AW: AW: AW: [PATCH 00/27] Update kern_tc in rtems 5 for ntp support
Gabriel.Moyano at dlr.de Gabriel.Moyano at dlr.de
Mon Nov 22 12:47:59 UTC 2021
> >> I am fine with this change being pushed to the 5 branch but I think it needs to built with the tier 1 archs (i386, powerpc, arm).
> > I could compile them for the BSPs of those archs.
> Thanks.
> > Does it make sense to run some test in qemu?
> Test results are always welcome.
I've run the following tests:
- sptimecounter02, 03 and 04 are pass on pc686 and Xilinx_zynq_a9.
- sptimecounter01 doesn't print something since everything happens inside of boot_card(). How the result of this test is verified?
Are there any other tests that can be interested to run?
For ppc, what bsp and configuration can be used with qemu? (is there some example showing how to run qemu for ppc?)
