _Scheduler_Set_idle_thread( needs_idle, idle );
+ _Scheduler_Node_set_idle_user( needs_idle, idle );
diff --git a/cpukit/include/rtems/score/schedulernodeimpl.h b/cpukit/include/rtems/score/schedulernodeimpl.h
index e222de953b..ecdc3c6d62 100644
--- a/cpukit/include/rtems/score/schedulernodeimpl.h
+++ b/cpukit/include/rtems/score/schedulernodeimpl.h
@@ -264,6 +264,27 @@ RTEMS_INLINE_ROUTINE Thread_Control *_Scheduler_Node_get_idle(
return node->idle;
+ * @brief Sets the scheduler node's user to the idle thread.
+ * @param[in, out] node is the node to receive an idle thread.
+ * @param idle is the idle thread to use.
+RTEMS_INLINE_ROUTINE void _Scheduler_Node_set_idle_user(
+ Scheduler_Node *node,
+ Thread_Control *idle
+ _Assert( _Scheduler_Node_get_idle( node ) == NULL );
+ _Assert(
+ _Scheduler_Node_get_owner( node ) == _Scheduler_Node_get_user( node )
+ _Scheduler_Node_set_user( node, idle );
+ node->idle = idle;
#endif
#ifdef __cplusplus
2.26.2
