[PATCH v2 1/6] cpukit/aarch64: Use correct interrupt level types
Gedare Bloom
gedare at rtems.org
Fri Oct 1 04:24:33 UTC 2021
If the rest of the patch set isn't ready, please split this out for
separate submission. It looks fine to me.
On Wed, Sep 22, 2021 at 6:17 PM Kinsey Moore <kinsey.moore at oarcorp.com> wrote:
> All other architectures use uint32_t for interrupt levels and there is
> no reason not to do so on AArch64.
> cpukit/score/cpu/aarch64/cpu.c | 4 ++--
> cpukit/score/cpu/aarch64/include/rtems/score/cpu.h | 4 ++--
> 2 files changed, 4 insertions(+), 4 deletions(-)
> diff --git a/cpukit/score/cpu/aarch64/cpu.c b/cpukit/score/cpu/aarch64/cpu.c
> index d09403a349..b36f55ae17 100644
> --- a/cpukit/score/cpu/aarch64/cpu.c
> +++ b/cpukit/score/cpu/aarch64/cpu.c
> @@ -146,7 +146,7 @@ void _CPU_Context_Initialize(
> -void _CPU_ISR_Set_level( uint64_t level )
> +void _CPU_ISR_Set_level( uint32_t level )
> /* Set the mask bit if interrupts are disabled */
> level = level ? AARCH64_PSTATE_I : 0;
> @@ -156,7 +156,7 @@ void _CPU_ISR_Set_level( uint64_t level )
> -uint64_t _CPU_ISR_Get_level( void )
> +uint32_t _CPU_ISR_Get_level( void )
> uint64_t level;
> diff --git a/cpukit/score/cpu/aarch64/include/rtems/score/cpu.h b/cpukit/score/cpu/aarch64/include/rtems/score/cpu.h
> index 82f74193a2..ae7e2bdcba 100644
> --- a/cpukit/score/cpu/aarch64/include/rtems/score/cpu.h
> +++ b/cpukit/score/cpu/aarch64/include/rtems/score/cpu.h
> @@ -204,9 +204,9 @@ static inline void _AARCH64_Instruction_synchronization_barrier( void )
> __asm__ volatile ( "isb" : : : "memory" );
> -void _CPU_ISR_Set_level( uint64_t level );
> +void _CPU_ISR_Set_level( uint32_t level );
> -uint64_t _CPU_ISR_Get_level( void );
> +uint32_t _CPU_ISR_Get_level( void );
> #if defined(AARCH64_DISABLE_INLINE_ISR_DISABLE_ENABLE)
> uint64_t AArch64_interrupt_disable( void );
> 2.30.2
> devel mailing list
> devel at rtems.org
