[PATCH] cpukit/aarch64: Use correct context register sets
Fri Oct 1 04:20:47 UTC 2021
looks ok to me.
On Thu, Sep 23, 2021 at 1:05 PM Kinsey Moore <kinsey.moore at oarcorp.com> wrote:
> Context validation for AArch64 was ported from the ARM implementation
> without a reinterpretation of the actual requirements. The spcontext01
> test just happened to pass because the set of scratch registers in ARM
> is a subset of the scratch registers in AArch64.
>  .../cpu/aarch64/aarch64-context-validate.S    | 159 ++++++++++++------
>  .../aarch64-context-volatile-clobber.S        |  19 +++
>  2 files changed, 123 insertions(+), 55 deletions(-)
> diff --git a/cpukit/score/cpu/aarch64/aarch64-context-validate.S b/cpukit/score/cpu/aarch64/aarch64-context-validate.S
> index 1e71bc5b3a..1daa0d6bf2 100644
> --- a/cpukit/score/cpu/aarch64/aarch64-context-validate.S
> +++ b/cpukit/score/cpu/aarch64/aarch64-context-validate.S
> @@ -44,35 +44,47 @@
>  #include <rtems/score/cpu.h>
>  #include <rtems/score/basedefs.h>
> -/* These must be 8 byte aligned to avoid misaligned accesses */
> -#define FRAME_OFFSET_X4  0x00
> -#define FRAME_OFFSET_X5  0x08
> -#define FRAME_OFFSET_X6  0x10
> -#define FRAME_OFFSET_X7  0x18
> -#define FRAME_OFFSET_X8  0x20
> -#define FRAME_OFFSET_X9  0x28
> -#define FRAME_OFFSET_X10 0x30
> -#define FRAME_OFFSET_X11 0x38
> -#define FRAME_OFFSET_LR  0x40
> + * This register size applies to X (integer) registers as well as the D (lower
> + * half floating point) registers. It does not apply to V (full size floating
> + * point) registers or W (lower half integer) registers.
> +#define AARCH64_REGISTER_SIZE 8
> +/* According to the AAPCS64, X19-X28 are callee-saved registers */
> +#define FRAME_OFFSET_X19  0x00
> +#define FRAME_OFFSET_X20  0x08
> +#define FRAME_OFFSET_X21  0x10
> +#define FRAME_OFFSET_X22  0x18
> +#define FRAME_OFFSET_X23  0x20
> +#define FRAME_OFFSET_X24  0x28
> +#define FRAME_OFFSET_X25  0x30
> +#define FRAME_OFFSET_X26  0x38
> +#define FRAME_OFFSET_X27  0x40
> +#define FRAME_OFFSET_X28  0x48
> +#define FRAME_OFFSET_LR   0x50
>  #ifdef AARCH64_MULTILIB_VFP
> -  /* These must be 16 byte aligned to avoid misaligned accesses */
> -  #define FRAME_OFFSET_V8  0x50
> -  #define FRAME_OFFSET_V9  0x60
> -  #define FRAME_OFFSET_V10 0x70
> -  #define FRAME_OFFSET_V11 0x80
> -  #define FRAME_OFFSET_V12 0x90
> -  #define FRAME_OFFSET_V13 0xA0
> -  #define FRAME_OFFSET_V14 0xB0
> -  #define FRAME_OFFSET_V15 0xC0
> +   * According to the AAPCS64, V8-V15 are callee-saved registers, but only the
> +   * bottom 8 bytes are required to be saved which correspond to D8-D15.
> +  #define FRAME_OFFSET_D8  0x58
> +  #define FRAME_OFFSET_D9  0x60
> +  #define FRAME_OFFSET_D10 0x68
> +  #define FRAME_OFFSET_D11 0x70
> +  #define FRAME_OFFSET_D12 0x78
> +  #define FRAME_OFFSET_D13 0x80
> +  #define FRAME_OFFSET_D14 0x88
> +  #define FRAME_OFFSET_D15 0x90
>     * Force 16 byte alignment of the frame size to avoid stack pointer alignment
>     * exceptions.
