[PATCH 17/27] score: Add node to insert to Chain_Node_order
Sebastian Huber
Mon Nov 15 17:12:49 UTC 2021
This allows to use additional members of the nodes for comparision.
Update #4534.
cpukit/include/rtems/score/chainimpl.h | 11 +++---
.../include/rtems/score/schedulersimpleimpl.h | 13 ++++---
cpukit/include/rtems/score/schedulersmpimpl.h | 36 ++++++++++++++-----
cpukit/score/src/coremsginsert.c | 6 ++--
.../score/src/schedulerpriorityaffinitysmp.c | 6 ++--
testsuites/sptests/spchain/init.c | 8 ++++-
6 files changed, 59 insertions(+), 21 deletions(-)
diff --git a/cpukit/include/rtems/score/chainimpl.h b/cpukit/include/rtems/score/chainimpl.h
index 234dd1d74e..6aaa89237d 100644
--- a/cpukit/include/rtems/score/chainimpl.h
+++ b/cpukit/include/rtems/score/chainimpl.h
@@ -826,7 +826,8 @@ RTEMS_INLINE_ROUTINE bool _Chain_Get_with_empty_check_unprotected(
* @retval false Otherwise.
typedef bool ( *Chain_Node_order )(
- const void *left,
+ const void *key,
+ const Chain_Node *left,
const Chain_Node *right
@@ -848,18 +849,20 @@ typedef bool ( *Chain_Node_order )(
RTEMS_INLINE_ROUTINE void _Chain_Insert_ordered_unprotected(
Chain_Control *the_chain,
Chain_Node *to_insert,
- const void *left,
+ const void *key,
Chain_Node_order order
const Chain_Node *tail = _Chain_Immutable_tail( the_chain );
+ Chain_Node *previous = _Chain_Head( the_chain );
Chain_Node *next = _Chain_First( the_chain );
- while ( next != tail && !( *order )( left, next ) ) {
+ while ( next != tail && !( *order )( key, to_insert, next ) ) {
+ previous = next;
next = _Chain_Next( next );
- _Chain_Insert_unprotected( _Chain_Previous( next ), to_insert );
+ _Chain_Insert_unprotected( previous, to_insert );
diff --git a/cpukit/include/rtems/score/schedulersimpleimpl.h b/cpukit/include/rtems/score/schedulersimpleimpl.h
index 08ad7b8c66..9d762e058a 100644
--- a/cpukit/include/rtems/score/schedulersimpleimpl.h
+++ b/cpukit/include/rtems/score/schedulersimpleimpl.h
@@ -48,21 +48,26 @@ RTEMS_INLINE_ROUTINE Scheduler_simple_Context *
* @brief Checks if the priority is less or equal than the priority of the node.
- * @param to_insert The priority to check whether it is less or equal than @a next.
- * @param next The Chain node to compare the priority of.
+ * @param key is the priority to compare.
+ * @param to_insert is the chain node to insert.
+ * @param next is the chain node to compare the priority of.
* @retval true @a to_insert is smaller or equal than the priority of @a next.
* @retval false @a to_insert is greater than the priority of @a next.
RTEMS_INLINE_ROUTINE bool _Scheduler_simple_Priority_less_equal(
- const void *to_insert,
+ const void *key,
+ const Chain_Node *to_insert,
const Chain_Node *next
const unsigned int *priority_to_insert;
const Thread_Control *thread_next;
- priority_to_insert = (const unsigned int *) to_insert;
+ (void) to_insert;
+ priority_to_insert = (const unsigned int *) key;
thread_next = (const Thread_Control *) next;
return *priority_to_insert <= _Thread_Get_priority( thread_next );
diff --git a/cpukit/include/rtems/score/schedulersmpimpl.h b/cpukit/include/rtems/score/schedulersmpimpl.h
index 6fb97c86b2..ab20a554f3 100644
--- a/cpukit/include/rtems/score/schedulersmpimpl.h
+++ b/cpukit/include/rtems/score/schedulersmpimpl.h
@@ -374,21 +374,26 @@ static inline void _Scheduler_SMP_Do_nothing_register_idle(
* @brief Checks if @a to_insert is less or equal than the priority of the chain node.
