[PATCH 2/3] bsps: Add MicroBlaze FPGA BSP
Alex White
alex.white at oarcorp.com
Fri Oct 1 05:43:57 UTC 2021
From: Hesham ALMatary <heshamelmatary at gmail.com>
.../microblaze_fpga/console/console-io.c | 74 +++++++++
.../microblaze/microblaze_fpga/include/bsp.h | 48 ++++++
.../microblaze/microblaze_fpga/include/tm27.h | 48 ++++++
.../microblaze/microblaze_fpga/start/start.S | 109 +++++++++++++
.../startup/_exception_handler.S | 38 +++++
.../startup/_interrupt_handler.S | 38 +++++
.../microblaze_fpga/startup/sim-crtinit.S | 86 +++++++++++
.../shared/include/linker-symbols.h | 104 +++++++++++++
cpukit/score/cpu/microblaze/cpu.c | 47 +++++-
.../microblaze/microblaze-context-switch.S | 89 +++++++++++
cpukit/score/cpu/microblaze/rtems/asm.h | 2 +-
cpukit/score/cpu/microblaze/rtems/score/cpu.h | 145 ++++++++++--------
.../cpu/microblaze/rtems/score/microblaze.h | 35 ++++-
13 files changed, 784 insertions(+), 79 deletions(-)
create mode 100644 c/src/lib/libbsp/microblaze/microblaze_fpga/console/console-io.c
create mode 100644 c/src/lib/libbsp/microblaze/microblaze_fpga/include/bsp.h
create mode 100644 c/src/lib/libbsp/microblaze/microblaze_fpga/include/tm27.h
create mode 100644 c/src/lib/libbsp/microblaze/microblaze_fpga/start/start.S
create mode 100644 c/src/lib/libbsp/microblaze/microblaze_fpga/startup/_exception_handler.S
create mode 100644 c/src/lib/libbsp/microblaze/microblaze_fpga/startup/_interrupt_handler.S
create mode 100644 c/src/lib/libbsp/microblaze/microblaze_fpga/startup/sim-crtinit.S
create mode 100644 c/src/lib/libbsp/microblaze/shared/include/linker-symbols.h
create mode 100644 cpukit/score/cpu/microblaze/microblaze-context-switch.S
diff --git a/c/src/lib/libbsp/microblaze/microblaze_fpga/console/console-io.c b/c/src/lib/libbsp/microblaze/microblaze_fpga/console/console-io.c
new file mode 100644
index 0000000000..47592967ac
--- /dev/null
+++ b/c/src/lib/libbsp/microblaze/microblaze_fpga/console/console-io.c
@@ -0,0 +1,74 @@
+ * @file
+ * @ingroup microblaze_uart
+ * @brief Console Configuration.
+ * Copyright (C) 2015 Hesham Almatary
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
+#include <rtems/bspIo.h>
+#include <libchip/serial.h>
+#include <bspopts.h>
+#include <bsp/uart.h>
+console_tbl Console_Configuration_Ports [] = {
+ .sDeviceName = "/dev/ttyS0",
+ .deviceType = SERIAL_CUSTOM,
+ .pDeviceFns = µblaze_uart_fns,
+ .deviceProbe = NULL,
+ .pDeviceFlow = NULL,
+ .ulCtrlPort1 = UART_BASEADDRESS,
+ .ulCtrlPort2 = 0,
+ .ulClock = 9600,
+ .ulIntVector = 0
+#define PORT_COUNT \
+ (sizeof(Console_Configuration_Ports) \
+ / sizeof(Console_Configuration_Ports [0]))
+unsigned long Console_Configuration_Count = PORT_COUNT;
+static void output_char(char c)