> -  #define FRAME_SIZE RTEMS_ALIGN_UP( FRAME_OFFSET_V15, 16 )
> +  #define FRAME_SIZE RTEMS_ALIGN_UP( FRAME_OFFSET_D15 + AARCH64_REGISTER_SIZE, 16 )
>  #else
> -  #define FRAME_SIZE RTEMS_ALIGN_UP( FRAME_OFFSET_LR, 16 )
> +  #define FRAME_SIZE RTEMS_ALIGN_UP( FRAME_OFFSET_LR + AARCH64_REGISTER_SIZE, 16 )
>  #endif
>         .section        .text
> @@ -83,25 +95,27 @@ FUNCTION_ENTRY(_CPU_Context_validate)
>         sub     sp, sp, #FRAME_SIZE
> -       str     x4, [sp, #FRAME_OFFSET_X4]
> -       str     x5, [sp, #FRAME_OFFSET_X5]
> -       str     x6, [sp, #FRAME_OFFSET_X6]
> -       str     x7, [sp, #FRAME_OFFSET_X7]
> -       str     x8, [sp, #FRAME_OFFSET_X8]
> -       str     x9, [sp, #FRAME_OFFSET_X9]
> -       str     x10, [sp, #FRAME_OFFSET_X10]
> -       str     x11, [sp, #FRAME_OFFSET_X11]
> +       str     x19, [sp, #FRAME_OFFSET_X19]
> +       str     x20, [sp, #FRAME_OFFSET_X20]
> +       str     x21, [sp, #FRAME_OFFSET_X21]
> +       str     x22, [sp, #FRAME_OFFSET_X22]
> +       str     x23, [sp, #FRAME_OFFSET_X23]
> +       str     x24, [sp, #FRAME_OFFSET_X24]
> +       str     x25, [sp, #FRAME_OFFSET_X25]
> +       str     x26, [sp, #FRAME_OFFSET_X26]
> +       str     x27, [sp, #FRAME_OFFSET_X27]
> +       str     x28, [sp, #FRAME_OFFSET_X28]
>         str     lr, [sp, #FRAME_OFFSET_LR]
> -       str     d8, [sp, #FRAME_OFFSET_V8]
> -       str     d9, [sp, #FRAME_OFFSET_V9]
> -       str     d10, [sp, #FRAME_OFFSET_V10]
> -       str     d11, [sp, #FRAME_OFFSET_V11]
> -       str     d12, [sp, #FRAME_OFFSET_V12]
> -       str     d13, [sp, #FRAME_OFFSET_V13]
> -       str     d14, [sp, #FRAME_OFFSET_V14]
> -       str     d15, [sp, #FRAME_OFFSET_V15]
> +       str     d8, [sp, #FRAME_OFFSET_D8]
> +       str     d9, [sp, #FRAME_OFFSET_D9]
> +       str     d10, [sp, #FRAME_OFFSET_D10]
> +       str     d11, [sp, #FRAME_OFFSET_D11]
> +       str     d12, [sp, #FRAME_OFFSET_D12]
> +       str     d13, [sp, #FRAME_OFFSET_D13]
> +       str     d14, [sp, #FRAME_OFFSET_D14]
> +       str     d15, [sp, #FRAME_OFFSET_D15]
>  #endif
>         /* Fill */
> @@ -119,7 +133,7 @@ FUNCTION_ENTRY(_CPU_Context_validate)
> -       /* X3 contains the FPSCR */
> +       /* X3 contains the FPSR */
>         mrs     x3, FPSR
>         ldr     x4, =0xf000001f
>         bic     x3, x3, x4
> @@ -139,6 +153,23 @@ FUNCTION_ENTRY(_CPU_Context_validate)
>         fill_register   x10
>         fill_register   x11
>         fill_register   x12
> +       fill_register   x13
> +       fill_register   x14
> +       fill_register   x15
> +       fill_register   x16
> +       fill_register   x17
> +       fill_register   x18
> +       fill_register   x19
> +       fill_register   x20
> +       fill_register   x21
> +       fill_register   x22
> +       fill_register   x23
> +       fill_register   x24
> +       fill_register   x25
> +       fill_register   x26
> +       fill_register   x27
> +       fill_register   x28
> +       fill_register   x29
>         fill_register   lr
> @@ -191,7 +222,6 @@ check:
>         bne     restore
>  .endm
> -       /* A compare involving the stack pointer is deprecated */
>         mov     x1, sp
>         cmp     x2, x1
>         bne     restore
> @@ -211,6 +241,23 @@ check:
>         check_register  x10
>         check_register  x11
>         check_register  x12
> +       check_register  x13
> +       check_register  x14
> +       check_register  x15
> +       check_register  x16
> +       check_register  x17