- * @param to_insert The priority to compare.
- * @param next The chain node to compare the priority of.
* @retval true @a to_insert is less or equal than the priority of @a next.
static inline bool _Scheduler_SMP_Priority_less_equal(
+ const void *key,
const Priority_Control *priority_to_insert;
const Scheduler_SMP_Node *node_next;
- priority_to_insert = (const Priority_Control *) to_insert;
+ (void) to_insert;
+ priority_to_insert = (const Priority_Control *) key;
node_next = (const Scheduler_SMP_Node *) next;
return *priority_to_insert <= node_next->priority;
@@ -931,7 +936,13 @@ static inline bool _Scheduler_SMP_Enqueue(
lowest_scheduled = ( *get_lowest_scheduled )( context, node );
- if ( ( *order )( &insert_priority, &lowest_scheduled->Node.Chain ) ) {
+ if (
+ ( *order )(
+ &insert_priority,
+ &node->Node.Chain,
+ &lowest_scheduled->Node.Chain
_Scheduler_SMP_Enqueue_to_scheduled(
context,
node,
@@ -1007,8 +1018,11 @@ static inline void _Scheduler_SMP_Enqueue_scheduled(
* it now on the scheduled or ready set.
if (
- node->sticky_level > 0
- && ( *order )( &insert_priority, &highest_ready->Node.Chain )
+ node->sticky_level > 0 && ( *order )(
+ &insert_priority,
+ &highest_ready->Node.Chain
if ( node_idle != NULL ) {
Thread_Control *owner;
@@ -1532,7 +1546,13 @@ static inline bool _Scheduler_SMP_Ask_for_help(
insert_priority = _Scheduler_SMP_Node_priority( node );
+ if (
+ ( *order )(
+ &insert_priority,
Thread_Control *lowest_scheduled_idle;
_Thread_Scheduler_cancel_need_for_help(
diff --git a/cpukit/score/src/coremsginsert.c b/cpukit/score/src/coremsginsert.c
index 14b023d9e1..d9e88ae0eb 100644
--- a/cpukit/score/src/coremsginsert.c
+++ b/cpukit/score/src/coremsginsert.c
@@ -24,14 +24,16 @@
#if defined(RTEMS_SCORE_COREMSG_ENABLE_MESSAGE_PRIORITY)
static bool _CORE_message_queue_Order(
- const void *left,
+ const void *key,
const int *left_priority;
const CORE_message_queue_Buffer *right_message;
- left_priority = (const int *) left;
+ (void) left;
+ left_priority = (const int *) key;
right_message = (const CORE_message_queue_Buffer *) right;
return *left_priority <
diff --git a/cpukit/score/src/schedulerpriorityaffinitysmp.c b/cpukit/score/src/schedulerpriorityaffinitysmp.c
index 7d971ef8d1..63d9ae47b1 100644
--- a/cpukit/score/src/schedulerpriorityaffinitysmp.c
+++ b/cpukit/score/src/schedulerpriorityaffinitysmp.c
@@ -52,12 +52,13 @@
static bool _Scheduler_priority_affinity_SMP_Priority_less_equal(
+ const void *key,
return next != NULL
- && _Scheduler_SMP_Priority_less_equal( to_insert, next );
+ && _Scheduler_SMP_Priority_less_equal( key, to_insert, next );
static Scheduler_priority_affinity_SMP_Node *
@@ -326,6 +327,7 @@ static void _Scheduler_priority_affinity_SMP_Check_for_migrations(
if (
&lowest_scheduled_priority,
+ &lowest_scheduled->Node.Chain,
diff --git a/testsuites/sptests/spchain/init.c b/testsuites/sptests/spchain/init.c
index 51278d52f3..ceb4f07b72 100644
--- a/testsuites/sptests/spchain/init.c
+++ b/testsuites/sptests/spchain/init.c
@@ -426,8 +426,14 @@ static void test_chain_node_count(void)
-static bool test_order( const void *left, const Chain_Node *right )
+static bool test_order(
+ const void *key,
+ const Chain_Node *right
+ rtems_test_assert( key == left );
return (uintptr_t) left < (uintptr_t) right;
2.26.2
