[PATCH 04/27] score: Not set CPU in _Scheduler_Use_idle_thread()
Sebastian Huber
Mon Nov 15 17:12:36 UTC 2021
Do not set the CPU of the idle thread in _Scheduler_Use_idle_thread(). This
helps to use _Scheduler_Try_to_schedule_node() under more general conditions in
the future, for example in case the owner and user of a node are not the same.
Update #4531.
cpukit/include/rtems/score/schedulerimpl.h | 22 ++++++++--------------
1 file changed, 8 insertions(+), 14 deletions(-)
diff --git a/cpukit/include/rtems/score/schedulerimpl.h b/cpukit/include/rtems/score/schedulerimpl.h
index 1109933e69..ec51b6d097 100644
--- a/cpukit/include/rtems/score/schedulerimpl.h
+++ b/cpukit/include/rtems/score/schedulerimpl.h
@@ -915,14 +915,12 @@ RTEMS_INLINE_ROUTINE void _Scheduler_Thread_change_state(
RTEMS_INLINE_ROUTINE Thread_Control *_Scheduler_Use_idle_thread(
Scheduler_Context *context,
Scheduler_Node *node,
- Per_CPU_Control *cpu,
Scheduler_Get_idle_thread get_idle_thread
Thread_Control *idle = ( *get_idle_thread )( context );
_Scheduler_Node_set_idle_user( node, idle );
- _Thread_Set_CPU( idle, cpu );
return idle;
@@ -999,12 +997,12 @@ _Scheduler_Try_to_schedule_node(
} else if ( idle != NULL ) {
action = SCHEDULER_TRY_TO_SCHEDULE_DO_IDLE_EXCHANGE;
} else {
- _Scheduler_Use_idle_thread(
- context,
- node,
- _Thread_Get_CPU( owner ),
- get_idle_thread
+ Thread_Control *idle;
+ Thread_Control *user;
+ idle = _Scheduler_Use_idle_thread( context, node, get_idle_thread );
+ user = _Scheduler_Node_get_user( node );
+ _Thread_Set_CPU( idle, _Thread_Get_CPU( user ) );
_Thread_Scheduler_release_critical( owner, &lock_context );
@@ -1104,12 +1102,8 @@ RTEMS_INLINE_ROUTINE Per_CPU_Control *_Scheduler_Block_node(
if ( is_scheduled && _Scheduler_Node_get_idle( node ) == NULL ) {
- idle = _Scheduler_Use_idle_thread(
- context,
- node,
- thread_cpu,
- get_idle_thread
+ _Thread_Set_CPU( idle, thread_cpu );
_Thread_Dispatch_update_heir( _Per_CPU_Get(), thread_cpu, idle );
2.26.2
