[PATCH 1/5] wkspace.c: Change license to BSD-2-Clause
Sebastian Huber
Mon Nov 29 10:29:22 UTC 2021
Change licence according to file history.
Update #3053.
cpukit/score/src/wkspace.c | 29 ++++++++++++++++++++++++-----
1 file changed, 24 insertions(+), 5 deletions(-)
diff --git a/cpukit/score/src/wkspace.c b/cpukit/score/src/wkspace.c
index 546847b82d..e4ba753435 100644
--- a/cpukit/score/src/wkspace.c
+++ b/cpukit/score/src/wkspace.c
@@ -1,3 +1,5 @@
* @file
@@ -10,12 +12,29 @@
- * COPYRIGHT (c) 1989-2009.
- * On-Line Applications Research Corporation (OAR).
+ * Copyright (C) 2012, 2020 embedded brains GmbH (http://www.embedded-brains.de)
+ * Copyright (C) 1989, 2008 On-Line Applications Research Corporation (OAR)
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
- * The license and distribution terms for this file may be
- * found in the file LICENSE in this distribution or at
- * http://www.rtems.org/license/LICENSE.
#ifdef HAVE_CONFIG_H
2.31.1