+ const console_fns *con =
+ Console_Configuration_Ports [Console_Port_Minor].pDeviceFns;
+ if (c == '\n') {
+ con->deviceWritePolled((int) Console_Port_Minor, '\r');
+ con->deviceWritePolled((int) Console_Port_Minor, c);
+BSP_output_char_function_type BSP_output_char = output_char;
+BSP_polling_getchar_function_type BSP_poll_char = NULL;
diff --git a/c/src/lib/libbsp/microblaze/microblaze_fpga/include/bsp.h b/c/src/lib/libbsp/microblaze/microblaze_fpga/include/bsp.h
index 0000000000..cb72835571
--- /dev/null
+++ b/c/src/lib/libbsp/microblaze/microblaze_fpga/include/bsp.h
@@ -0,0 +1,48 @@
+ * are met:
+#ifndef _BSP_H
+#define _BSP_H
+#ifdef __cplusplus
+extern "C" {
+#endif
+#include <rtems.h>
+#include <rtems/iosupp.h>
+#include <rtems/console.h>
+#include <rtems/clockdrv.h>
+/* support for simulated clock tick */
+Thread clock_driver_sim_idle_body(uintptr_t);
+#define BSP_IDLE_TASK_BODY clock_driver_sim_idle_body
+#ifdef __cplusplus
+#endif
+#endif
diff --git a/c/src/lib/libbsp/microblaze/microblaze_fpga/include/tm27.h b/c/src/lib/libbsp/microblaze/microblaze_fpga/include/tm27.h
index 0000000000..393990157f
--- /dev/null
+++ b/c/src/lib/libbsp/microblaze/microblaze_fpga/include/tm27.h
@@ -0,0 +1,48 @@
+ * COPYRIGHT (c) 1989-2011.
+ * On-Line Applications Research Corporation (OAR).
+ * are met:
+#ifndef _RTEMS_TMTEST27
+#error "This is an RTEMS internal file you must not include directly."
+#endif
+#ifndef __tm27_h
+#define __tm27_h
+ * Define the interrupt mechanism for Time Test 27
+#define MUST_WAIT_FOR_INTERRUPT 0
+#define Install_tm27_vector( handler ) /* set_vector( (handler), 6, 1 ) */
+#define Cause_tm27_intr() /* XXX */
+#define Clear_tm27_intr() /* XXX */
+#define Lower_tm27_intr() /* empty */
+#endif
diff --git a/c/src/lib/libbsp/microblaze/microblaze_fpga/start/start.S b/c/src/lib/libbsp/microblaze/microblaze_fpga/start/start.S
index 0000000000..9a994c33f8
--- /dev/null
+++ b/c/src/lib/libbsp/microblaze/microblaze_fpga/start/start.S
@@ -0,0 +1,109 @@
+/* Copyright (c) 2001, 2009 Xilinx, Inc. All rights reserved.
+ Redistribution and use in source and binary forms, with or without
+ modification, are permitted provided that the following conditions are
+ met:
+ 1. Redistributions source code must retain the above copyright notice,
+ this list of conditions and the following disclaimer.
+ 2. Redistributions in binary form must reproduce the above copyright
+ notice, this list of conditions and the following disclaimer in the
+ documentation and/or other materials provided with the distribution.
+ 3. Neither the name of Xilinx nor the names of its contributors may be
+ used to endorse or promote products derived from this software without
+ specific prior written permission.
+ THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDER AND CONTRIBUTORS "AS
+ IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED
+ TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A
+ PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
+ HOLDER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
+ SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED
+ TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR
+ PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF
+ LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING
+ NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS
+ SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
+ XMD load *.elf error:
+ MicroBlaze Vector Map for standalone executables
+ Address Vector type Label
+ # 0x00 # (-- IMM --)
+ # 0x04 # Reset _start1
+ # 0x08 # (-- IMM --)
+ # 0x0c # Software Exception _exception_handler
+ # 0x10 # (-- IMM --)
+ # 0x14 # Hardware Interrupt _interrupt_handler
+ # 0x18 # (-- IMM --)
+ # 0x1C # Breakpoint Exception (-- Don't Care --)
+ # 0x20 # (-- IMM --)
+ # 0x24 # Hardware Exception _hw_exception_handler
+ .globl _start
+ .section .vectors.reset, "ax"
+ .align 2
+ .ent _start
+ .type _start, @function
+_start:
+ brai _start1
+ .end _start
+ .section .vectors.sw_exception, "ax"
+ .align 2
+_vector_sw_exception:
+ brai _exception_handler
+ .section .vectors.interrupt, "ax"
+ .align 2
+_vector_interrupt:
+ brai _interrupt_handler
+ .section .vectors.hw_exception, "ax"
+ .align 2
+_vector_hw_exception:
+ brai _hw_exception_handler
+ .section .text
+ .globl _start1
+ .align 2
+ .ent _start1
+ .type _start1, @function
+_start1:
+ //la r13, r0, _SDA_BASE_ /* Set the Small Data Anchors and the stack pointer */
+ //la r2, r0, _SDA2_BASE_
+ la r1, r0, bsp_section_stack_begin-16 /* 16 bytes (4 words are needed by crtinit for args and link reg */
+ brlid r15, _crtinit /* Initialize BSS and run program */
+ nop
+ brlid r15, exit /* Call exit with the return value of main */
+ addik r5, r3, 0
+ /* Control does not reach here */
+ .end _start1
+ _exit
+ Our simple _exit
+ .globl _exit
+ .align 2
+ .ent _exit
+ .type _exit, @function
+_exit:
+ bri 0
+ .end _exit
diff --git a/c/src/lib/libbsp/microblaze/microblaze_fpga/startup/_exception_handler.S b/c/src/lib/libbsp/microblaze/microblaze_fpga/startup/_exception_handler.S
index 0000000000..2224c924f7
--- /dev/null
+++ b/c/src/lib/libbsp/microblaze/microblaze_fpga/startup/_exception_handler.S
@@ -0,0 +1,38 @@
+ met:
+ .text
+ .globl _exception_handler # Exception Handler Label
+ .align 2
+ _exception_handler:
+ rtsd r17, 0
+ nop
diff --git a/c/src/lib/libbsp/microblaze/microblaze_fpga/startup/_interrupt_handler.S b/c/src/lib/libbsp/microblaze/microblaze_fpga/startup/_interrupt_handler.S
index 0000000000..844c7d01bd
--- /dev/null
+++ b/c/src/lib/libbsp/microblaze/microblaze_fpga/startup/_interrupt_handler.S
@@ -0,0 +1,38 @@
+ met:
+ .text
+ .globl _interrupt_handler # Interrupt Handler Label
+ .align 2
+ _interrupt_handler:
+ rtid r14, 0
+ nop
diff --git a/c/src/lib/libbsp/microblaze/microblaze_fpga/startup/sim-crtinit.S b/c/src/lib/libbsp/microblaze/microblaze_fpga/startup/sim-crtinit.S
index 0000000000..6c88272e9e
--- /dev/null
+++ b/c/src/lib/libbsp/microblaze/microblaze_fpga/startup/sim-crtinit.S
@@ -0,0 +1,86 @@
+## Copyright (c) 2015, Hesham Almatary
+## Copyright (c) 2001, 2009 Xilinx, Inc. All rights reserved.
+## Redistribution and use in source and binary forms, with or without
+## modification, are permitted provided that the following conditions are
+## met:
+## 1. Redistributions source code must retain the above copyright notice,
+## this list of conditions and the following disclaimer.
+## 2. Redistributions in binary form must reproduce the above copyright
+## notice, this list of conditions and the following disclaimer in the
+## documentation and/or other materials provided with the distribution.
+## 3. Neither the name of Xilinx nor the names of its contributors may be
+## used to endorse or promote products derived from this software without
+## specific prior written permission.
+## THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDER AND CONTRIBUTORS "AS
+## IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED
+## TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A
+## PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
+## HOLDER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
+## SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED
+## TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR
+## PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF
+## LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING
+## NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS
+## SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
+# sim-crtinit.s
+# Default second stage of C run-time initialization that does not peform
+# BSS initialization to zero. Typical use is on a simulator.
+ .globl _crtinit
+ .align 2
+ .ent _crtinit
+_crtinit:
+ addi r1, r1, -20 /* Save Link register */
+ swi r15, r1, 0
+#ifndef __rtems__
+ brlid r15, _program_init /* Initialize the program */
+ nop
+ brlid r15, __init /* Invoke language initialization functions */
+ nop
+#endif
+ /* Init .bss */
+ addi r6, r0, bsp_section_bss_begin
+ addi r7, r0, bsp_section_bss_end
+_clear_bss_loop:
+ swi r0, r6, 0
+ addi r6, r6, 4
+ cmpu r8, r6, r7
+ bgti r8, _clear_bss_loop
+ addi r6, r0, 0 /* Initialize argc = 1 and argv = NULL and envp = NULL */
+ addi r7, r0, 0
+ brlid r15, boot_card /* Execute the program */
+ addi r5, r0, 0
+ addik r19, r3, 0 /* Save return value */
+#ifndef __rtems__
+ brlid r15, __fini /* Invoke language cleanup functions */
+ nop
+ brlid r15, _program_clean /* Cleanup the program */
+ nop
+#endif
+ lw r15, r1, r0 /* Return back to CRT */
+ addik r3, r19, 0 /* Restore return value */
+ rtsd r15, 8
+ addi r1, r1, 20
+ .end _crtinit
diff --git a/c/src/lib/libbsp/microblaze/shared/include/linker-symbols.h b/c/src/lib/libbsp/microblaze/shared/include/linker-symbols.h
index 0000000000..60a5057486
--- /dev/null
+++ b/c/src/lib/libbsp/microblaze/shared/include/linker-symbols.h
@@ -0,0 +1,104 @@
+ * are met:
+#ifndef LIBBSP_MICROBLAZE_SHARED_LINKER_SYMBOLS_H
+#define LIBBSP_MICROBLAZE_SHARED_LINKER_SYMBOLS_H
+#ifdef __cplusplus
+extern "C" {
+#endif /* __cplusplus */
+ * @defgroup microblaze Linker Support
+ * @ingroup microblaze_shared
+ * @brief Linker support.
+#ifndef ASM
+ #define LINKER_SYMBOL(sym) extern char sym [];
+#else
+ #define LINKER_SYMBOL(sym) .extern sym
+#endif
+LINKER_SYMBOL(bsp_section_start_begin)
+LINKER_SYMBOL(bsp_section_start_end)
+LINKER_SYMBOL(bsp_section_start_size)
+LINKER_SYMBOL(bsp_section_vector_begin)
+LINKER_SYMBOL(bsp_section_vector_end)
+LINKER_SYMBOL(bsp_section_vector_size)
+LINKER_SYMBOL(bsp_section_text_begin)
+LINKER_SYMBOL(bsp_section_text_end)
+LINKER_SYMBOL(bsp_section_text_size)
+LINKER_SYMBOL(bsp_section_text_load_begin)
+LINKER_SYMBOL(bsp_section_text_load_end)
+LINKER_SYMBOL(bsp_section_rodata_begin)
