[PATCH 21/27] score: Move _Scheduler_Unblock_node()
Sebastian Huber
Mon Nov 15 17:12:53 UTC 2021
Move _Scheduler_Unblock_node() into _Scheduler_SMP_Unblock(). This simplifies
the code and makes it easier to review.
Update #4531.
cpukit/include/rtems/score/schedulerimpl.h | 42 ------------
cpukit/include/rtems/score/schedulersmpimpl.h | 64 ++++++++++---------
2 files changed, 35 insertions(+), 71 deletions(-)
diff --git a/cpukit/include/rtems/score/schedulerimpl.h b/cpukit/include/rtems/score/schedulerimpl.h
index 0081b1904b..10dd039086 100644
--- a/cpukit/include/rtems/score/schedulerimpl.h
+++ b/cpukit/include/rtems/score/schedulerimpl.h
@@ -954,48 +954,6 @@ RTEMS_INLINE_ROUTINE void _Scheduler_Discard_idle_thread(
_Thread_Set_CPU( the_thread, cpu );
_Thread_Dispatch_update_heir( _Per_CPU_Get(), cpu, the_thread );
- * @brief Unblocks this scheduler node.
- * @param context The scheduler instance context.
- * @param[in, out] the_thread The thread which wants to get unblocked.
- * @param[in, out] node The node which wants to get unblocked.
- * @param is_scheduled This node is scheduled.
- * @param release_idle_thread Function to release an idle thread.
- * @retval true Continue with the unblocking operation.
- * @retval false Do not continue with the unblocking operation.
-RTEMS_INLINE_ROUTINE bool _Scheduler_Unblock_node(
- Thread_Control *the_thread,
- Scheduler_Node *node,
- bool is_scheduled,
- Scheduler_Release_idle_node release_idle_node,
- void *arg
- bool unblock;
- ++node->sticky_level;
- _Assert( node->sticky_level > 0 );
- if ( is_scheduled ) {
- _Scheduler_Thread_change_state( the_thread, THREAD_SCHEDULER_SCHEDULED );
- _Scheduler_Discard_idle_thread(
- the_thread,
- node,
- release_idle_node,
- arg
- unblock = false;
- } else {
- _Scheduler_Thread_change_state( the_thread, THREAD_SCHEDULER_READY );
- unblock = true;
- return unblock;
#endif
diff --git a/cpukit/include/rtems/score/schedulersmpimpl.h b/cpukit/include/rtems/score/schedulersmpimpl.h
index 8aa41e81e4..f4383e9379 100644
--- a/cpukit/include/rtems/score/schedulersmpimpl.h
+++ b/cpukit/include/rtems/score/schedulersmpimpl.h
@@ -1326,43 +1326,49 @@ static inline void _Scheduler_SMP_Unblock(
Scheduler_SMP_Node_state node_state;
- bool unblock;
+ Priority_Control priority;
+ bool needs_help;
+ ++node->sticky_level;
+ _Assert( node->sticky_level > 0 );
node_state = _Scheduler_SMP_Node_state( node );
- unblock = _Scheduler_Unblock_node(
- thread,
- node,
- node_state == SCHEDULER_SMP_NODE_SCHEDULED,
- context
- if ( unblock ) {
- Priority_Control priority;
- bool needs_help;
+ if ( RTEMS_PREDICT_FALSE( node_state == SCHEDULER_SMP_NODE_SCHEDULED ) ) {
+ _Scheduler_Thread_change_state( thread, THREAD_SCHEDULER_SCHEDULED );
+ _Scheduler_Discard_idle_thread(
+ thread,
+ node,
+ release_idle_node,
+ context
- priority = _Scheduler_Node_get_priority( node );
- priority = SCHEDULER_PRIORITY_PURIFY( priority );
+ return;
- if ( priority != _Scheduler_SMP_Node_priority( node ) ) {
- ( *update )( context, node, priority );
+ _Scheduler_Thread_change_state( thread, THREAD_SCHEDULER_READY );
- if ( node_state == SCHEDULER_SMP_NODE_BLOCKED ) {
- Priority_Control insert_priority;
+ priority = _Scheduler_Node_get_priority( node );
+ priority = SCHEDULER_PRIORITY_PURIFY( priority );
- insert_priority = SCHEDULER_PRIORITY_APPEND( priority );
- needs_help = ( *enqueue )( context, node, insert_priority );
- } else {
- _Assert( node_state == SCHEDULER_SMP_NODE_READY );
- _Assert( node->idle == NULL );
- needs_help = true;
+ if ( priority != _Scheduler_SMP_Node_priority( node ) ) {
+ ( *update )( context, node, priority );
- if ( needs_help ) {
- _Scheduler_Ask_for_help( thread );
+ if ( node_state == SCHEDULER_SMP_NODE_BLOCKED ) {
+ Priority_Control insert_priority;
+ insert_priority = SCHEDULER_PRIORITY_APPEND( priority );
+ needs_help = ( *enqueue )( context, node, insert_priority );
+ } else {
+ _Assert( node_state == SCHEDULER_SMP_NODE_READY );
+ _Assert( node->idle == NULL );
+ needs_help = true;
+ if ( needs_help ) {
+ _Scheduler_Ask_for_help( thread );
2.26.2
