[PATCH v2] c-user: Document new clock manager directives
Fri Nov 19 10:04:12 UTC 2021
On 17/11/2021 19:32, Sebastian Huber wrote:
> On 16/11/2021 22:47, Chris Johns wrote:
>> On 16/11/21 4:27 am, Sebastian Huber wrote:
>>> On 11/11/2021 08:02, Sebastian Huber wrote:> On 09/11/2021 13:06,
>>> Sebastian
>>> Huber wrote:
>>>>> On 09/11/2021 08:50, Sebastian Huber wrote:
>>>>>> On 09/11/2021 08:41, Chris Johns wrote:
>>>>>>>> We could also use something like this:
>>>>>>>> static inline struct timespec rtems_clock_get_realtime(void)
>>>>>>>>     struct timespec time_snapshot;
>>>>>>>>     _Timecounter_Nanotime( &time_snapshot );
>>>>>>>>     return time_snapshot;
>>>>>>>> Unfortunately GCC is not able to optimize this.
>>>>>>> Ah OK. This can be fixed and the performance improved but once
>>>>>>> the API is
>>>>>>> set it
>>>>>>> cannot change or do you think we can add a check later and not
>>>>>>> break the API?
>>>>>> I filed a GCC bug for this:
>>>>>> https://gcc.gnu.org/bugzilla/show_bug.cgi?id=103150
>>>>>> It seems I was not the only one noticing issues related to
>>>>>> structure returns:
>>>>>> https://gcc.gnu.org/bugzilla/show_bug.cgi?id=101926
>>>>>> However, if we want a foolproof API, then I would prefer the
>>>>>> structure
>>>>>> return over the return status and pointer argument. Compilers may
>>>>>> get better
>>>>>> in the future. clang has similar issues, so this is not only a GCC
>>>>>> problem.
>>>>> We have at least three options for the API:
>>>>> 1. Use the existing FreeBSD implementation as is:
>>>>> void rtems_clock_get_realtime(struct timespec *);
>>>>> This is the easiest and most efficient approach.
>>>>> 2. Check for NULL and return a status:
>>>>> rtems_status_code rtems_clock_get_realtime(struct timespec *);
>>>>> This requires a wrapper function which is a bit less efficient and
>>>>> needs more
>>>>> code/testing:
>>>>> rtems_status_code
>>>>> rtems_clock_get_realtime(struct timespec *time_snapshot)
>>>>>     if ( time_snapshot == NULL ) {
>>>>>       return RTEMS_INVALID_ADDRESS;
>>>>>     _Timecounter_Nanotime( time_snapshot );
>>>>>     return RTEMS_SUCCESSFUL;
>>>>> 3. Return the structure and use the existing implementation:
>>>>> This is currently not well supported by existing compilers:
>>>> 4. Do nothing for a NULL pointer:
>>>> This requires a wrapper function which can use a tail call
>>>> optimization:
>>>> void
>>>>       return;
>>> How do we want to proceed with this? We ship the high performance and
>>> very
>>> useful clock routines from FreeBSD since 2015. I just would like to
>>> add an RTEMS
>>> signature for them and document them in the Clock Manager. Currently,
>>> these
>>> routines are the most efficient way to get clock values in RTEMS.
>>> Developers
>>> afraid of unchecked NULL pointers may use existing RTEMS directives or
>>> clock_get(). It would be nice if we can decide on a way forward.
>> I will leave this for Joel to decide.
> Joel, what is your opinion on this? I accidentally committed this patch:
> https://lists.rtems.org/pipermail/devel/2021-November/069984.html
I also checked in the documentation patch. We can adjust the API before
the RTEMS 6 release if necessary.
https://docs.rtems.org/branches/master/c-user/clock/index.html
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax:   +49-89-18 94 741 - 08
Registernummer: HRB 157899
