[PATCH 18/27] score: Fix SMP EDF priority group ordering
Sebastian Huber
Mon Nov 15 17:12:50 UTC 2021
The SMP EDF scheduler supports one-to-one and one-to-all thread to
processor affinities. The one-to-one thread to processor affinity
introduces a constraint on the ordering of threads. The implementation
uses one ready queue for threads which have a one-to-all affinity and
one for each one-to-one affinity group. To order threads across the
ready queues, a generation number is used. However, the approach to
update the generation number each time a thread is inserted into a ready
queue was wrong. The generation number needs to be updated only in the
enqueue and enqueue scheduled operations where an insert priority is
available. The scheduled chain needs to take the generation number into
account.
An example scenario which shows the bug is this. Let T be a high
priority task affine to processor X. Let A be a lower priority task
affine to processor X. Let B be a lower priority task with no affinity
to a particular processor which executes on processor Y. Let B be in
the same priority group than A and after A. Let T set the affinity to
all processors. Now A (higher priority relative to B) should execute on
X and T (high priority) should execute on Y.
Close #4534.
cpukit/score/src/scheduleredfsmp.c | 74 ++++++++++++++++++++++++------
1 file changed, 61 insertions(+), 13 deletions(-)
diff --git a/cpukit/score/src/scheduleredfsmp.c b/cpukit/score/src/scheduleredfsmp.c
index 28266dd13d..7a1c3c598d 100644
--- a/cpukit/score/src/scheduleredfsmp.c
+++ b/cpukit/score/src/scheduleredfsmp.c
@@ -67,6 +67,28 @@ static inline bool _Scheduler_EDF_SMP_Priority_less_equal(
return prio_left <= prio_right;
+static inline bool _Scheduler_EDF_SMP_Overall_less_equal(
+ const void *key,
+ const Chain_Node *to_insert,
+ const Chain_Node *next
+ Priority_Control insert_priority;
+ Priority_Control next_priority;
+ const Scheduler_EDF_SMP_Node *node_to_insert;
+ const Scheduler_EDF_SMP_Node *node_next;
+ insert_priority = *(const Priority_Control *) key;
+ insert_priority = SCHEDULER_PRIORITY_PURIFY( insert_priority );
+ node_to_insert = (const Scheduler_EDF_SMP_Node *) to_insert;
+ node_next = (const Scheduler_EDF_SMP_Node *) next;
+ next_priority = node_next->Base.priority;
+ return insert_priority < next_priority ||
+ ( insert_priority == next_priority &&
+ node_to_insert->generation <= node_next->generation );
void _Scheduler_EDF_SMP_Initialize( const Scheduler_Control *scheduler )
Scheduler_EDF_SMP_Context *self =
@@ -241,6 +263,28 @@ static inline Scheduler_Node *_Scheduler_EDF_SMP_Get_lowest_scheduled(
return _Scheduler_SMP_Get_lowest_scheduled( context, filter_base );
+static inline void _Scheduler_EDF_SMP_Update_generation(
+ Scheduler_Context *context,
+ Scheduler_Node *node_base,
+ Scheduler_EDF_SMP_Context *self;
+ Scheduler_EDF_SMP_Node *node;
+ int generation_index;
+ int increment;
+ int64_t generation;
+ self = _Scheduler_EDF_SMP_Get_self( context );
+ node = _Scheduler_EDF_SMP_Node_downcast( node_base );
+ generation_index = SCHEDULER_PRIORITY_IS_APPEND( insert_priority );
+ increment = ( generation_index << 1 ) - 1;
+ generation = self->generations[ generation_index ];
+ node->generation = generation;
+ self->generations[ generation_index ] = generation + increment;
static inline void _Scheduler_EDF_SMP_Insert_scheduled(
@@ -257,7 +301,12 @@ static inline void _Scheduler_EDF_SMP_Insert_scheduled(
rqi = node->ready_queue_index;
ready_queue = &self->Ready[ rqi ];
- _Scheduler_SMP_Insert_scheduled( context, node_base, priority_to_insert );
+ _Chain_Insert_ordered_unprotected(
+ &self->Base.Scheduled,
+ &node_base->Node.Chain,
+ &priority_to_insert,
+ _Scheduler_EDF_SMP_Overall_less_equal
if ( rqi != 0 ) {
ready_queue->affine_scheduled = node;
@@ -293,21 +342,12 @@ static inline void _Scheduler_EDF_SMP_Insert_ready(
uint8_t rqi;
Scheduler_EDF_SMP_Ready_queue *ready_queue;
- int generation_index;
- int increment;
- int64_t generation;
- generation_index = SCHEDULER_PRIORITY_IS_APPEND( insert_priority );
- increment = ( generation_index << 1 ) - 1;
- generation = self->generations[ generation_index ];
- node->generation = generation;
- self->generations[ generation_index ] = generation + increment;
_Scheduler_EDF_SMP_Activate_ready_queue_if_necessary( self, rqi, ready_queue );
_RBTree_Initialize_node( &node->Base.Base.Node.RBTree );
_RBTree_Insert_inline(
@@ -509,11 +549,13 @@ static inline bool _Scheduler_EDF_SMP_Enqueue(
+ _Scheduler_EDF_SMP_Update_generation( context, node, insert_priority );
return _Scheduler_SMP_Enqueue(
context,
node,
insert_priority,
- _Scheduler_SMP_Priority_less_equal,
+ _Scheduler_EDF_SMP_Overall_less_equal,
_Scheduler_EDF_SMP_Insert_ready,
_Scheduler_EDF_SMP_Insert_scheduled,
_Scheduler_EDF_SMP_Move_from_scheduled_to_ready,
@@ -531,11 +573,12 @@ static inline void _Scheduler_EDF_SMP_Enqueue_scheduled(
_Scheduler_SMP_Enqueue_scheduled(
context,
node,
insert_priority,
_Scheduler_EDF_SMP_Extract_from_ready,
_Scheduler_EDF_SMP_Get_highest_ready,
@@ -575,7 +618,7 @@ static inline bool _Scheduler_EDF_SMP_Do_ask_for_help(
context,
the_thread,
node,
@@ -704,6 +747,11 @@ static inline void _Scheduler_EDF_SMP_Register_idle(
idle = _Scheduler_EDF_SMP_Node_downcast( idle_base );
_Scheduler_EDF_SMP_Set_allocated( self, idle, cpu );
+ context,
+ idle_base,
+ PRIORITY_GROUP_LAST
void _Scheduler_EDF_SMP_Add_processor(
2.26.2