+LINKER_SYMBOL(bsp_section_rodata_end)
+LINKER_SYMBOL(bsp_section_rodata_size)
+LINKER_SYMBOL(bsp_section_rodata_load_begin)
+LINKER_SYMBOL(bsp_section_rodata_load_end)
+LINKER_SYMBOL(bsp_section_data_begin)
+LINKER_SYMBOL(bsp_section_data_end)
+LINKER_SYMBOL(bsp_section_data_size)
+LINKER_SYMBOL(bsp_section_data_load_begin)
+LINKER_SYMBOL(bsp_section_data_load_end)
+LINKER_SYMBOL(bsp_section_bss_begin)
+LINKER_SYMBOL(bsp_section_bss_end)
+LINKER_SYMBOL(bsp_section_bss_size)
+LINKER_SYMBOL(bsp_section_work_begin)
+LINKER_SYMBOL(bsp_section_work_end)
+LINKER_SYMBOL(bsp_section_work_size)
+LINKER_SYMBOL(bsp_section_stack_begin)
+LINKER_SYMBOL(bsp_section_stack_end)
+LINKER_SYMBOL(bsp_section_stack_size)
+LINKER_SYMBOL(bsp_vector_table_begin)
+LINKER_SYMBOL(bsp_vector_table_end)
+LINKER_SYMBOL(bsp_vector_table_size)
+LINKER_SYMBOL(bsp_start_vector_table_begin)
+LINKER_SYMBOL(bsp_start_vector_table_end)
+LINKER_SYMBOL(bsp_start_vector_table_size)
+LINKER_SYMBOL(bsp_translation_table_base)
+LINKER_SYMBOL(bsp_translation_table_end)
+#ifdef __cplusplus
+#endif /* LIBBSP_MICROBLAZE_SHARED_LINKER_SYMBOLS_H */
diff --git a/cpukit/score/cpu/microblaze/cpu.c b/cpukit/score/cpu/microblaze/cpu.c
index 27dd69b9fb..ca4a3ec2f6 100644
--- a/cpukit/score/cpu/microblaze/cpu.c
+++ b/cpukit/score/cpu/microblaze/cpu.c
@@ -1,14 +1,28 @@
- * MicroBlaze CPU Dependent Source
+ * Copyright (c) 2015, Hesham Almatary
- * The license and distribution terms for this file may be
- * found in the file LICENSE in this distribution or at
- * http://www.rtems.com/license/LICENSE.
- * $Id: cpu.c,v 1.24 2010/03/27 15:02:26 joel Exp $
+ * are met:
#ifdef HAVE_CONFIG_H
@@ -42,6 +56,25 @@ void _CPU_Initialize(void)
/* FP context initialization support goes here */
+void _CPU_Context_Initialize(
+ Context_Control *context,
+ void *stack_area_begin,
+ size_t stack_area_size,
+ uint32_t new_level,
+ void (*entry_point)( void ),
+ bool is_fp,
+ void *tls_area
+ uint32_t stack = ((uint32_t) stack_area_begin);
+ uint32_t stack_high = stack + stack_area_size;
+ memset(context, 0, sizeof(*context));
+ context->r[0] = stack_high;
+ context->r[3] = (uint32_t) entry_point;
/*PAGE
* _CPU_ISR_Get_level
diff --git a/cpukit/score/cpu/microblaze/microblaze-context-switch.S b/cpukit/score/cpu/microblaze/microblaze-context-switch.S
index 0000000000..c033fb1f5e
--- /dev/null
+++ b/cpukit/score/cpu/microblaze/microblaze-context-switch.S
@@ -0,0 +1,89 @@
+ * are met:
+#ifdef HAVE_CONFIG_H
+ #include "config.h"
+#endif
+#include <rtems/asm.h>
+.text
+.align 4
+PUBLIC(_CPU_Context_switch)
+PUBLIC(_CPU_Context_restore)
+PUBLIC(_CPU_Context_restore_fp)
+PUBLIC(_CPU_Context_save_fp)
+SYM(_CPU_Context_switch):
+ swi r1, r5, 0
+ swi r13, r5, 4
+ swi r14, r5, 8
+ swi r15, r5, 12
+ swi r16, r5, 16
+ swi r17, r5, 20
+ swi r18, r5, 24
+ swi r19, r5, 28
+ swi r20, r5, 32
+ swi r21, r5, 36
+ swi r22, r5, 40
+ swi r23, r5, 44
+ swi r24, r5, 48
+ swi r25, r5, 52
+ swi r26, r5, 56
