[PATCH v2] c-user: Document new clock manager directives
Sebastian Huber
Wed Nov 17 18:32:10 UTC 2021
On 16/11/2021 22:47, Chris Johns wrote:
> On 16/11/21 4:27 am, Sebastian Huber wrote:
>> On 11/11/2021 08:02, Sebastian Huber wrote:> On 09/11/2021 13:06, Sebastian
>> Huber wrote:
>>>> On 09/11/2021 08:50, Sebastian Huber wrote:
>>>>> On 09/11/2021 08:41, Chris Johns wrote:
>>>>>>> We could also use something like this:
>>>>>>> static inline struct timespec rtems_clock_get_realtime(void)
>>>>>>> struct timespec time_snapshot;
>>>>>>> _Timecounter_Nanotime( &time_snapshot );
>>>>>>> return time_snapshot;
>>>>>>> Unfortunately GCC is not able to optimize this.
>>>>>> Ah OK. This can be fixed and the performance improved but once the API is
>>>>>> set it
>>>>>> cannot change or do you think we can add a check later and not break the API?
>>>>> I filed a GCC bug for this:
>>>>> https://gcc.gnu.org/bugzilla/show_bug.cgi?id=103150
>>>>> It seems I was not the only one noticing issues related to structure returns:
>>>>> https://gcc.gnu.org/bugzilla/show_bug.cgi?id=101926
>>>>> However, if we want a foolproof API, then I would prefer the structure
>>>>> return over the return status and pointer argument. Compilers may get better
>>>>> in the future. clang has similar issues, so this is not only a GCC problem.
>>>> We have at least three options for the API:
>>>> 1. Use the existing FreeBSD implementation as is:
>>>> void rtems_clock_get_realtime(struct timespec *);
>>>> This is the easiest and most efficient approach.
>>>> 2. Check for NULL and return a status:
>>>> rtems_status_code rtems_clock_get_realtime(struct timespec *);
>>>> This requires a wrapper function which is a bit less efficient and needs more
>>>> code/testing:
>>>> rtems_status_code
>>>> rtems_clock_get_realtime(struct timespec *time_snapshot)
>>>> if ( time_snapshot == NULL ) {
>>>> return RTEMS_INVALID_ADDRESS;
>>>> _Timecounter_Nanotime( time_snapshot );
>>>> return RTEMS_SUCCESSFUL;
>>>> 3. Return the structure and use the existing implementation:
>>>> This is currently not well supported by existing compilers:
>>> 4. Do nothing for a NULL pointer:
>>> This requires a wrapper function which can use a tail call optimization:
>>> void
>>> return;
>> How do we want to proceed with this? We ship the high performance and very
>> useful clock routines from FreeBSD since 2015. I just would like to add an RTEMS
>> signature for them and document them in the Clock Manager. Currently, these
>> routines are the most efficient way to get clock values in RTEMS. Developers
>> afraid of unchecked NULL pointers may use existing RTEMS directives or
>> clock_get(). It would be nice if we can decide on a way forward.
> I will leave this for Joel to decide.
Joel, what is your opinion on this? I accidentally committed this patch:
https://lists.rtems.org/pipermail/devel/2021-November/069984.html
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax: +49-89-18 94 741 - 08
Registernummer: HRB 157899
