[PATCH v2 5/6] cpukit: Add signal mapping support
Fri Oct 1 23:44:53 UTC 2021
On 1/10/21 11:33 pm, Sebastian Huber wrote:
> The fatal extensions have a well defined order (position in the
> table). The user has the full control over the initial extensions table.
Is it backwards compatible when this new mode is enabled?