+ swi r27, r5, 60
+ swi r28, r5, 64
+ swi r29, r5, 68
+ swi r30, r5, 72
+ swi r31, r5, 76
+SYM(restore):
+ lwi r1, r6, 0
+ lwi r13, r6, 4
+ lwi r14, r6, 8
+ lwi r15, r6, 12
+ lwi r16, r6, 16
+ lwi r17, r6, 20
+ lwi r18, r6, 24
+ lwi r19, r6, 28
+ lwi r20, r6, 32
+ lwi r21, r6, 36
+ lwi r22, r6, 40
+ lwi r23, r6, 44
+ lwi r24, r6, 48
+ lwi r25, r6, 52
+ lwi r26, r6, 56
+ lwi r27, r6, 60
+ lwi r28, r6, 64
+ lwi r29, r6, 68
+ lwi r30, r6, 72
+ lwi r31, r6, 76
+ rtsd r15, 8
+SYM(_CPU_Context_restore):
+ add r6, r5, r0
+ brai restore
diff --git a/cpukit/score/cpu/microblaze/rtems/asm.h b/cpukit/score/cpu/microblaze/rtems/asm.h
index 13609d2d70..b5a8702f02 100644
--- a/cpukit/score/cpu/microblaze/rtems/asm.h
+++ b/cpukit/score/cpu/microblaze/rtems/asm.h
@@ -19,6 +19,7 @@
* notice. This file is freely distributable as long as the source
* of the file is noted. This file is:
* COPYRIGHT (c) 1994-2006.
@@ -36,7 +37,6 @@
#define ASM
#endif
-#include <rtems/score/no_cpu.h>
#ifndef __USER_LABEL_PREFIX__
diff --git a/cpukit/score/cpu/microblaze/rtems/score/cpu.h b/cpukit/score/cpu/microblaze/rtems/score/cpu.h
index 4947045c2c..d9f9e8add5 100644
--- a/cpukit/score/cpu/microblaze/rtems/score/cpu.h
+++ b/cpukit/score/cpu/microblaze/rtems/score/cpu.h
@@ -1,3 +1,30 @@
+ * COPYRIGHT (c) 1989-2008.
+ * are met:
* @file rtems/score/cpu.h
@@ -19,17 +46,6 @@
* add CPU family specific information in this section
- * COPYRIGHT (c) 1989-2008.
- * On-Line Applications Research Corporation (OAR).
- * $Id: cpu.h,v 1.35 2010/10/21 22:14:20 joel Exp $
#ifndef _RTEMS_SCORE_CPU_H
#define _RTEMS_SCORE_CPU_H
@@ -464,19 +480,7 @@ extern "C" {
* to another.
typedef struct {
- /** This field is a hint that a port will have a number of integer
- * registers that need to be saved at a context switch.
- uint32_t some_integer_register;
- /** This field is a hint that a port will have a number of system
- uint32_t some_system_register;
- /** This field is a hint that a port will have a register that
- * is the stack pointer.
- uint32_t stack_pointer;
+ uint32_t r[32];
} Context_Control;
@@ -489,7 +493,7 @@ typedef struct {
* @return This method returns the stack pointer.
#define _CPU_Context_Get_SP( _context ) \
- (_context)->stack_pointer
+ (_context)->r[0]
* @ingroup CPUContext Management
@@ -799,43 +803,32 @@ uint32_t _CPU_ISR_Get_level( void );
/* end of ISR handler macros */
-/* Context handler macros */
- * @ingroup CPUContext
- * Initialize the context to a state suitable for starting a
- * task after a context restore operation. Generally, this
- * involves:
- * - setting a starting address
- * - preparing the stack
- * - preparing the stack and frame pointers
- * - setting the proper interrupt level in the context
- * - initializing the floating point context
- * This routine generally does not set any unnecessary register
- * in the context. The state of the "general data" registers is
- * undefined at task start time.