> +       check_register  x18
> +       check_register  x19
> +       check_register  x20
> +       check_register  x21
> +       check_register  x22
> +       check_register  x23
> +       check_register  x24
> +       check_register  x25
> +       check_register  x26
> +       check_register  x27
> +       check_register  x28
> +       check_register  x29
>         check_register  lr
> @@ -222,25 +269,27 @@ check:
>         /* Restore */
>  restore:
> -       ldr     x4, [sp, #FRAME_OFFSET_X4]
> -       ldr     x5, [sp, #FRAME_OFFSET_X5]
> -       ldr     x6, [sp, #FRAME_OFFSET_X6]
> -       ldr     x7, [sp, #FRAME_OFFSET_X7]
> -       ldr     x8, [sp, #FRAME_OFFSET_X8]
> -       ldr     x9, [sp, #FRAME_OFFSET_X9]
> -       ldr     x10, [sp, #FRAME_OFFSET_X10]
> -       ldr     x11, [sp, #FRAME_OFFSET_X11]
> +       ldr     x19, [sp, #FRAME_OFFSET_X19]
> +       ldr     x20, [sp, #FRAME_OFFSET_X20]
> +       ldr     x21, [sp, #FRAME_OFFSET_X21]
> +       ldr     x22, [sp, #FRAME_OFFSET_X22]
> +       ldr     x23, [sp, #FRAME_OFFSET_X23]
> +       ldr     x24, [sp, #FRAME_OFFSET_X24]
> +       ldr     x25, [sp, #FRAME_OFFSET_X25]
> +       ldr     x26, [sp, #FRAME_OFFSET_X26]
> +       ldr     x27, [sp, #FRAME_OFFSET_X27]
> +       ldr     x28, [sp, #FRAME_OFFSET_X28]
>         ldr     lr, [sp, #FRAME_OFFSET_LR]
> -       ldr     d8, [sp, #FRAME_OFFSET_V8]
> -       ldr     d9, [sp, #FRAME_OFFSET_V9]
> -       ldr     d10, [sp, #FRAME_OFFSET_V10]
> -       ldr     d11, [sp, #FRAME_OFFSET_V11]
> -       ldr     d12, [sp, #FRAME_OFFSET_V12]
> -       ldr     d13, [sp, #FRAME_OFFSET_V13]
> -       ldr     d14, [sp, #FRAME_OFFSET_V14]
> -       ldr     d15, [sp, #FRAME_OFFSET_V15]
> +       ldr     d8, [sp, #FRAME_OFFSET_D8]
> +       ldr     d9, [sp, #FRAME_OFFSET_D9]
> +       ldr     d10, [sp, #FRAME_OFFSET_D10]
> +       ldr     d11, [sp, #FRAME_OFFSET_D11]
> +       ldr     d12, [sp, #FRAME_OFFSET_D12]
> +       ldr     d13, [sp, #FRAME_OFFSET_D13]
> +       ldr     d14, [sp, #FRAME_OFFSET_D14]
> +       ldr     d15, [sp, #FRAME_OFFSET_D15]
>  #endif
>         add     sp, sp, #FRAME_SIZE
> diff --git a/cpukit/score/cpu/aarch64/aarch64-context-volatile-clobber.S b/cpukit/score/cpu/aarch64/aarch64-context-volatile-clobber.S
> index 2be5ce69ff..73472b81ac 100644
> --- a/cpukit/score/cpu/aarch64/aarch64-context-volatile-clobber.S
> +++ b/cpukit/score/cpu/aarch64/aarch64-context-volatile-clobber.S
> @@ -90,10 +90,29 @@ FUNCTION_ENTRY(_CPU_Context_volatile_clobber)
>         clobber_vfp_register    d31
>  #endif /* AARCH64_MULTILIB_VFP */
> + * According to the AAPCS64, X0-X18 and X29 are caller-saved registers. X0 is
> + * already being clobbered.
>         clobber_register        x1
>         clobber_register        x2
>         clobber_register        x3
> +       clobber_register        x4
> +       clobber_register        x5
> +       clobber_register        x6
> +       clobber_register        x7
> +       clobber_register        x8
> +       clobber_register        x9
> +       clobber_register        x10
> +       clobber_register        x11
>         clobber_register        x12
> +       clobber_register        x13
> +       clobber_register        x14
> +       clobber_register        x15
> +       clobber_register        x16
> +       clobber_register        x17
> +       clobber_register        x18
> +       clobber_register        x29
>         ret
> 2.30.2
> devel mailing list
> devel at rtems.org
