AW: AW: AW: [PATCH 00/27] Update kern_tc in rtems 5 for ntp support
Gabriel.Moyano at dlr.de
Tue Nov 23 08:41:39 UTC 2021
> > >> I am fine with this change being pushed to the 5 branch but I think it needs to built with the tier 1 archs (i386, powerpc, arm).
> > > I could compile them for the BSPs of those archs.
> > Thanks.
> > > Does it make sense to run some test in qemu?
> > Test results are always welcome.
> I've run the following tests:
> - sptimecounter02, 03 and 04 are pass on pc686 and Xilinx_zynq_a9.
> - sptimecounter01 doesn't print something since everything happens inside of boot_card(). How the result of this test is verified?
Re-run the test using rtems-test.
- sptimecounter01, 02, 03 and 04 are marked as pass on Xilinx_zynq_a9 and psim
- sptimecounter02, 03 and 04 are marked as pass on pc686
- sptimecounter01 is marked as invalid on pc686. This result is with and without the patch set. I guess it is because nothing is printed out.
> Are there any other tests that can be interested to run?
If there isn't any other test to run, I would say that the patch set is ready.
