[PATCH 20/27] score: Move _Scheduler_Block_node()
Mon Nov 15 17:12:52 UTC 2021
Move _Scheduler_Block_node() into _Scheduler_SMP_Block().  This simplifies the
code and makes it easier to review.
Update #4531.
 cpukit/include/rtems/score/schedulerimpl.h    | 56 ---------------
 cpukit/include/rtems/score/schedulersmpimpl.h | 71 ++++++++++++-------
 2 files changed, 46 insertions(+), 81 deletions(-)
diff --git a/cpukit/include/rtems/score/schedulerimpl.h b/cpukit/include/rtems/score/schedulerimpl.h
index 12b6806402..0081b1904b 100644
--- a/cpukit/include/rtems/score/schedulerimpl.h
+++ b/cpukit/include/rtems/score/schedulerimpl.h
@@ -926,62 +926,6 @@ RTEMS_INLINE_ROUTINE Thread_Control *_Scheduler_Release_idle_thread_if_necessary
   return idle;
- * @brief Blocks this scheduler node.
- * @param[in, out] thread The thread which wants to get blocked referencing this
- *   node.  This is not necessarily the user of this node in case the node
- *   participates in the scheduler helping protocol.
- * @param[in, out] node is the node which wants to get blocked.
- * @param get_idle_node is the get idle node handler.
- * @param arg is the get idle node handler argument.
- * @retval thread_cpu The processor of the thread.  Indicates to continue with
- *   the blocking operation.
- * @retval NULL Otherwise.
-RTEMS_INLINE_ROUTINE Per_CPU_Control *_Scheduler_Block_node(
-  Thread_Control          *thread,
-  Scheduler_Node          *node,
-  bool                     is_scheduled,
-  Scheduler_Get_idle_node  get_idle_node,
-  void                    *arg
-  int               sticky_level;
-  ISR_lock_Context  lock_context;
-  Per_CPU_Control  *thread_cpu;
-  sticky_level = node->sticky_level;
-  --sticky_level;
-  node->sticky_level = sticky_level;
-  _Assert( sticky_level >= 0 );
-  _Thread_Scheduler_acquire_critical( thread, &lock_context );
-  thread_cpu = _Thread_Get_CPU( thread );
-  _Thread_Scheduler_cancel_need_for_help( thread, thread_cpu );
-  _Scheduler_Thread_change_state( thread, THREAD_SCHEDULER_BLOCKED );
-  _Thread_Scheduler_release_critical( thread, &lock_context );
-  if ( sticky_level > 0 ) {
-    if ( is_scheduled && _Scheduler_Node_get_idle( node ) == NULL ) {
-      Thread_Control *idle;
-      idle = _Scheduler_Use_idle_thread( node, get_idle_node, arg );
-      _Thread_Set_CPU( idle, thread_cpu );
-      _Thread_Dispatch_update_heir( _Per_CPU_Get(), thread_cpu, idle );
-    return NULL;
-  _Assert( thread == _Scheduler_Node_get_user( node ) );
-  return thread_cpu;
  * @brief Discards the idle thread used by the scheduler node.
diff --git a/cpukit/include/rtems/score/schedulersmpimpl.h b/cpukit/include/rtems/score/schedulersmpimpl.h
index 2ebcd98373..8aa41e81e4 100644
--- a/cpukit/include/rtems/score/schedulersmpimpl.h
+++ b/cpukit/include/rtems/score/schedulersmpimpl.h
@@ -1250,38 +1250,59 @@ static inline void _Scheduler_SMP_Block(
   Scheduler_Release_idle_node       release_idle_node
+  int                       sticky_level;
+  ISR_lock_Context          lock_context;
   Scheduler_SMP_Node_state  node_state;
-  node_state = _Scheduler_SMP_Node_state( node );
+  sticky_level = node->sticky_level;
+  --sticky_level;
+  node->sticky_level = sticky_level;
+  _Assert( sticky_level >= 0 );
-  thread_cpu = _Scheduler_Block_node(
-    thread,
-    node,
-    node_state == SCHEDULER_SMP_NODE_SCHEDULED,
-    get_idle_node,
-    context
+  _Thread_Scheduler_acquire_critical( thread, &lock_context );
+  thread_cpu = _Thread_Get_CPU( thread );
+  _Thread_Scheduler_cancel_need_for_help( thread, thread_cpu );
+  _Scheduler_Thread_change_state( thread, THREAD_SCHEDULER_BLOCKED );
+  _Thread_Scheduler_release_critical( thread, &lock_context );
-  if ( thread_cpu != NULL ) {
-    _Scheduler_SMP_Node_change_state( node, SCHEDULER_SMP_NODE_BLOCKED );
+  node_state = _Scheduler_SMP_Node_state( node );
-    if ( node_state == SCHEDULER_SMP_NODE_SCHEDULED ) {
-      ( *extract_from_scheduled )( context, node );
-      _Scheduler_SMP_Schedule_highest_ready(
-        context,
-        node,
-        thread_cpu,
-        extract_from_ready,
-        get_highest_ready,
-        move_from_ready_to_scheduled,
-        allocate_processor,
-        get_idle_node,
-        release_idle_node
-    } else if ( node_state == SCHEDULER_SMP_NODE_READY ) {
-      ( *extract_from_ready )( context, node );
+  if ( RTEMS_PREDICT_FALSE( sticky_level > 0 ) ) {
+    if (
+      node_state == SCHEDULER_SMP_NODE_SCHEDULED &&
+      _Scheduler_Node_get_idle( node ) == NULL
+      Thread_Control *idle;
+      idle = _Scheduler_Use_idle_thread( node, get_idle_node, context );
+      _Thread_Set_CPU( idle, thread_cpu );
+      _Thread_Dispatch_update_heir( _Per_CPU_Get(), thread_cpu, idle );
+    return;
+  _Assert( _Scheduler_Node_get_user( node ) == thread );
+  _Assert( _Scheduler_Node_get_idle( node ) == NULL );
+  _Scheduler_SMP_Node_change_state( node, SCHEDULER_SMP_NODE_BLOCKED );
+  if ( node_state == SCHEDULER_SMP_NODE_SCHEDULED ) {
+    ( *extract_from_scheduled )( context, node );
+    _Scheduler_SMP_Schedule_highest_ready(
+      context,
+      node,
+      thread_cpu,
+      extract_from_ready,
+      get_highest_ready,
+      move_from_ready_to_scheduled,
+      allocate_processor,
+      get_idle_node,
+      release_idle_node
+  } else if ( node_state == SCHEDULER_SMP_NODE_READY ) {
+    ( *extract_from_ready )( context, node );
2.26.2