- * @param[in] _the_context is the context structure to be initialized
- * @param[in] _stack_base is the lowest physical address of this task's stack
- * @param[in] _size is the size of this task's stack
- * @param[in] _isr is the interrupt disable level
- * @param[in] _entry_point is the thread's entry point. This is
- * always @a _Thread_Handler
- * @param[in] _is_fp is TRUE if the thread is to be a floating
- * point thread. This is typically only used on CPUs where the
- * FPU may be easily disabled by software such as on the SPARC
- * where the PSR contains an enable FPU bit.
- * Port Specific Information:
- * XXX document implementation including references if appropriate
-#define _CPU_Context_Initialize( _the_context, _stack_base, _size, \
- _isr, _entry_point, _is_fp ) \
+ * @brief Initializes the CPU context.
+ * The following steps are performed:
+ * - setting a starting address
+ * - preparing the stack
+ * - preparing the stack and frame pointers
+ * - setting the proper interrupt level in the context
+ * @param[in] context points to the context area
+ * @param[in] stack_area_begin is the low address of the allocated stack area
+ * @param[in] stack_area_size is the size of the stack area in bytes
+ * @param[in] new_level is the interrupt level for the task
+ * @param[in] entry_point is the task's entry point
+ * @param[in] is_fp is set to @c true if the task is a floating point task
+ * @param[in] tls_area is the thread-local storage (TLS) area
+ bool is_fp,
+ void *tls_area
* This routine is responsible for somehow restarting the currently
@@ -916,9 +909,9 @@ uint32_t _CPU_ISR_Get_level( void );
-#define _CPU_Fatal_halt( _error ) \
+#define _CPU_Fatal_halt(_source, _error ) \
+ printk("Fatal Error %d.%d Halted\n",_source, _error); \
+ for(;;)
/* end of Fatal Error manager macros */
@@ -1059,6 +1052,21 @@ uint32_t _CPU_ISR_Get_level( void );
#endif
+#define CPU_TIMESTAMP_USE_STRUCT_TIMESPEC FALSE
+#define CPU_TIMESTAMP_USE_INT64 TRUE
+#define CPU_TIMESTAMP_USE_INT64_INLINE FALSE
+typedef struct {
+/* There is no CPU specific per-CPU state */
+} CPU_Per_CPU_control;
+#define CPU_SIZEOF_POINTER 4
+#define CPU_PER_CPU_CONTROL_SIZE 0
+typedef struct {
+ uint32_t r[32];
+} CPU_Exception_frame;
/* end of Priority handler macros */
/* functions */
@@ -1256,6 +1264,15 @@ static inline uint32_t CPU_swap_u32(
#define CPU_swap_u16( value ) \
(((value&0xff) << 8) | ((value >> 8)&0xff))
+typedef uint32_t CPU_Counter_ticks;
+CPU_Counter_ticks _CPU_Counter_read( void );
+CPU_Counter_ticks _CPU_Counter_difference(
+ CPU_Counter_ticks second,
+ CPU_Counter_ticks first
#ifdef __cplusplus
#endif
diff --git a/cpukit/score/cpu/microblaze/rtems/score/microblaze.h b/cpukit/score/cpu/microblaze/rtems/score/microblaze.h
index 06f79aadea..df521f1bd7 100644
--- a/cpukit/score/cpu/microblaze/rtems/score/microblaze.h
+++ b/cpukit/score/cpu/microblaze/rtems/score/microblaze.h
@@ -1,20 +1,41 @@
+ * are met:
* This file sets up basic CPU dependency settings based on
* compiler settings. For example, it can determine if
* floating point is available. This particular implementation
* is specified to the NO CPU port.
- * COPYRIGHT (c) 1989-2011.
* $Id: no_cpu.h,v 1.9 2009/12/02 09:48:25 ralf Exp $
#ifndef _RTEMS_SCORE_NO_CPU_H
#define _RTEMS_SCORE_NO_CPU_H
2.27.0
