[PATCH 13/27] Mark more nodes as CTLFLAG_MPSAFE
Moyano, Gabriel gabriel.moyano at dlr.de
Wed Nov 17 07:50:25 UTC 2021
or CTLFLAG_NEEDGIANT (17 of many)
r357614 added CTLFLAG_NEEDGIANT to make it easier to find nodes that are
still not MPSAFE (or already are but aren’t properly marked).
Use it in preparation for a general review of all nodes.
This is non-functional change that adds annotations to SYSCTL_NODE and
SYSCTL_PROC nodes using one of the soon-to-be-required flags.
Mark all obvious cases as MPSAFE.  All entries that haven't been marked
as MPSAFE before are by default marked as NEEDGIANT
Approved by:	kib (mentor, blanket)
Commented by:	kib, gallatin, melifaro
Differential Revision:	https://reviews.freebsd.org/D23718
 cpukit/score/src/kern_tc.c | 37 ++++++++++++++++++++++++-------------
 1 file changed, 24 insertions(+), 13 deletions(-)
diff --git a/cpukit/score/src/kern_tc.c b/cpukit/score/src/kern_tc.c
index ed8dc00ac1..1756ac1cb8 100644
--- a/cpukit/score/src/kern_tc.c
+++ b/cpukit/score/src/kern_tc.c
@@ -236,11 +236,16 @@ volatile int32_t time_uptime = 1;
 #ifndef __rtems__
 static int sysctl_kern_boottime(SYSCTL_HANDLER_ARGS);
-SYSCTL_PROC(_kern, KERN_BOOTTIME, boottime, CTLTYPE_STRUCT|CTLFLAG_RD,
-    NULL, 0, sysctl_kern_boottime, "S,timeval", "System boottime");
+SYSCTL_PROC(_kern, KERN_BOOTTIME, boottime,
+    CTLTYPE_STRUCT | CTLFLAG_RD | CTLFLAG_MPSAFE, NULL, 0,
+    sysctl_kern_boottime, "S,timeval",
+    "System boottime");
-SYSCTL_NODE(_kern, OID_AUTO, timecounter, CTLFLAG_RW, 0, "");
-static SYSCTL_NODE(_kern_timecounter, OID_AUTO, tc, CTLFLAG_RW, 0, "");
+SYSCTL_NODE(_kern, OID_AUTO, timecounter, CTLFLAG_RW | CTLFLAG_MPSAFE, 0,
+static SYSCTL_NODE(_kern_timecounter, OID_AUTO, tc,
+    CTLFLAG_RW | CTLFLAG_MPSAFE, 0,
 static int timestepwarnings;
 SYSCTL_INT(_kern_timecounter, OID_AUTO, stepwarnings, CTLFLAG_RW,
@@ -1337,16 +1342,19 @@ tc_init(struct timecounter *tc)
 	tc_root = SYSCTL_ADD_NODE_WITH_LABEL(NULL,
 	    SYSCTL_STATIC_CHILDREN(_kern_timecounter_tc), OID_AUTO, tc->tc_name,
-	    CTLFLAG_RW, 0, "timecounter description", "timecounter");
+	    "timecounter description", "timecounter");
 	SYSCTL_ADD_UINT(NULL, SYSCTL_CHILDREN(tc_root), OID_AUTO,
 	    "mask", CTLFLAG_RD, &(tc->tc_counter_mask), 0,
 	    "mask for implemented bits");
 	SYSCTL_ADD_PROC(NULL, SYSCTL_CHILDREN(tc_root), OID_AUTO,
-	    "counter", CTLTYPE_UINT | CTLFLAG_RD, tc, sizeof(*tc),
-	    sysctl_kern_timecounter_get, "IU", "current timecounter value");
+	    "counter", CTLTYPE_UINT | CTLFLAG_RD | CTLFLAG_MPSAFE, tc,
+	    sizeof(*tc), sysctl_kern_timecounter_get, "IU",
+	    "current timecounter value");
-	    "frequency", CTLTYPE_U64 | CTLFLAG_RD, tc, sizeof(*tc),
-	     sysctl_kern_timecounter_freq, "QU", "timecounter frequency");
+	    "frequency", CTLTYPE_U64 | CTLFLAG_RD | CTLFLAG_MPSAFE, tc,
+	    sizeof(*tc), sysctl_kern_timecounter_freq, "QU",
+	    "timecounter frequency");
 	SYSCTL_ADD_INT(NULL, SYSCTL_CHILDREN(tc_root), OID_AUTO,
 	    "quality", CTLFLAG_RD, &(tc->tc_quality), 0,
 	    "goodness of time counter");
@@ -1701,8 +1709,9 @@ sysctl_kern_timecounter_hardware(SYSCTL_HANDLER_ARGS)
 	return (EINVAL);
-SYSCTL_PROC(_kern_timecounter, OID_AUTO, hardware, CTLTYPE_STRING | CTLFLAG_RW,
-    0, 0, sysctl_kern_timecounter_hardware, "A",
+SYSCTL_PROC(_kern_timecounter, OID_AUTO, hardware,
+    CTLTYPE_STRING | CTLFLAG_RWTUN | CTLFLAG_NOFETCH | CTLFLAG_MPSAFE, 0, 0,
+    sysctl_kern_timecounter_hardware, "A",
     "Timecounter hardware selected");
 /* Report the available timecounter hardware. */
@@ -1724,8 +1733,10 @@ sysctl_kern_timecounter_choice(SYSCTL_HANDLER_ARGS)
 	return (error);
-SYSCTL_PROC(_kern_timecounter, OID_AUTO, choice, CTLTYPE_STRING | CTLFLAG_RD,
-    0, 0, sysctl_kern_timecounter_choice, "A", "Timecounter hardware detected");
+SYSCTL_PROC(_kern_timecounter, OID_AUTO, choice,
+    CTLTYPE_STRING | CTLFLAG_RD | CTLFLAG_MPSAFE, 0, 0,
+    sysctl_kern_timecounter_choice, "A",
+    "Timecounter hardware detected");
 #endif /* __rtems__ */
 #ifndef __rtems__
2.17.1
