RSB Failure
Ryan Long
ral051 at oarcorp.com
Tue Nov 30 14:07:45 UTC 2021
Hi,
I'm trying to do a forced build of all of the tools and BSPs for RTEMS
5, but I'm getting this error.
script: 86: source_dir_rtems_tools=${rtems_tools_source}
source setup: rtems-tools-0a5d2057749066e7d184836e92c7ce5334fccc90-1:
source rtems-tools -q -n ${rtems_tools_source}
making dir: /home/tester/rtems-cron-5/rtems-source-builder/rtems/sources
download: (full)
https://git.rtems.org/rtems-tools/snapshot/rtems-tools-0a5d2057749066e7d184836e92c7ce5334fccc90.tar.bz2
-> sources/rtems-tools-0a5d2057749066e7d184836e92c7ce5334fccc90.tar.bz2
download:
https://git.rtems.org/rtems-tools/snapshot/rtems-tools-0a5d2057749066e7d184836e92c7ce5...<see
log> -> sources/rtems-tools-0a5d2057749066e7d184836e92c7ce5334fccc90.tar.bz2
download: no ssl context
download:
log>: error: <urlopen error [Errno 0] Error>
error: downloading
https://git.rtems.org/rtems-tools/snapshot/rtems-tools-0a5d2057749066e7d184836e92c7ce5334fccc90.tar.bz2:
all paths have failed, giving up
"rsb-report-rtems-tools-0a5d2057749066e7d184836e92c7ce5334fccc90-1.txt"
[noeol] 407L, 32689B
Yesterday, it was failing to pull in some patches from a ticket because
the certificates had expired, but I'm not sure if this is the same
issue. I was able to get this tarball with wget.
Does anyone know what the issue might be?
Thanks,
Ryan
