[PATCH 1/5] wkspace.c: Change license to BSD-2-Clause
Joel Sherrill
joel at rtems.org
Tue Nov 30 13:49:30 UTC 2021
Ok
On Mon, Nov 29, 2021, 4:29 AM Sebastian Huber <
> Change licence according to file history.
> Update #3053.
> cpukit/score/src/wkspace.c | 29 ++++++++++++++++++++++++-----
> 1 file changed, 24 insertions(+), 5 deletions(-)
> diff --git a/cpukit/score/src/wkspace.c b/cpukit/score/src/wkspace.c
> index 546847b82d..e4ba753435 100644
> --- a/cpukit/score/src/wkspace.c
> +++ b/cpukit/score/src/wkspace.c
> @@ -1,3 +1,5 @@
> +/* SPDX-License-Identifier: BSD-2-Clause */
> * @file
> @@ -10,12 +12,29 @@
> - * COPYRIGHT (c) 1989-2009.
> - * On-Line Applications Research Corporation (OAR).
> + * Copyright (C) 2012, 2020 embedded brains GmbH (
> http://www.embedded-brains.de)
> + * Copyright (C) 1989, 2008 On-Line Applications Research Corporation
> (OAR)
> + * Redistribution and use in source and binary forms, with or without
> + * modification, are permitted provided that the following conditions
> + * are met:
> + * 1. Redistributions of source code must retain the above copyright
> + * notice, this list of conditions and the following disclaimer.
> + * 2. Redistributions in binary form must reproduce the above copyright
> + * notice, this list of conditions and the following disclaimer in the
> + * documentation and/or other materials provided with the distribution.
> - * The license and distribution terms for this file may be
> - * found in the file LICENSE in this distribution or at
> - * http://www.rtems.org/license/LICENSE.
> + * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
> "AS IS"
> + * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO,
> THE
> + * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
> PURPOSE
> + * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS
> BE
> + * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
> + * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
> + * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR
> BUSINESS
> + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
> + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
> + * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF
> THE
> + * POSSIBILITY OF SUCH DAMAGE.
> #ifdef HAVE_CONFIG_H
> 2.31.1
> devel mailing list
> devel at rtems.org
